Do Accessory Start, reboot Sync if it let's you.Yes, I get no key detected. I do not get a prompt to enter my backup passcode.
See this post - might be applicable. Turning on the climate remotely with FORD app.I just got an update that FedEx won’t deliver the fob until Monday. So much for guaranteed over night.
Is there a more direct way to force the drive password prompt to appear. I’ve not even been able to try my password.
And the code is how gone...tried removing and reinstalling app. Now the phone as a key is totally gone. I guess I’ll just waiting for the fob now.
No idea why I no longer get the prompt for the backup passcode.
Deleting and reinstalling the app was the worst advice you could have gotten. That wipes out any PAAK you have saved.tried removing and reinstalling app. Now the phone as a key is totally gone. I guess I’ll just waiting for the fob now.
I was wondering about this. The other day AC charging would fail after 10 minutes or so. I checked 12v and it was low. Charged the 12v and AC charging had no issue. It's unfortunate how the truck charges the 12v when parked. Other platforms do a better job maintaining the 12v so it doesn't sulfur up as fast.It could be a weak 12v battery issue of course...it can affect so many things. Jump it and see if that helps.
Yes, but actually some other brands have had 12v issue as well.I was wondering about this. The other day AC charging would fail after 10 minutes or so. I checked 12v and it was low. Charged the 12v and AC charging had no issue. It's unfortunate how the truck charges the 12v when parked. Other platforms do a better job maintaining the 12v so it doesn't sulfur up as fast.
My 2023 Teslas had a 16 volt Li-ion Low Voltage battery. They got tired of replacing the 12 v lead acid battery and went to Li-ion.I read somewhere that Tesla got tired of replacing 12v batteries and changed their algorithm to maintain the 12v battery health better.
Makes sense - Li could be longer lasting and easier to keep healthy.My 2023 Teslas had a 16 volt Li-ion Low Voltage battery. They got tired of replacing the 12 v lead acid battery and went to Li-ion.
https://www.autoevolution.com/news/...tage-battery-in-its-latest-models-249724.html
"Tesla replaced the lead-acid low-voltage battery in its vehicles with a Li-ion counterpart in 2021. However, these batteries used NMC chemistry, thus having a higher voltage of 16 volts. The newer Model 3 and Model Ys are now built with a new low-voltage battery that uses LFP cells to produce a lower voltage of 12.8 volts. "
