Stranded - phone as a key stopped working
Yes, I get no key detected. I do not get a prompt to enter my backup passcode.
Do Accessory Start, reboot Sync if it let's you.
xycarp
SE Michigan
2021 Bronco Sasquatch, Lighting Lariat ER on order
tried removing and reinstalling app. Now the phone as a key is totally gone. I guess I’ll just waiting for the fob now.
No idea why I no longer get the prompt for the backup passcode.
I just got an update that FedEx won’t deliver the fob until Monday. So much for guaranteed over night.
Is there a more direct way to force the drive password prompt to appear. I’ve not even been able to try my password.
See this post - might be applicable. Turning on the climate remotely with FORD app.
"...What I didn't expect is the instrument panel display (IPD?) had a message that said "push start button to start vehicle". Hmmm... I do not have my key fob with me and PAAK was not active. I hit the start button and the SYNC screen asked me to enter my password. Hmm, when I entered the PW I was able to put the car in reverse or drive. I was in a carport and choose to move the car only a few inches before putting it back in park. Sitting there trying to understand what had just happed, I tried to put in park again and it wouldn't go. The IPD popped up again to "push start to start vehicle" and once again it asked for a PW. I did and once again I was able to drive the truck. Now I think the only reason I had a password was because I did have PAAK active for a few months and had only turned it off to trouble shoot the key detection problem..."
It could be a weak 12v battery issue of course...it can affect so many things. Jump it and see if that helps.
And the code is now gone...
CARDINAL RULE
NEVER --- EVER --- delete Ford App when you do not have immediate access to a FOB, even if it's malfunctioning.
JCCZ75
Jason
2023 Lariat ER
Deleting and reinstalling the app was the worst advice you could have gotten. That wipes out any PAAK you have saved.
MontanaLightning
Montana
2023 Ford F-150 Lightning
I was wondering about this. The other day AC charging would fail after 10 minutes or so. I checked 12v and it was low. Charged the 12v and AC charging had no issue. It's unfortunate how the truck charges the 12v when parked. Other platforms do a better job maintaining the 12v so it doesn't sulfur up as fast.
Reactions: chl
Yes, but actually some other brands have had 12v issue as well.
I also have a 2012 Leaf and it had the 12v battery go 'dead' when I was away on a 2 month vacation the first winter I had it (2012). The charge timers draw enough energy to drain it fairly quickly.
Since then I have had it on a maintainer - it is now over 14 years old and when I did a battery test, it still was at an 80% SOH. I did have to replenish with distilled water at least once - it's the original OEM flooded battery.
Now and then on the Leaf forum, I read reports of 12v battery failures, so it's a still a thing.
I read somewhere that Tesla got tired of replacing 12v batteries and changed their algorithm to maintain the 12v battery health better.
Besides sulfation because the battery is never really topped off by the truck to 100% there is also the possibility of high current damage since the truck apparently does not limit the charge current to an optimum level - there have been reports of swelling and venting as a result.
Got mine on a maintainer with an AGM mode, fingers crossed!
flyct
Jerry
South Florida
Blissfully Retired
My 2023 Teslas had a 16 volt Li-ion Low Voltage battery. They got tired of replacing the 12 v lead acid battery and went to Li-ion.
https://www.autoevolution.com/news/...tage-battery-in-its-latest-models-249724.html
"Tesla replaced the lead-acid low-voltage battery in its vehicles with a Li-ion counterpart in 2021. However, these batteries used NMC chemistry, thus having a higher voltage of 16 volts. The newer Model 3 and Model Ys are now built with a new low-voltage battery that uses LFP cells to produce a lower voltage of 12.8 volts. "
Makes sense - Li could be longer lasting and easier to keep healthy.
Using a battery maintainer can prolong the lifespan of lead-acid batteries considerably,which is what I have done for years - my 2012 Leaf 12v flooded battery is now over 14 years old and at 80% SOH.
Keeping the depth of discharge to a minimum is key, and always topping off to 100% ensures that the depth of discharge is minimal and sulfates are driven off as completely as possible.
Since I have a lead-acid AGM battery in my Lightning I follow those best practices using a maintainer.
Time will tell how many years it lasts. Fingers crossed.
Adventureboy
Ontario
For those of you using a Faraday pouch, they are not foolproof. If you leave a key fob in the truck, pop the battery cover off and flip the battery. This deactivates the key fob, and a failed Faraday pouch won't cause you grief. This allows you to use the key fob in the emergency slot, or flip the battery back over and use it as a fully operational key fob if needed.
K6CCC
Glendora, Calif.
Sure hope you don't have any afternarket electronics running on that. 16 volts is high enough to damage some electronics that was designed for a 12 volt system (should max out a little under 14 volts).
flyct
Jerry
South Florida
Blissfully Retired
I’m aware. The only after Market device I use is a powered cooler. The DC input is rated from 12-24 DC volts. On our 2023’s the DC output was 16 vdc. . On the 2026 Tesla went to a LFP low voltage battery that outputs 12.8 -13.0 vac.
I purchased the cooler after researching it because I converted my RV to Li-ion.
