Coolant valve broken, no parts, buyback: Fix#92
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I would like to try this but the dealer is holding the part.....
I have a spare OEM one, if you want to purchase it. DM me
lightning-spark
Vancouver, Canada
2023 F150 Lightning Lariat ER
Call them out on Twitter with the photos etc and do everything you can to bring attention to this. The more public you are about it the more likely they are to do something for you.
ka-chow
Scott
2023 Lightning XLT
DJ
@Ford Motor Company Brian has and continues to jump in and offer help. He (of course) can’t help everyone, but I bet there are many here he has helped!
I really don’t understand all the @ing ford here. This dude is not the ceo, not in charge of supply chain, just a guy who either volunteered or was given a tertiary title to crowd source user feedback from current and perspective owners. I suspect he’s got another job that actually pays bills. @ all day, not sure it makes any difference.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
We need like 10 Brians I think before we'd really feel the love. I they hadn't cancelled the truck and started building some 150+kWh packs I feel like we'd be in a much better place.
TwentyTwentyThree
2023 ER
Pointless. You did see article talking about extended range EV drivers being long distance drivers. Whatever that means.
I was super excited to get my Lightning. Between my recent battery service experience and what I’m reading in the forum, ford is not interested in me as a customer. It’s a shame. I mainly registered here so I can stay on top of the T3 news and get on the reservation list early.
Ford F-150 Lightning Coolant valve broken, no parts, buyback: Fix#92 IMG_8766
roddiaz1
Rod
Pittsburgh
Right on!
Would help if you had like a million followers, otherwise might not even get any eyeballs.
Jseis
Washington
article (go-parts) on importance of a coolant control module.
follow link here: Control Module operationsl
Also, doing a bit deeper dive and proprietary issues pop up.
FORScan can read the address and codes for the coolant systems on a 2023 Ford F-150 Lightning. However, the tool does not scan the physical valve as an independent module. Instead, the coolant control valve is treated as a monitored slave component wired directly to a primary vehicle module.[1]
Depending on whether you are looking to pull Diagnostic Trouble Codes (DTCs), perform a pinpoint live test, or check hex addresses in As-Built data, here is exactly how to find it in FORScan:
1. The Module Addresses to Scan
If you are hunting down a fault with the coolant control valve (such as the standard P0D1B code for a stuck valve), you need to communicate with one of two primary modules where the valve logic lives: [1]
  • SOBDMC (Secondary On-Board Diagnostic Module C / Rear Motor-Inverter): On Ford’s EV architecture (shared with the Mach-E), thermal management faults for the high-voltage battery cooling loop—including the physical diverter valve—are predominantly handled and logged by the SOBDMC.
  • BECM (Battery Energy Control Module): This module handles overall pack temperatures and commands flow metrics.
2. Reading Live Data and Testing (PIDs)
Instead of altering raw As-Built hex codes, if you are diagnosing a cooling valve issue, you should use FORScan’s Live Data (PID) or Output Control functions. [1]
  • Select either the SOBDMC or BECM from your module list.
  • Switch to the command/test panel to look for valve position parameters or active self-tests.
  • FORScan allows you to command an output status test to cycle the valve dynamically, verifying if the actuator is physically seized or failing to report its position back to the host module. [1]
3. Deleting or Bypassing the Address via As-Built
You can’t simply code out or disable the coolant valve address (7XX series blocks) in the As-Built configuration to clear the dashboard wrench light, this is not possible. [1]
The hardware profile for the high-voltage battery cooling loop is hardcoded directly into the core operating firmware of the SOBDMC and BECM. It cannot be toggled to a "disabled" state like a courtesy feature (such as approach lighting or turn signal flash counts). Deleting or corrupting the lines of data associated with thermal tracking will immediately trigger an unrecoverable U-code (lost communication/checksum error), locking the truck out of charging or driving. [1, 2, 3, 4, 5, 6]
Mike G
N. AL, USA
When I go to the Ford parts lookup and enter the search prompt for "Coolant Control Valve" I get three of them. I did put in my VIN as part of the search filters. I have an ER, without max tow.
The first relevant item is:
Engine Coolant Control Valve Towing Pack 13 is part # MU5Z8C513A
And the second one shows up as:
Hvac Heater Control Valve Engine Coolant with part # MU5Z8C513B
The third one says it's simply a Valve Asy - Engine Coolant Control with part # MU5Z8C513D, but this one has no picture to show what it looks like.
Pictures of the first two valves look very similar.
I think it's the -D version you're after if I remember.
Mike G
N. AL, USA
Watch the YouTube video a few posts up. Simple fix and good view of what is likely broken.
Yeah, what I wanna know is whether that other diverter valve that looks physically identical can be used as a replacement even if we have to cannibalize the valve or the electronics from a different one to make it all work. Those two valves look so similar that there's got to be some small fix that can be applied to make the "A" version or the "B" version work as an alternative.
Quibbs
SE
23 Lightning, it's electrifying (and discontinued)
Regardless of why, this is not a good look.
I've been thinking about this thread for the last day as I was driving my truck.
If* this is an issue in part due to the cancellation of the Lightning then I would most likely sell my truck sooner rather than later.
For me, the thought that any part that can sideline the truck may be extremely difficult to obtain is not something I want to be driving.
Unfortunately there's no guarantees any other car/truck manufacturer won't have the same issue from time to time.
Though I do think the differentiator here is it's easier to attribute/believe this is due to the vehicle being cancelled rather than a industry wide issue.
Guess we'll see if more stories like this start being reported.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
I have a 2022 XLT SR with 155kmi, best truck I've ever owned and I wouldn't have paid more than the 52k I paid for any more battery, but there are a lot of people who would have, they should've offered it.
ryun
Earth
So Ford is actually going to do a buyback on a $50K truck because they can't locate a $132.60 diverter valve.
Wow. 🤦‍♂️
Yeesh that's nuts.
I'm usually pretty understanding, but if something like that ever happened to me while my extended warranty was still good that would be the last Ford I'd ever buy.
Warp Asylum
Austin, TX
2022 F-150 Lightning Lariat ER, 2023 Mach-E GTPE
I'm getting there too. I was planning to keep it until 2028 or possibly 2029. Now I'm not so sure.
JRDM2
J
2025 Lightning Flash
It’s not ideal, but have you seen the temporary fix method by Martin Rebuilds? Depending on the mode of failure, it may at least get you your vehicle back running while your dealer locate the correct part.
I hope that @Ford Motor Company makes this right, expeditiously. It does not seem that failure of the coolant valve is entirely uncommon. I hope this is not an indicator for future parts availability when issues arise.
I got around to watching it. It seems like it could benefit from an upgrade to metal gears.
