thevofl
Rob
Hayward CA
2021 Antimatter Blue F-150 Platinum
Math
Personally, I'd keep driving my current vehicle unless there was something major wrong that just didn't make sense to repair. Trying to get a vehicle in the next year or so is going to be rough as it appears there is no sign of the chip shortage letting up soon.
I have an order (on 5/1) for a Platinum Hybrid that is waiting for a VIN. I really wanted my next vehicle to be an EV (specifically a pickup). I wasn't hearing anything at the time other than reservations. Once the Lightning was announced and hearing that it would be spring '22 at the earliest, I skipped sending Ford $100 as I am looking to a vehicle soon, thinking that I would be in possession of my F150 Hybrid this summer.
With no VIN in sight I thought I would switch over to the desired Lightning. With a reservation number right around 120,000, I doubt I will get the Lightning before a year from now.
So I will stick with my Hybrid order and switch out in 2023. By then I should also have solar panels installed on my house.
vandy1981
Tennessee
Plumber
The benefit to the antenna (so I’m told) is that it whacks the top of low parking garages first, and let’s you know to mash the brake before you turn your $89K truck into a convertible!
It also gives you the opportunity to stick one of these on your truck:
Ford F-150 Lightning Answers & Info From F-150 Lightning Event. 300 mile range with 1000 lbs payload confirmed 1628546077474
Nikos
Nicholas
Taylors SC
F 150 Lightning
Aircraft Mechanic
Thanks for the info. As a Mach E owner I like to give as much info to all the owners. Any questions, any doubts, any reservations are all answered thru the forum. I am one of the early reservation holders and I am looking forward to my F150 Lightning. I had to wait 14 months for my Mach E.
I have learned from my Mach E a lot. The experience is enlightening. Can't wait for the Lightning. OTA updates will make the experience even greater.
Patience.!!!
vegas2k
Reno NV
Prius, Fit
Not sure if I have seen this covered before, but can the lightning charge amps be customized to charge at a lower amperage? My home outlet that charges the bolt goes to 40 which is my outlet max amp. The bolt is fine because it makes out at 32amps. The evse is 40amp. So I'd like to use this evse with the lightning but set it to 32 amps while home charging, and 40 when I'm at an RV charge port that can support the full 40 amps.
shutterbug
Phoenix
The mobile charger that will come with Lightning is 32A, so you can use that. Most 48A and 40A chargers allow you to change the Amps they draw (either through the App or DIP switches). Note that at 32A it will take a full day and night to charge the extended range battery.
vegas2k
Reno NV
Prius, Fit
Yah, my 40 amp(mustart) evse does not allow any amp changes (I think)
shutterbug
Phoenix
I was referring to Chargepoint, Juicebox, Grizzl-e, Ford Connected charger, etc.
astricklin
99 Mercury mountaineer
I believe that even with a fairly simple evse, the vehicle and the box still communicate. The cable is going to tell the vehicle it can only supply x amperage.
Lime Green
CO / AZ
F-350, Expedition Max, Tesla...
Why the fake propulsion sound? It’s so stooopid. They put it in the Expedition to make it sound like it has a V8. Real subtle, most people don’t realize it’s fake, but turn it to Sport mode and it pumps the volume and it becomes really cheesy. Did some marketing exec actually think that people wanted this? Or that people wouldn’t buy their truck/SUV if it didn’t sound like it had a bigger engine in it? Oh, and they did the same on the Bronco Sport. No fake noise there normally, but if you put it in Sport mode, then it suddenly growls like an old-timey V8 Bronco and it’s comically out of place and poorly done. If I could meet the person who approved that I’d love to kick him/her square in the nuts.
They put fake V8 Mustang noise in the Mach-E, but at least there’s an option to turn it off.
Being a long-time Tesla owner, I can say one of the greatest things about electric is the SILENT power. …Well, my first Model S kinda sounded like a small jet spooling up for take-off when accelerating hard, but that was cool in a different way. The Mach-E sounds like a dentist drill, so yeah, I’d want to cover that up, but fake V8 noise isn’t the answer.
F150ROD
U.S. Navy Retired
Id estimate about 90% of cars nowadays have sound pumped into the cabin. Ford is just doing what they think will help transition buyers faster.
MickeyAO
Mickey
San Antonio Tx
With all the cars I've had to drive for my job, I have yet to hear an interior sound added. I do know the exterior sound is regulatory until the tire noise is loud enough (about 20 mph).
shutterbug
Phoenix
Ahem, Mustang Mach-E pipes in what Ford calls "propulsion" sound. Thankfully, it can be turned off.
vegas2k
Reno NV
Prius, Fit
Oh ok. I'm thinking what I can do is using my 40 amp charger which will be ok with my Bolt, as the bolt will only draw 32 amps. Once I get the ford, I'll use the current 40 amp charger exclusively on the ford where it has an appropriate 40 amp capable plug and use the ford evse with the bolt, if that makes sense. What plug does the ford come with for 240v charging? NEMA 14-50? That would e perfect, maxing out the bolt. Ford uses the standard J1772 connector I assume.
shutterbug
Phoenix
Yes J1772. Ford (standard range) can use anything the charger provides up to 48A. The Ford mobile charger comes with 2 swappable plugs: NEMA 14-50 and standard 110V plug.
blkZ28spt
2019 501A SCREW 4x4 tuned 3.5
Because it was well integrated, and you couldn't even tell.
