✅ 1/9/2023 Lightning Build Week Group (MY2023)
msadan
Lafayette IN
2023 F-150 Lightning Pro, 2025 Tesla Model 3, 2010 Tesla Roadster
Pinball repair
Mine just says "BAT"
They probably just have a set number of characters for that line. I think I would have gone with “STD BATTERY”, or maybe “STANDARD BAT”.
EVMainer
Jesse
Maine
Prius, Volt, F150 Lightning Pro
Just heard from my rep that I'm in production. Pulled the window sticker with a blend date of 01/12! Pretty stoked that this is really happening.
There is a little clarification needed with the term IN PRODUCTION.
When your window sticker was selected for production day, it was also sent to plant, that triggers the status narrative to say "In Production" as colored pink on the snapshot, the actual build/blend day should reflect on the lime green area under the label "In Production" on the time bar.
If everything is humming along nicely the date shown will match your blend date, if the production line is running slow or behind schedule, the date will be later than your blend date.
Once you see a date in the green area, you might also see service modules being to populate, leading to a tear tag.
If the truck has no QA issues and no missing parts/chips, it will be marked BUILT a few to 10 days later.
Ford F-150 Lightning ✅ 1/9/2023 Lightning Build Week Group (MY2023) 1672804336235
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
So, if I don't have a date under IN PRODUCTION, MY "In Production" status is not really moving along yet? According to my Window Sticker, my blend date is 1-15-23. Once a date appears under IN PRODUCTION, hopefully it should be the same or before the blend date on the sticker for my truck production to be humming along?
I'm just so amped up about my truck, I want to learn any and everything about this process.
Thanks.
Ford F-150 Lightning ✅ 1/9/2023 Lightning Build Week Group (MY2023) InProduction
You got it, understand the sub assemblies are being assembled and queued for final mating on the blend day, several days of preparation are in process but the unity moment is everything coming together and the LVB connected to the the electrical system bringing life to your truck, it's heart is beating when the service codes are loaded and archived to the master file.
keen
Minneapolis, MN
F150 Lightning
bizz
NY
Chevy Tahoe, Ford F250
Just filled out the order tracking form for my 2023 PRO SR in Carbonized Gray Metallic that's scheduled to go into production 1/9/2023
Sealevel
Martin
Memphis, TN
23 XLT Lightning SR
Engineer - Retired 2025
Our Build Week has arrived - GLTA! ? I know we will be watching for every hint of progress. :D
Good luck folks
msadan
Lafayette IN
Pinball repair
January 16th blend date. I’m starting to get excited!
Lightning Rod
North Coast
I can't remember the thread where someone said that they were a software developer and he made and posted a link to a really cool and more comprehensive tracker for tracking our trucks through the build process. Does anyone know that link or the link to that thread?
Thanks.
