Status
Not open for further replies.
RapidRedRick
Rick
Northern Virginia
Ford F150 Platinum Powerboost
My power running boards are not moving anymore either. I did the PMI as both original and new, unplugged the battery for a few hours and tried again, even tried unplugging the running boards and completely unplugging the DSM for some time and trying it all again. Nothing seems to work. When I unplugged the DSM tho, i did get a POWER RUNNING BOARD FAULT message on the IPC. Goes away once you plug it back in. I think side loading firmware is the only solution at this point as @Jesse-Infotainment mentioned. That or go play dumb at your local dealer, something I don't really wanna do.
EDIT: I got them back alive! I went into Forscan, DSM module, went to line 744-23-02 and changed **xx-xxxx to 00 (configured them to NOT present). Saved the changes. Then went and changed it back to 01 (as built) and saved it. They came back alive instantly!
RapidRedRick
Rick
Northern Virginia
That is some awesome problem solving. I have a similar issue, I lost my heated steering/ heated & cooled seat functions. I believe the controlling lines are in the DSM. I would like to try that on/off trick too. Is there a guide that sows the functions of each of the lines in the module? How did you find where the line was to make the changes?
Slappy McGee
South Caccalackey
2021 F-150 Powerboost
I haven’t dug through all the “tools” in FDRS but I find it odd there’s not a Ford-sanctioned fix for this stuff, which doesn’t seem unusual. My running boards are out of commission and I haven’t tried the seats yet so who knows how that will turn out!
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
Congrats! I have not used Forscan. Do I need the OBDLink from the tutorial or will the Mongoose work?
You need a different cable and forscan (and a license for it i believe, though its significant cheaper). There is an excellent tutorial on how to do it by @Livnitup under the Forscan thread on this forum.
As mentioned, the Mongoose (and Nano) will both work with FORScan. Worst case you'll just have to go into settings and change the adapter FORScan is using.
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
I'm not sure why Ford would "sanction" what this thread represents. And certainly not the editing of ASbuilt parameters with Forscan.
Having said that, I wouldn't be surprised if Ford has some folks monitoring what is being shared here and have discussed it in the conference room in various contexts. :)
antho
Anthony
Houston, Texas
2021 801A Raptor
Just wanted to shoutout @speedracercjr. He let me borrow his Mongoose and it fixed all of the corrupt Nano data i had. Its nice to be able to do a network scan with the truck connected! Sometimes jumping the gun isnt a good thing and i wish i knew about the Mongoose before i bought the paperweight Nano.
Also, The mongoose does not see my SODCMC and SODCMD in forscan just like the Nano. So i would assume its a Forscan and J2534 issue.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
glad to help a fellow member out! To be fair we all thought the Nano was a budget deal, and it still kind of is as long as you know the pitfalls of the network scan and that it will only get updates so far.
Slappy McGee
South Caccalackey
I guess what I was trying to say was that if the Ford "official" software update tool (FDRS) "disables" the power running boards in some capacity, they would presumably it would also provide some sort of tool to "fix" them since it seems to be a not-uncommon problem.
Perhaps I assume too much from the good people that brought you the 1.7.1 "borked" OTA update.
ksimon123451
Kelly
21 F150 Lariat
Systems Administrator
I purchased a new to me 21 F150 Lariat 3 weeks ago with a stuck update 1.7, I just got my Mongoose and recommended battery charger, all the updates went off with out a hitch. Then came the Apim I created the USB and nothing. So my plan is to leave it plugged in the truck until it starts. I have it currently sitting in the driveway with the battery charger, key on engine off. I am getting the IPMA u2400 error and I no longer have lane centering and street sign adjusted cruise control.
I am excited to be apart of this forum and a new ford owner.
Ajzride
Alan
Houston
Eng
I believe that the engine has to be on for the USB update to kickoff. I know FDRS instructs you to engine on, and the popup tells you to drive the car as normal while updating.
ksimon123451
Kelly
21 F150 Lariat
Ok great thank you.
Snakebitten
Coastal Texas
Agree. Ford should have a remedy for the disabled power running boards.
And they just might, as soon as they know about it and then come up with an appropriate update routine that "toggles" the AB value similar to what was brilliantly discovered by one of our own. :)
I personally believe this grassroots OTA/FDRS group is fluid and FAST moving compared to what Ford's huge machine is.
christophers
Christopher
Austin, TX
2021 F150 Platinum Hybrid
With BMWs we use a tool for F and G chassis called E-Sys. It's a factory diagnostic and low-level editing tool that dealerships do not have. It was protected by certificates but those were able to be re-generated by a gentleman named TokenMaster (haha). After a few years, BMW basically "scrambled" all of the text and information in Esys thinking they would prevent people from using it. They were wrong.
From what I've seen with Ford vs BMW, Ford seems to understand people use these tools and has (unlike BMW) made them safer and more dummy-proof. FDRS module recovery is a great example of this, as is saving As-Builts in a database, among other things. I'm sure Ford knows we use these tools, but they likely sat down and realized that _most_ of the people here are trying to do things right and in the end, saving money on warranty payouts to dealerships. Also, they are almost certainly learning from what we're doing on not only how to improve their products and tools, but also how to write new TSBs and shop instructions for procedures.
It would be cool for someone in the technical group of Ford to let us know if we're helping/hurting, but if we were hurting them it's fairly trivial for them to implement roadblocks.
Status
