Status
Not open for further replies.
BHunted1
Sumner County TN
2021 Ford-150 Platinum Hybrid
Yep
I can launch FDRS without any adapter, pull from the mothership, and get different values for the APIM than I get 2 minutes later if I repeat the whole process.
So it's definitely ONLY an FDRS related phenomenon since there's no influence from the truck itself or an adapter.
I haven't actually seen any impact that I've noticed. But who knows? :)
Weird. It also goes blank for awhile. I reload, then its back.
No more fdrs subscription tomorrow. Have to wait for something to happen I guess. Would be nice to get an ota eventually. ?
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Also this happened just a bit ago. I had been needing to replace my battery, I suspected it was bad and sure enough it was. I actually got the message about it was safe to remove the USB that the update was complete. I've never seen that message before! I'm going to run through the rest of the updates and see if it goes smoother. If it does I guess my bad battery was holding me back. Stay tuned...
Ford F-150 Lightning ECU module programming guide using FDRS IMG_1980
imnuts
Dirty Jerz
'21 502A Powerboost 4Ă—4
Facilities Engineer
I was actually thinking the other day about bad/weak batteries and random issues people have. The biggest thing I'm wondering is if the MyView and other settings not saving are due to a bad battery. With the number of people posting about batteries getting replaced, it would make sense. I can also see Ford having logic saying not to start an update unless voltage is >X, similar to cell phones.
BHunted1
Sumner County TN
Your truck battery? Must be 12.5vdc or higher. This had me concerned too as I’ve never had an ota. I considered leaving a battery tender on a few nights. During the day it stays pretty good and never had a start prob. But when I put the charger on, its at 12.5 already. But you’d think 16hrs out of the day, it would be fine.
I’m old school. Batteries years ago were about 13.8 but didn't have all the gizmos these days.
speedracercjr
Cory
Houston
2021 Lariat EB
O&G
Yes replaced the truck battery. I've ran with the recommended battery charger on it many many times. Who knows, running the TCU update right now, we'll see how it goes.
BHunted1
Sumner County TN
Holy shit, it was the freaking battery. I just updated the TCU, followed the prompts, walked away for 13 minutes, ignition on no engine and got the complete message on the first try. I've never had an update go that smoothly.
Dealer replace it or on your dime?
Snakebitten
Coastal Texas
2021 F150 Powerboost Platinum
I had a new PCM update pop up yesterday. Applied it tonight.
Anyone else that has been uptodate on all updates recently seen this new one?
(Powerboost)
Just curious if anyone knew what it is.
Thekameleon
Chicago
2021 Ford F150
(Powerboost)
I saw this too, but didn't apply it yet.
Bob_Mac
Bob
North Carolina
2021 Ford F-150 Platinum
Cyber Security | Developer
My 2.3.0 OTA failed due to a bad battery. My truck sat from 3/21 to 10/21 because of the chip shortage and I'm thinking that was the cause of a bad battery due to no maintainer while sitting for so long.
BHunted1
Sumner County TN
I'm sure if I pushed the issue the dealer would have replaced it, however they are horrible to deal with so I spent the change myself.
What it run ya? Also, did ya take a voltage reading on the new one afterwords?
jperry5835
2021 F-150 Hybrid Platinum
I'm looking for VINs guys. I'm trying to collect some data and test something I recently created so the more VINs you PM the better.
I'm trying to build out some module data info, plus this will also help with letting you guys know when you may have updates available.
Here is mine - 1FTFW1ED2MFB62273
Status
