WildBlue
What doesn't seem to work or works differently than I expected is the temperature. When I set the temperature to 74 degrees, when I get into the truck, the HVAC shows the temperature I set in-truck from the prior use (72 degrees). I expected the HVAC to have the temperature set to the value I selected with the app during pre-conditioning. Is this what others are experiencing?Departure Timer kicked off as it has in the past.
For kicks & giggles I switched the wheel warmer on to see if it's actually on when I go out at 8am,
ambient temp is around 61 degrees so I really don't need it, but I want to see if it works in an "unplugged" operation.
UPDATE: heated wheel worked!!!!
