B177y
Olympic Peninsula, WA
2024 Pro SSV ER Max Tow
tHIS ERROR ISNT A big deal. The failure can be due to one line. If you dont have a 2100 DTC in the PCM I wouldnt worry about it.
Meaning if one line doesnt report success it will fail the entire procedure.
THis is typically due to an updated config.. change in a line length. The updated config doesnt have the added octets accounted for.
no biggie
Thanks Jesse!
I had some PCM DTCs when @Mike G ran my VIN:
C0604
C0630
P161C
U0111
The update shows as still available (green "run"). You are saying to just ignore the update?
Jesse-Infotainment
Jesse
Dallas
2024 F150 Lightning Platinum
Thanks Jesse!
C0604
C0630
P161C
U0111
You can attempt to clear those. I would bet they are all :08 status meaning not currently active.
FOr now yes.. I would ignore it. The update wont clear if it doesnt have a successful Config. The module is updated though if it flashed. The PCM only as one file the strategy. So if you saw the flashing occur the its updated.
you can TRY the configuration also.. But end of the day sounds like a issue on Fords end
B177y
I just hate not being able to complete an update after spending $120. Oh well...
Thank you for the help!
Jesse-Infotainment
Jesse
Dallas
I understand. Been many updates like that over the years.. they wont clear.. one was the GSM for the ICE trucks. THe ACM.. The PCM for some power boost. Nothing new.
If they ping your truck run the interrogator it will clear it. Just the data submission is at the end after the config. Network scans arent as common in the new FDRS..
B177y
Just to close the loop on this PCM thing, I checked FDRS today to see if the PCM cleared and to see if anything else magically popped up that needed to be updated before my two-day subscription ended.
The PCM has cleared and no more updates available 👍🎉
Mike G
Mike G
N. AL, USA
I know the cost to use FDRS has gone up, but there is a very reasonably priced used Mongoose over on the ICE forum - https://www.f150gen14.com/forum/threads/mongoose-plus-ford-cable-300-shipped.43325/post-725348
Which is what the Topdon Rlink J2532 costs, and it works on multiple OEM systems......not just Fords.
I have one of those I got during a Prime event, and it works just as well as my Mongoose does.
I got it with the intention of testing it out and then passing it on to one of my kids. I still use a VCM3 primarily, but would have no problems using the Rlink instead.
For those that haven't seen - we have a new "tweaker" coming to the dark side: Tweaker
ytwytw
Toronto, Canada
2023 F150 Lighting ER Lariat
does anyone know if walk away lock can be updated via FDRS? if not, can it be sideloaded with Forscan?
rugedraw
Javier
Miami
Auto Sales
I've never done it because I haven't had to, but it can be side-loaded if you are able to source the correct files. The BCM is VIN coded, so you would need to write your VIN to the proper block after you flash it.
I will STRONGLY suggest you do not trust FORScan to pull the correct files on its own. It's one thing FAAFO with a door module or something minor, but a bricked BCM will turn your truck into a 3 and a half ton paperweight.
PJnc284
Garner, NC
Was just wondering if it could be done with the beta forscan. Updated the IPC on my 23 last week with one from a 24 to get the charge rate. Took 5.5 hours so wasn't the fastest process. Already had my bcm updated at the dealer though. Maybe @Jesse-Infotainment has some insight
ytwytw
Toronto, Canada
Thanks! Hopefully Ford can deliver OTA soon to the north
