New BlueCruise Version 1.4 - Rollout
RLXXI
S. E. Louisiana
Auto tech
I had asked before how to tell what version of BC I have, and was told that 2025s all shipped with BC1.2 and BC1.4 wasn't out for them yet. Is that not correct? How do you know that you have 1.4?
Well, I thought I saw it somewhere either on a Ford website or on screen in the truck or on the app but damned if I can find it now so I have no idea at this point what BC I have lol. Good grief.
What I'm going to do to find out though is on the near horizon, I picked up a strong power supply and I'm going to interface with Ford's data base and my vcm2 to see what's what.
PJnc284
Garner, NC
Believe 1.4 adds curve control (well technically 1.3 but the lightnings skipped to 1.4) when you have predictive speed assist enabled (automatically slows and speeds up for speed limit changes). This slows the truck down going into curves even with regular hands-on lane center but tends to spaz out. Maybe someone with a 24 can confirm since it came with 1.2.
RLXXI
S. E. Louisiana
Auto tech
Ok I think I found it. One thing I noted when using BC I blipped the turn signal to change lanes and the truck did it for me if that's indicative of BC 1.4.
Here's the chart I found that says all 25> comes with BC 1.4 where as the Mustang e comes with BC 1.5 and goes on to say other models to follow. I only grabbed the ss of the f 150 timelines and software levels.
Ford F-150 Lightning New BlueCruise Version 1.4 - Rollout f150bluecruiselevels
PJnc284
Garner, NC
1.2 has lane change assist and in lane repositioning. 1.4 is just stability improvements and the curve control which I'm sure most don't run into since Predictive Speed Assist is flaky enough leading to most to disable it. Google does seem to think the 25's (excluding mach e) came with 1.4 though
The Weatherman
Dean
South Central KY
A
As mentioned, if you have automatic lane change with a tab of the turn single you have 1.4 more likely than not.
Timeless Epoch
Chad
2024 F150 Lightning Platinum
Professionally: Disaster Recovery - Recreationally: Watchmaker
Either I have a very rare 2024 that came with 1.4, or 1.2 includes both lane changing via turn signal and a rather aggressive slow down for very shallow curves. For moderately shallow curves, it just runs and hides and makes me take over.
I don’t think 1.4 adds any major features. Just some well needed refinement.
The Weatherman
Dean
South Central KY
That sounds like 1.2 behavior.
Those Ai searches might confuse what's deployed to ICE vs BEV vehicles as well.
MidAtlanticLightningClub
F-150 Lightning Lariat ER
Here's the actual info from Ford:
Ford F-150 Lightning New BlueCruise Version 1.4 - Rollout BC_Shipped_With
Ford F-150 Lightning New BlueCruise Version 1.4 - Rollout BlueCruise-1-4-Performance-Improvements
Ford F-150 Lightning New BlueCruise Version 1.4 - Rollout BlueCruise-Software-Versions-Chart-1.4
rugedraw
Javier
Miami
Auto Sales
Zed
Chuck
2022 Lightning Platinum Rapid Red
Heat index here is 100 degrees today, but apparently he!! still froze over: BC1.4 finally pushed out to my 2022 Platinum!
Ford F-150 Lightning New BlueCruise Version 1.4 - Rollout BC1_4a
TaxmanHog - if you haven't seen yours yet, the time may be near. Our updates have been closely matched for a while, so.....
Not yet, but looking forward to it, BTW is this [ IPMA-24.204.10.9 ]listed at the bottom of the release notes?
