New truck tried to kill me!
BuzzLightning2023
Los Angeles
92 Explorer,94 F150,06 Avalanche,05 F250,11 F150
I think there's a big difference between a legit concern, or even "power steering failed, could have crashed" and "my truck tried to kill me !", that's all.
A complete power steering failure is obviously much worse than fighting lane assist, if that is what happened. But even so, it is usually not completely frozen /
unmaneuverable at that point (think we would have seen a lot more lawsuits if that was the case), but I suppose anything could happen, especially if the driver panics.
I’ll bite my tongue now. I got chased out of this forum for going toe-to-toe with some dude over something very trivial.
BuzzLightning2023
Los Angeles
The man was scared. He’s entitled to use a little hyperbole. Safe to say he doesn’t think HAL took over his truck.
MontanaLightning
MontanaLightning
Montana
2023 Ford F-150 Lightning
Thankfully, I'm strong enough to overpower the 1's and 0's of a failed steering system that is capable of driving the truck without human input.
designthis
NYS
2023 F150 Lightning Lariat SR Black 8/21/23 blend
Builder
It's much more than a "concern" when the truck tries to steer you off the highway.
This is beyond terrifying to think about. If my wife read this post she’d probably not let me take ownership. Mine was built on 8/25 and I’m still waiting for it. My current truck is tried and true and for what it’s worth—has never tried to kill me. I really hope —when you get to the bottom of this problem,—you’ll let us all know What it is.
BTW, which model do you have? And when was it built?
Glad you’re alive!
ctuan13
Chuck
Pittsburgh, PA
This isn't just "power steering failure". I've driven a heavy car with a failed power steering rack. If it suddenly stopped working at highway speeds, I wouldn't have even noticed. Most variable assists almost entirely disable assist at highway speeds, precisely because so little effort is needed to turn the wheel at speed and so little steering wheel turning arc is needed when you're moving at that speed.
It sounds like his truck's power steering system actively commanded steering direction changes that were not the result of any steering inputs on his part. That is as close to "my truck tried to kill me" as I can think of. I get that a lot of people like to exaggerate, but if what he's saying is accurate and true, this was a seriously dangerous event.
mr.Magoo
2022 Lariat ER, AMB
This isn't just "power steering failure". I've driven a heavy car with a failed power steering rack.....
I'll let this be my last post on this topic before mods get tired of the ping pong.
It would be interesting if someone with actual knowledge into the design of active steering and it's fail safe mechanisms would care to comment.
I find it very unlikely that the forces involved to overpower active steering that's gone haywire would be higher than that of a failed power steering setup for the simple reason that they have to design things for when things go wrong, not if, and in those instances someone with a moderate build should still be able to control the vehicle. If not it would truly be a case of the vehicle "trying to kill them" and a gazillion dollar lawsuit waiting to happen and I find it equally unlikely that someone would be willing to take that risk thinking it'll never happen / fail.
ctuan13
Chuck
Pittsburgh, PA
A failed mechanical hydraulic power steering system almost always fails in the "unassisted" mode, meaning the pump fails which means there is no longer any fluid pressure to operate the rack or steering gear. This would present as very high steering effort at low speeds, while steering wheel feel at speed would feel pretty much normal as assist is pretty much disabled at high speed.
The rack on the Lightning however, and all 14th generation F150s, is an electric rack. This is an entirely different setup that uses an electric motor, position and force sensors and control module to determine steering direction and assist. If the module were to fail or the sensors were to malfunction, unlike the hydraulic system, it wouldn't simply default to no assist, it could suddenly command rapid steering input, even at highway speeds. This electric motor is capable of very high amounts of torque, which is needed to direct the steering rack under a heavy truck even when stationary. If it were to malfunction, and move against intentional steering inputs instead of with, it's quite capable of overpowering a person.
MontanaLightning
MontanaLightning
Montana
My preferred dealer 187 miles away is going to get the truck in ASAP and is going to loan me a Mach-E. I just need to trailer the truck over this weekend. I wish my local dealer was owned by my preferred dealer.
MontanaLightning
MontanaLightning
Montana
===SOBDMB DTC None===
Successful DTC reading, no error codes found
Module: SOBDM-B
===END SOBDMB DTC None===
===SOBDMC DTC P1A10:00-28===
Code: P1A10 - Hybrid Powertrain Control Module - Battery Disabled
Status (-28):
- Previously Set DTC - Not Present at Time of Request
- Malfunction Indicator Lamp is Off for this DTC
Module: Secondary OBD Control Module C
Freeze Frame #1:
-EVENT_TIME: 21520665 s (Sun Oct 15 14:38:25 2023) - Event time
-TOTAL_DISTANCE: 1345 miles - Total Distance
-MODULE_VOLTAGE: 8.5 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 51 °F - Outside temperature
===END SOBDMC DTC P1A10:00-28===
===SOBDMC DTC P291E:00-28===
Code: P291E - A/C Compressor 'B' Motor Voltage 'A' Low
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 21520675 s (Sun Oct 15 14:38:35 2023) - Event time
-MODULE_VOLTAGE: 8.8 V - Control Module Voltage
===END SOBDMC DTC P291E:00-28===
===SOBDMC DTC U0289:00-28===
Code: U0289 - Lost Communication With DC/AC Converter Control Module 'B'
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 21520738 s (Sun Oct 15 14:39:38 2023) - Event time
-MODULE_VOLTAGE: 9.0 V - Control Module Voltage
===END SOBDMC DTC U0289:00-28===
===BECM DTC U3003:16-28===
Code: U3003 - Battery Voltage
Additional Fault Symptom :)16):
- Circuit Voltage Below Threshold
Status (-28):
Module: Battery Energy Control Module
Freeze Frame #1:
-EVENT_TIME: 21520647 s (Sun Oct 15 14:38:07 2023) - Event time
-MODULE_VOLTAGE: 11.0 V - Control Module Voltage
-VSS: 0.0 mph - Vehicle Speed
-RPM: 0 1/min - Engine Revolutions Per Minute
-POWRPCK_STATE: Like KOEO - Power Pack NOT Available - Power Pack State
===END BECM DTC U3003:16-28===
===BECM DTC P2C85:1E-64===
Code: P2C85 - Hybrid/EV Battery Voltage External Isolation Fault
Additional Fault Symptom :)1E):
- Circuit Resistance Out Of Range
Status (-64):
- DTC Maturing - Intermittent at Time of Request
- Test not complete
===END BECM DTC P2C85:1E-64===
===BECM DTC U3003:A2-28===
Status (-28):
Freeze Frame #1:
===END BECM DTC U3003:A2-28===
===SOBDM DTC P0D28:00-68===
Code: P0D28 - Battery Charger 'A' Input Voltage Too High
Status (-68):
- Test not complete
Module: Secondary OBD Control Module A
Freeze Frame #1:
-EVENT_TIME: 20380383 s (Mon Oct 02 09:53:42 2023) - Event time
-TOTAL_DISTANCE: 702 miles - Total Distance
-MODULE_VOLTAGE: 12.5 V - Control Module Voltage
-INCAR_TEMPERATURE: 32 °F - In car temperature
-OUTDOOR_TEMPERATURE: 59 °F - Outside temperature
===END SOBDM DTC P0D28:00-68===
===SOBDM DTC U3003:16-28===
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 19769854 s (Mon Sep 25 08:18:13 2023) - Event time
-TOTAL_DISTANCE: 410 miles - Total Distance
-MODULE_VOLTAGE: 11.8 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 48 °F - Outside temperature
===END SOBDM DTC U3003:16-28===
===PCM DTC P0480:00-28===
Code: P0480 - Fan 1 Control Circuit
Status (-28):
Module: Powertrain Control Module
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: 21597715 s (Mon Oct 16 12:02:34 2023) - Event time
-TOTAL_DISTANCE: 1530 miles - Total Distance
-FUELSYS: error - Fuel System Status (Open/Closed Loop)
-ECT: 59 °F - Engine coolant temperature
-LONGFT1: -100.00 % - Long term fuel trim 1
-RUNTM: 58827 s - Time Since Engine Start
-RUNTM: 58827 s - Engine Run Time
-FLI: 0.00 % - Fuel Level
-BARO: 13.1 psi - Barometric pressure
-VPWR: 11.40 V - Control Module Voltage
-ECT2_SUP: Yes - Engine Coolant Temperature Sensor 1 supported
-ECT1_SUP: No - Engine Coolant Temperature Sensor 1 supported
-ECT1: 59 °F - Engine Coolant Temperature Sensor 1
-ECT2: 72 °F - Engine Coolant Temperature Sensor 2
-ECT2: 72 °F - Engine Coolant Temperature 2
===END PCM DTC P0480:00-28===
===PCM DTC P087F:00-28===
Code: P087F - One Pedal Drive System Performance
Status (-28):
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: 20767335 s (Fri Oct 06 21:22:54 2023) - Event time
-TOTAL_DISTANCE: 946 miles - Total Distance
-RUNTM: 657 s - Time Since Engine Start
-RUNTM: 657 s - Engine Run Time
-BARO: 13.2 psi - Barometric pressure
-VPWR: 14.17 V - Control Module Voltage
-ECT2: 181 °F - Engine Coolant Temperature Sensor 2
-ECT2: 181 °F - Engine Coolant Temperature 2
===END PCM DTC P087F:00-28===
===PCM DTC U0415:00-28===
Code: U0415 - Invalid Data Received from Anti-Lock Brake System (ABS) Control Module 'A'
Status (-28):
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: 21530357 s (Sun Oct 15 17:19:56 2023) - Event time
-TOTAL_DISTANCE: 1509 miles - Total Distance
-VSS: 0.6 mph - Vehicle Speed
-RUNTM: 52 s - Time Since Engine Start
-RUNTM: 52 s - Engine Run Time
-VPWR: 14.20 V - Control Module Voltage
-ECT2: 79 °F - Engine Coolant Temperature Sensor 2
-ECT2: 79 °F - Engine Coolant Temperature 2
===END PCM DTC U0415:00-28===
===PCM DTC U0554:00-28===
Code: U0554 - Invalid Data Received From Accessory Protocol Interface Module
Status (-28):
Freeze Frame #1:
Freeze Frame #2:
-EVENT_TIME: 21520683 s (Sun Oct 15 14:38:42 2023) - Event time
-RUNTM: 18 s - Time Since Engine Start
-RUNTM: 18 s - Engine Run Time
-BARO: 12.9 psi - Barometric pressure
-VPWR: 8.78 V - Control Module Voltage
-ECT2: 63 °F - Engine Coolant Temperature Sensor 2
-ECT2: 63 °F - Engine Coolant Temperature 2
===END PCM DTC U0554:00-28===
===OBDII DTC None===
Module: On Board Diagnostic II
===END OBDII DTC None===
===GFM2 DTC U3003:16-28===
Status (-28):
Module: Generic Function Module 2
Freeze Frame #1:
-EVENT_TIME: 21153850 s (Wed Oct 11 08:44:50 2023) - Event time
-TOTAL_DISTANCE: 1066 miles - Total Distance
-MODULE_VOLTAGE: 12.0 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 44 °F - Outside temperature
===END GFM2 DTC U3003:16-28===
===APIM DTC U3003:16-08===
Status (-08):
Module: Accessory Protocol Interface Module
===END APIM DTC U3003:16-08===
===ACCM DTC None===
Module: Air Conditioning Control Module
===END ACCM DTC None===
===SODR DTC None===
Module: Side Obstacle Detection Control Module - Right
===END SODR DTC None===
===SODL DTC None===
Module: Side Obstacle Detection Control Module - Left
===END SODL DTC None===
===CMR DTC B15E1:97-08===
Code: B15E1 - Driver Side LED
Additional Fault Symptom :)97):
- Component Or System Operation Obstructed Or Blocked
Status (-08):
Module: Camera Module Rear
===END CMR DTC B15E1:97-08===
===TRM DTC U0131:87-08===
Code: U0131 - Lost Communication With Power Steering Control Module 'A'
Additional Fault Symptom :)87):
- Missing Message
Status (-08):
Module: Trailer Module
===END TRM DTC U0131:87-08===
===DSP DTC U3003:16-08===
Status (-08):
Module: (Audio) Digital Signal Processing Module
===END DSP DTC U3003:16-08===
===RGTM DTC None===
Module: Rear Gate/Trunk Module
===END RGTM DTC None===
===OCS DTC None===
Module: Occupant Classification System Module
===END OCS DTC None===
===CCM DTC None===
Module: Cruise Control
===END CCM DTC None===
===ABS DTC U0420:00-28===
Code: U0420 - Invalid Data Received from Power Steering Control Module 'A'
Status (-28):
Module: Antilock braking system
Freeze Frame #1:
-EVENT_TIME: 14862247 s (Sun Jul 30 13:04:46 2023) - Event time
-TOTAL_DISTANCE: 192 miles - Total Distance
-MODULE_VOLTAGE: 14.5 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 91 °F - Outside temperature
-PWR_MODE_KEY: error - Power Mode Key State
-ECU_POWER_SUPPLY: 14.3 V - ECU Power Supply Voltage
-EDC#1: INACTIVE - Engine Drag Control
-BTCS: INACTIVE - Brake Traction Control System
-AYC: INACTIVE - Active Yaw Control
-ABS: INACTIVE - Antilock braking system
-TCS: INACTIVE - Traction control system
-BRK_F_P_R: 0.0 psi - Brake Fluid Line Hydraulic Pressure (Raw Value)
-IFC_D703: 288 - Internal Module Fail Code
Freeze Frame #2:
-EVENT_TIME: 21530337 s (Sun Oct 15 17:19:36 2023) - Event time
-MODULE_VOLTAGE: 13.5 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 66 °F - Outside temperature
-VEHICLE_SPEED: 29 mph - Vehicle Speed
-ECU_POWER_SUPPLY: 14.0 V - ECU Power Supply Voltage
===END ABS DTC U0420:00-28===
===ABS DTC U0131:00-28===
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 14862245 s (Sun Jul 30 13:04:44 2023) - Event time
-ECU_POWER_SUPPLY: 14.2 V - ECU Power Supply Voltage
-IFC_D703: 78 - Internal Module Fail Code
Freeze Frame #2:
-EVENT_TIME: 21598000 s (Mon Oct 16 12:07:19 2023) - Event time
-MODULE_VOLTAGE: 12.8 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 62 °F - Outside temperature
-ECU_POWER_SUPPLY: 12.6 V - ECU Power Supply Voltage
===END ABS DTC U0131:00-28===
===ABS DTC C0051:67-28===
Code: C0051 - Steering Wheel Position Sensor
Additional Fault Symptom :)67):
- Signal Incorrect After Event
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 21524073 s (Sun Oct 15 15:35:12 2023) - Event time
-TOTAL_DISTANCE: 1403 miles - Total Distance
-OUTDOOR_TEMPERATURE: 64 °F - Outside temperature
-VEHICLE_SPEED: 67 mph - Vehicle Speed
-ECU_POWER_SUPPLY: 12.2 V - ECU Power Supply Voltage
-IFC_D703: 167 - Internal Module Fail Code
Freeze Frame #2:
-EVENT_TIME: 21530346 s (Sun Oct 15 17:19:45 2023) - Event time
-VEHICLE_SPEED: 22 mph - Vehicle Speed
===END ABS DTC C0051:67-28===
===ABS DTC C0051:96-28===
Additional Fault Symptom :)96):
- Component Internal Failure
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 21524047 s (Sun Oct 15 15:34:46 2023) - Event time
-ECU_POWER_SUPPLY: 12.1 V - ECU Power Supply Voltage
-IFC_D703: 168 - Internal Module Fail Code
Freeze Frame #2:
===END ABS DTC C0051:96-28===
===ABS DTC U3003:16-68===
Status (-68):
- Test not complete
Freeze Frame #1:
-EVENT_TIME: 21520633 s (Sun Oct 15 14:37:52 2023) - Event time
-ECU_POWER_SUPPLY: 8.4 V - ECU Power Supply Voltage
-IFC_D703: 495 - Internal Module Fail Code
Freeze Frame #2:
-EVENT_TIME: 21520677 s (Sun Oct 15 14:38:36 2023) - Event time
-MODULE_VOLTAGE: 10.8 V - Control Module Voltage
-OUTDOOR_TEMPERATURE: 73 °F - Outside temperature
===END ABS DTC U3003:16-68===
===TCU DTC U0146:09-08===
Code: U0146 - Lost Communication With Serial Data Gateway 'A'
Additional Fault Symptom :)09):
- Component Failures
Status (-08):
Module: Telematic Control Unit Module
===END TCU DTC U0146:09-08===
===RTM DTC None===
Module: Radio Transceiver Module
===END RTM DTC None===
===PACM DTC None===
Module: Pedestrian Alert Control Module
===END PACM DTC None===
===DCDC DTC None===
Module: DC to DC Converter Control Module
===END DCDC DTC None===
===DSM DTC U3000:49-48===
Code: U3000 - Control Module
Additional Fault Symptom :)49):
- Internal Electronic Failure
Status (-48):
- Test not complete
Module: Driver's Seat Module
===END DSM DTC U3000:49-48===
===DSM DTC C1008:15-08===
Code: C1008 - Left Power Running Board Position/Motion Sensor
Additional Fault Symptom :)15):
- Circuit Short To Battery Or Open
Status (-08):
===END DSM DTC C1008:15-08===
===DSM DTC C1009:11-08===
Code: C1009 - Right Power Running Board Position/Motion Sensor
Additional Fault Symptom :)11):
- Circuit Short To Ground
Status (-08):
===END DSM DTC C1009:11-08===
===DSM DTC C1009:15-08===
Status (-08):
===END DSM DTC C1009:15-08===
===PDM DTC None===
Module: Passengers Door Control Unit
===END PDM DTC None===
===DDM DTC None===
Module: Drivers Door Module
===END DDM DTC None===
===RCM DTC U0131:00-08===
Status (-08):
Module: Restraint Control Module
Freeze Frame #1:
-EVENT_TIME: 21524532 s (Sun Oct 15 15:42:51 2023) - Event time
-TOTAL_DISTANCE: 1411 miles - Total Distance
Freeze Frame #2:
-EVENT_TIME: 21532033 s (Sun Oct 15 17:47:52 2023) - Event time
===END RCM DTC U0131:00-08===
===HCM DTC U3003:16-08===
Status (-08):
Module: Headlamp Control Module
Freeze Frame #1:
-ECU_POWER_SUPPLY: 8.7 V - ECU Power Supply Voltage
-EVENT_TIME: 167837034 s (Sun Jul 14 17:22:56 2024) - Event time
-HCM_DiagVehMde: 0 - Diagnostic Vehicle Mode
===END HCM DTC U3003:16-08===
===HCM DTC U0131:87-08===
- Missing Message
Status (-08):
Freeze Frame #1:
-ECU_POWER_SUPPLY: 13.1 V - ECU Power Supply Voltage
-EVENT_TIME: 85886289 s (Thu Dec 09 04:17:11 2021) - Event time
-HCM_DiagVehMde: 1 - Diagnostic Vehicle Mode
===END HCM DTC U0131:87-08===
===HCM DTC U0415:00-08===
Status (-08):
Freeze Frame #1:
-EVENT_TIME: 242224460 s (Sun Nov 22 15:33:22 2026) - Event time
===END HCM DTC U0415:00-08===
===HCM DTC U0420:00-08===
Status (-08):
Freeze Frame #1:
===END HCM DTC U0420:00-08===
===HVAC DTC None===
Module: Heating Ventilation Air Conditioning
===END HVAC DTC None===
===GSM DTC None===
Module: Gear Shift Module
===END GSM DTC None===
===RFA DTC None===
Module: Remote Function Actuator
===END RFA DTC None===
===PSCM DTC U3003:16-28===
Status (-28):
Module: Power Steering Control Module
Freeze Frame #1:
-STEER_ROT_SPD: 0 1/min - Steering Pinion Rotation Speed
-STEER_PIN_ANG: 116.80 ° - Steering Pinion Angle
-SSHFT_TQ_S2: 0.7 ft·lb - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: -0.40 ° - Steering Wheel Angle Alignment Offset
-ECU_POWER_SUPPLY: 14.6 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 80 °F - ECU Internal Temperature
-MOTOR_CURRENT: 0.80 A - Motor Current
-EVENT_TIME: 19897964 s (Tue Sep 26 19:53:23 2023) - Event time
-TOTAL_DISTANCE: 501 miles - Total Distance
-OUTDOOR_TEMPERATURE: 60 °F - Outside temperature
-VEHICLE_SPEED: 21 mph - Vehicle Speed
-IGN_CYCL_CNTR: 255 - DID EE03 Ignition Cycle Counter
-IGN_ON_TIME: 22000.00 ms - Ignition On Time
-FINAL_MTR_TOR: 0.0 ft·lb - Final Motor Torque
===END PSCM DTC U3003:16-28===
===PSCM DTC U3003:68-28===
Additional Fault Symptom :)68):
- Event Information
Status (-28):
Freeze Frame #1:
-STEER_PIN_ANG: 117.50 ° - Steering Pinion Angle
-SSHFT_TQ_S2: -0.1 ft·lb - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 2.10 ° - Steering Wheel Angle Alignment Offset
-ECU_POWER_SUPPLY: 9.8 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 60 °F - ECU Internal Temperature
-MOTOR_CURRENT: 25.10 A - Motor Current
-EVENT_TIME: 21520792 s (Sun Oct 15 14:40:31 2023) - Event time
-OUTDOOR_TEMPERATURE: 186 °F - Outside temperature
-IGN_CYCL_CNTR: 100 - DID EE03 Ignition Cycle Counter
-IGN_ON_TIME: 1000.00 ms - Ignition On Time
===END PSCM DTC U3003:68-28===
===PSCM DTC U3003:A2-28===
Status (-28):
Freeze Frame #1:
-ECU_POWER_SUPPLY: 9.9 V - ECU Power Supply Voltage
-MOTOR_CURRENT: 0.00 A - Motor Current
-EVENT_TIME: 21520793 s (Sun Oct 15 14:40:32 2023) - Event time
-IGN_ON_TIME: 2000.00 ms - Ignition On Time
===END PSCM DTC U3003:A2-28===
===PSCM DTC U3001:89-28===
Code: U3001 - Control Module Improper Shutdown Performance
Additional Fault Symptom :)89):
- Data Transfer Failure
Status (-28):
Freeze Frame #1:
-STEER_PIN_ANG: 117.00 ° - Steering Pinion Angle
-SSHFT_TQ_S2: 7.2 ft·lb - Steering Shaft Torque Sensor #2
-SW_ALIGN_OFSET: 0.00 ° - Steering Wheel Angle Alignment Offset
-ECU_POWER_SUPPLY: 13.0 V - ECU Power Supply Voltage
-ECU_INTERNAL_TEMPERATURE: 69 °F - ECU Internal Temperature
-VEHICLE_SPEED: 3 mph - Vehicle Speed
-IGN_CYCL_CNTR: 101 - DID EE03 Ignition Cycle Counter
-IGN_ON_TIME: 0.00 ms - Ignition On Time
===END PSCM DTC U3001:89-28===
===ACM DTC None===
Module: Audio Control Module
===END ACM DTC None===
===BdyCM DTC U0131:87-08===
- Missing Message
Status (-08):
Module: Body Control Module
===END BdyCM DTC U0131:87-08===
===WACM DTC U3003:16-08===
Status (-08):
Module: Wireless Accessory Charging Module
===END WACM DTC U3003:16-08===
===SCCM DTC None===
Module: Steering Column Control Module
===END SCCM DTC None===
===IPC DTC U0415:82-08===
Additional Fault Symptom :)82):
- Alive/Sequence Counter Incorrect/Not Updated
Status (-08):
Module: Instrument Panel Control Module
===END IPC DTC U0415:82-08===
===IPC DTC U0420:82-08===
Status (-08):
===END IPC DTC U0420:82-08===
===GWM DTC U053B:57-08===
Code: U053B - Invalid Data Received From Image Processing Module A
Additional Fault Symptom :)57):
- Invalid/Incompatible Software Component
Status (-08):
Module: Gateway Module A
===END GWM DTC U053B:57-08===
===GFM3_HS14229 DTC U3003:16-28===
Status (-28):
Module: Generic Function Module 3
===END GFM3_HS14229 DTC U3003:16-28===
===IPMA DTC U0131:00-28===
Status (-28):
Module: Image Processing Module A
===END IPMA DTC U0131:00-28===
===IPMA DTC U0420:86-28===
Additional Fault Symptom :)86):
- Signal Invalid
Status (-28):
Freeze Frame #1:
===END IPMA DTC U0420:86-28===
===IPMA DTC U0415:86-28===
- Signal Invalid
Status (-28):
Freeze Frame #1:
-OUTDOOR_TEMPERATURE: 86 °F - Outside temperature
===END IPMA DTC U0415:86-28===
===IPMA DTC B1385:68-28===
Code: B1385 - Lane Keeping Aid System
- Event Information
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 21280486 s (Thu Oct 12 19:55:25 2023) - Event time
-TOTAL_DISTANCE: 1273 miles - Total Distance
===END IPMA DTC B1385:68-28===
===IPMA DTC B1385:82-28===
Status (-28):
Freeze Frame #1:
-EVENT_TIME: 21018853 s (Mon Oct 09 19:14:52 2023) - Event time
-TOTAL_DISTANCE: 1017 miles - Total Distance
-OUTDOOR_TEMPERATURE: 57 °F - Outside temperature
===END IPMA DTC B1385:82-28===
===IPMA DTC U0565:86-28===
Code: U0565 - Invalid Data Received From Camera Module-Rear
- Signal Invalid
Status (-28):
===END IPMA DTC U0565:86-28===
===LDCMB DTC U3003:16-28===
Status (-28):
Module: Lighting Driver Control Module B
===END LDCMB DTC U3003:16-28===
===LDCMA DTC U3003:16-28===
Status (-28):
Module: Lighting Driver Control Module A
===END LDCMA DTC U3003:16-28===
===OBCC DTC P1A3C:00-68===
Code: P1A3C - Hybrid/EV Battery Charging Disabled - DC Charging Station Performance
Status (-68):
- Test not complete
Module: Off-Board Charger Control
===END OBCC DTC P1A3C:00-68===
===OBCC DTC U3003:16-28===
Status (-28):
===END OBCC DTC U3003:16-28===
===SODCMD DTC None===
Module: Side Obstacle Detection Control Module D
===END SODCMD DTC None===
===SODCMC DTC None===
Module: Side Obstacle Detection Control Module C
===END SODCMC DTC None===
===DCACA DTC B1655:08-28===
Code: B1655 - DC/AC Converter 'A' High Voltage Power Outlet Control Module 'G'
Additional Fault Symptom :)08):
- Bus Signal/Message Failures
Status (-28):
Module: DC / AC Converter Module A
===END DCACA DTC B1655:08-28===
===DCACA DTC U3003:16-28===
Status (-28):
===END DCACA DTC U3003:16-28===
===BCMC DTC U3003:16-08===
Status (-08):
Module: Body Control Module C
===END BCMC DTC U3003:16-08===
===BCMC DTC C0040:16-08===
Code: C0040 - Brake Pedal Switch 'A'
Status (-08):
===END BCMC DTC C0040:16-08===
===BCMC DTC B157A:16-08===
Code: B157A - Park By Wire Solenoid Output
Status (-08):
===END BCMC DTC B157A:16-08===
===BCMC DTC B157B:16-08===
Code: B157B - Park By Wire Motor Output
Status (-08):
===END BCMC DTC B157B:16-08===
===FHCM DTC U3003:16-08===
Status (-08):
Module: Front Hatch Control Module
===END FHCM DTC U3003:16-08===
===FHCM DTC B144D:49-08===
Code: B144D - Tailgate/Liftgate/Boot/Trunk Position Sensor 2
Status (-08):
===END FHCM DTC B144D:49-08===
===FHCM DTC B144E:49-08===
Code: B144E - Tailgate/Liftgate/Boot/Trunk Position Sensor 2
Status (-08):
===END FHCM DTC B144E:49-08===
===FHCM DTC B1219:15-08===
Code: B1219 - Interior Boot/Trunk Release Switch
Status (-08):
===END FHCM DTC B1219:15-08===
===FHCM DTC U2001:68-08===
Code: U2001 - Reduced System Function
- Event Information
Status (-08):
===END FHCM DTC U2001:68-08===
===ACCMB DTC P0562:00-08===
Code: P0562 - System Voltage Low
Status (-08):
Module: Air Conditioning Compressor Control Module B
===END ACCMB DTC P0562:00-08===
Gimme_my_MME
Did you install ANYTHING aftermarket? Tapped into the harness for power for something?
MontanaLightning
MontanaLightning
Montana
I haven't installed anything.
designthis
NYS
Builder
That smiley face emoji seems totally inappropriate.
MontanaLightning
MontanaLightning
Montana
It's posted straight from Forscan.
