Pre-Purchase Guidance and Thinking Points
97WhiteCobra
George
North Carolina
65 Mustang GT, 2010 F-150
SOME are made for continious heavy use, others are not. Make sure you have the right one.
A hard wired charger is better if you can. You may even be able to use that exact wiring (ensuring current is set correctly).
Thanks so much, this forum has been absolutely fantastic meeting all you guys. I think I’m at the point where I got everything I need to make the decision to do it. I have a dealership close to me that has a very large inventory of Lightenings that were leased vehicles. They are very low mileage and good warranty life left.
Thanks again for all the help.
97WhiteCobra
George
North Carolina
Hi everyone, I’m back. I haven’t been able to find a truck yet but I’ve come close several times. They get sold right out from under me. I think since Ford announced the Manufacturing stoppage it’s getting harder to get them.
I had a pretty strict list of things I wanted to get, but I wanted to ask the group what your thoughts are on the Max tow package, and is it worth holding out? It’s one of my requirements. I will be pulling an RV and I will be pulling a boat, but not all the time.
For folks that have it, or have had that option is it worth the weight? And does it actually help extend the battery life as well by keeping the battery cooler?
Are there any other benefits to other than just keeping the battery temperature cooled down to perform better under tow?
Firn
23 Pro ER
I wouldn't think of it as keeping the battery cooler, it would think of it as more power to cool the battery if it gets too hot.
Having monitored high speed charging i dont think the regular trucks are cooling limited there. And same with regular driving.
Regular towing big wide trailers up long hills, yes. But aside from that I wouldn't think the regular trucks are cooling limited for normal towing
97WhiteCobra
George
North Carolina
thank you. That’s helpful. I passed on a few without it. I do plan to do some traveling hauling a camper. Sounds like the option would be be needed for the most part unless I was hitting some more extreme mountains.
We've not had many reports of drive train overheating for trucks with or without MAX TOW option, if I were you, I'd hold out for the feature, better prepared than not.
97WhiteCobra
George
North Carolina
Will do, thank you, I have my local Ford dealer on the hunt. It’s been sort tough to find the right truck. We’ll get there.
97WhiteCobra
George
North Carolina
Hi folks, I had some really good feedback on this question, thanks again to help. I saw a guy at a charge station pulling a boat similar to mine and I stopped to ask his thoughts. He said the following, hill decent control and trailer brake controller is worth the wait. He boats a lot in western NC like me, and said he sold his first Lightening to get one with the option (plus he wanted the 9.6kw package) and he said it really helps.
Firn
23 Pro ER
Thats right. They moved the brake controller to max tow.
I dont think hill descent control has anything to do with towing though.
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
So the OE brake controller isn't a stand alone option on Lightning like it is with other Ford trucks? You HAVE to get the $1,200 Max Towing package?
If so that's stupid.
While I certainly wanted the Max Towing package (mainly for the rear locking differential) I ended up with a truck that doesn't have it and it's been fine for me. Not having it actually results in higher payload capacity, which in turn results in higher *realistic* towing capacity in many situations, and it also reduces a potential failure point by eliminating a cooling circuit. When I do tow heavy I just use my Curt Echo brake controller. No sweat.
97WhiteCobra
George
North Carolina
Thanks, it will be great if hill decent is standard, I’ll keep looking in to it and report back.
97WhiteCobra
George
North Carolina
I know I was pretty surprised as well. I like the point you make out of the potential higher payload and leverage a third party brake control system.
WXman
Central Kentucky
Yeah I mean ultimately the entire purpose of the Max Towing package is to add that additional cooling circuit to keep the battery pack and motors cool while towing heavy in the mountains. But if a guy with a non-Max Towing truck watches his gauges and has no temperature issues, there is no reason he can't tow just as much weight.
When I tow my 26' heavy duty enclosed trailer through the hills of Kentucky, I don't see any temperature rises at all with my truck. So I'm happy. Would I like the locking rear diff and OE brake controller? Sure. But there are advantages the other way too; my payload rating is over 2,000 lbs.
Firn
23 Pro ER
You can also buy the ford controller (and module) and add it if you want the fully integrated factory system. About $250 iirc and then it integrates with the center screen and you trailer settings.
IMO anything above a few thousand pounds should be using a brake controller. A quick google says anything over 3000lbs requires it.
I still don't understand why Ford cannot put the brake controller on Max Tow, OR tow tech, OR as a stand alone package. Previously if you got a truck with max tow but not tow tech you didn't get a controller, which is just insane IMO. This makes more sense but its still silly that its only on one package.
97WhiteCobra
George
North Carolina
Thanks for the option. That makes a lot of sense and a great Plan B if I can’t find a truck with the package. I agree the way they’ve got a package does not make sense at all.
Jonny Lightning
Jon
Kansas
2025 F-150 Lightning Latiat
HVAC
My 2025 Lariat ER has been at the dealership 3 times now due to them trying to get a brake controller to work. Ford says it won’t work but the dealer assured me they could do it. First trip they said they must have got a bad module from Ford (I don’t believe it) and the second time they “got a good module but the dash slider for the gain wasn’t good”. Now it’s back in for the third time and they still can’t make it work. I told them to forget it and put it back to factory settings and I’ll just get a Curt Bluetooth controller. Now they are having to work with Ford to get my computer back to factory settings. It has been an absolute nightmare.
I really want the OEM controller to be integrated into the truck but from all that I have read it just can’t be done without the Max Tow package…which is STUPID! Ford really started dropping the ball on needed features in 2024.
