Rotary Shifter Part Numbers
Dahveed
Salina, Kansas
2025 Ford F-150 Lightning Flash
I ordered a second version from the original supplier of these Manion Makes after he introduced a "finless" version of the binnacle, which I much prefer.
Taking inspiration from the OP, I hit mine with a few coats of sandable primer, then matte black paint, then matte clear with plenty of sanding along the way. This looks closer to factory than my first attempt using a satin clear to finish, which was much too glossy.
I wanted it to turn out nice and not look rough and unfinished. I am no painter by any means but I took my time and I'm pretty happy with the result.
Looks really good! Probably going to try this myself.
Bandit216
Alaska
Mach E GTPE, Lightning Lariat
I went with the @PolymerBuilt version referenced above, but I agree, yours looks nice.
wighty
NY
Is LX6Z-7P155-X the only motorized one with rubber? Any idea what vehicle it came from?
Shmoe
sounds like the bronco shifter.
wighty
NY
Seems most of the others were starting with P, and I haven't been able to pin down what exact trim it would be from to search for it. If I can't find it I guess I will get one without the motor since it is like $60-80 vs trying to get the new one that has the motor ($230ish).
Karlos
Karl
DFW & Kerrville Tx
Retired CPA, active pilot
I've installed PN# LJ9Z 7P155D Mach-e Rotary Shifter in my 2022 & 2023 Lariats and now getting a DTC for the GSM DTC P0929(77). I've updated all the modules with FDRS on the 2023 LER & thought that might fix it, but it's still showing up. How to fix ?
The Weatherman
South Central KY
The Mach-e shifters have been flagged here as having issues if installed in the Lightning. Your best bet will be from an Escape of the 2021-2023 time frame.
El Duderino
2025 Flash Job 1
I have an Escape shifter LX6P-7P155-ED that has worked flawlessly for 6 months until last night.
I am getting DTC U0103 code in the Secondary OBD Control Module B and
in the Gear Shift Module (GSM) I am getting
===GSM DTC U0100:87-AF===
Code: U0100 - Lost Communication With ECM/PCM A
Additional Fault Symptom :)87):
- Missing Message
Status (-AF):
- DTC Present at Time of Request
- Malfunction Indicator Lamp is On for this DTC
Module: Gear Shift Module
===END GSM DTC U0100:87-AF===
Clearing the DTC with Forscan doesn't fix the issue, the DTCs come right back.
Any ideas? I am confident it's an OEM Ford shifter:
Ford F-150 Lightning Rotary Shifter Part Numbers 1772916283698-lh
mr.Magoo
2022 Lariat ER, AMB
It's not like rotary shifter are immune to issues, and if they're bought used I'm sure it's even sketchier - doubt Ford specifically prints "replaced if dropped" on 'em for fun.
Karlos
Karl
DFW & Kerrville Tx
So there should NOT be any DTC's with a suitable replacement ?
Do you have to tell the truck you've changed the part ? VIA FDRS maybe ?
digitaldad
ABQ
2023 Lariat ER MaxTow
I've had mine in for some time, no FDRS/FORScan tinkering needed.
EDIT: Regarding DTCs, I went back to my original post when I installed: I only had DTCs when I started truck without any shifter installed, and then when I installed rotary...but I hadnt securely seated the connector (slider-lock) correctly/fully.
The Weatherman
South Central KY
Nope.
Plug and play.
El Duderino
2025 Flash Job 1
Update:
I re-installed the original Lightning shifter and the DTCs went away on their own...
Then I unplugged the original shifter and plugged in the dial shifter... Drum rolll... No DTCs...
Maybe the CANbus message stays flagged until it sees a new shifter module by some unique identifier?
I didn't just unplug the dial shifter and then plug it back in. I should have done that first.
I am taking a J1939 protocol training this week, maybe I will be able to answer my own question in a few days...
