✅ 7/25 Lightning Build Week Group
Farmford42
WA
69 Bronco
Farmer
Log onto your personal ORDER page, verify the build week has not been pushed back to August or September. Can I get your 4-digit ORDER number? (DM if you prefer)
I am still in the 7/25 week and saw a window sticker it now says 110/241 but dont know all the codes.
broncoaz
Cape Cod, MA
Ford F-150 Lightning ✅ 7/25 Lightning Build Week Group 7C0F17E9-E781-48C9-BE0F-ED042C7DF2DC
Mine says “in production” and week of 7/25, but I found a window sticker with a blend date of 7/13 when I looked yesterday.
Actually, your BLEND DATE is 7/25/2022 [20220725] over the word BLEND
(Which coincidently is the first day of production for that build week)
The 07-13-22 is the day they selected you in previewing this past Wednesday, it's also referred to as the invoicing day on the ORDERTRACK.APP site
Ford F-150 Lightning ✅ 7/25 Lightning Build Week Group 1657938571832
Ford F-150 Lightning ✅ 7/25 Lightning Build Week Group 1657938606557
broncoaz
Cape Cod, MA
Sorry, I was going off memory from my Bronco’s build process last November.
Galactus55
Gus
Ontario - Canada
BLEND Date 07/29/2022
505 of 627
GrokTime
Sean
Ithaca, NY
2022 F150 Lightning, Rivian R1S 1st Gen
I just checked and I have a window sticker as well. I am new to analyzing window stickers! I believe I have a blend date of 7/28. What else should I be checking on the window sticker?
Ford F-150 Lightning ✅ 7/25 Lightning Build Week Group 1658086073084
Ford F-150 Lightning ✅ 7/25 Lightning Build Week Group 1658086099910
Ken
Ken
Monterey
Lightning Lariat ER
My window sticker has my blend date as 7/26 . Ramp says CU84 and Convoy. Have no idea what the other codes mean. Where is this order to blend number? VIn is GO9XXX
great spreadsheet TaxmanHog, might be worth adding another column for blend to delivery, instead of having to add up the four columns. Looks like the shortest that's happening is about 30 days right now
Thank you for the blend date, I posted it to the sheet, now you will see a 173 days from your order date to the 7/26 blend day. As your build progresses, mention the action dates in this thread and I'll update as we go, good luck on a smooth build & delivery!!!
Ford F-150 Lightning ✅ 7/25 Lightning Build Week Group 1658142039518
Yes, I've considered that metric, just a matter of another column and simply subtracting the order to blend (idle time waiting) from the Order to Delivery value resulting in the elapsed time of active production & delivery.
Until I make the changes, a quick way to sum the production times is highlight the cells, then look at the lower right, the google sheet will apply a calculation (Sum, Avg, min, max, count) it's selectable based to type of data selected
Ford F-150 Lightning ✅ 7/25 Lightning Build Week Group 1658142579529
Added "Total P & D Days" which is the total of all days in active production and delivery phases.
Included a conditional format cell color fill of green for low values graduating toward red for higher values.
Adjusted column headers to affirm the values are "days" of an activity
Ford F-150 Lightning ✅ 7/25 Lightning Build Week Group 1658144159040
JLee
NJ
2022 Lariat ER, 2015 Mustang GT, 2005 GX470
