Diesel heater(new video of it running)
Dylanch
Dylan
Maple creek
F150
Some people might be butt hurt but whatever.
Can't wait for cold weather testing.
Doesn't get extremely hot in the cab which is ok. But to midly heat the cab and only uses 12watts I'm ok with that
It's not really ment for this but with a bit more tweaking I think it will be perfect
Right now everything is temporarily installed. Wasn't sure if it would freak out or not. Wanted it easily removable waiting for a check valve to stop reverse flow
Drove 140km in -2celcius weather and i had to turn it down because it was to warm. We will see at 30 below
Ford F-150 Lightning Diesel heater(new video of it running) 20221028_161546
Ford F-150 Lightning Diesel heater(new video of it running) 20221028_161558
Ford F-150 Lightning Diesel heater(new video of it running) 20221028_161535
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
I'd do the same but I'm spoiled here in socal. Cool project.
lightspeed
2023 Lightning Lariat ER
Whoa I suggested in another thread that Ford could add a fuel heater for extremely cold weather. I never thought someone would be crazy enough to do it though!
Did you build it into the hot water loop of the truck? I don't understand from the pictures how the heat gets into the cab.
Dylanch
Dylan
Maple creek
F150
Sure did it's plummed into the heater core. So I just use the fan like normal and out comes hot air
I can't believe someone would do this to their Lightning. Ford tested in cold environments. This is a really bad idea.
Not "butt hurt", just amazed that someone would do this without even determining the need (there isn't one).
3rdgenfan
Geoff
Delaware
Cybersecurity
You could have saved a bunch of time and money and bought a Powerboost instead.
I mean...this kind of solves the issue of range degradation in the winter months, while sipping on the fuel and giving you close to normal battery range, no?
Buying a Powerboost would only benefit OP in the winter and come Spring/Summer/Fall would be back to paying an arm and a leg to fuel it.
Try running your truck in winter with no cabin heat at all. You still wont get anywhere near the rated range. Cabin heat is a relatively small portion of winter range degradation.
3rdgenfan
Geoff
Delaware
Cybersecurity
I mean I did it in my Bolt and for that particular car, running the heat on my commute made a big change. Without HVAC running it went back up to my average in the coldest part of winter ?‍♂
Additionally if he is up in Saskatchewan I would say anything would help in limiting the range. There is only so much that preconditioning can do.
I’ve heard that before regarding Bolts.
My Mach-E doesn’t behave that way. I get 290-300 all summer. In single digit temps, around 200 give or take whether using either E Heat or heated seats only.
Dylanch
Dylan
Maple creek
F150
Speak for yourself iv had an ev for 5 yrs now and I know the impact cold can have.
