$500 for Mobile Power Cord?
starrtech2000
Colorado
23 Lightning Lariat ER 511a
Just noticing a $500 charge for a mobile power cord on the window sticker of a 23 Lariat ER I’m looking at. Is this normal? I thought these included a power cord AND an 80amp wall charger at no extra charge.
Ford F-150 Lightning $500 for Mobile Power Cord? IMG_6666
Lucky26
I think they pulled it out with the pricing change. It’s pretty useless to me so I pulled it out of my build. I can always get a third party one later or use points and the current accessories 15% discount to get it.
davehu
hot springs, AR
was optional on my Lariat ordered Dec 2022. I have one but doubt if it will ever be used. consider it like a spare tire. expensive but when you need it... well, you need it.
carys98
Cary
Raleigh, NC
2023 Lightning Lariat SR
Retired EE
Standard on ‘22s, option on ‘23s.
Amps
Bolt
Just say, "No" if it's not too late. There are much better mobile options available, especially ones that have selectable power outputs. If you're using a mobile, you need options under 240V/30A. It's a shame there are probably some trucks being delivered where that $500 option on the sticker could net out to $8000.
That truck will also come with the 80A FCSP as well, shipped later from SunRun if you buy this dealer stock truck.
starrtech2000
Colorado
Lame.
I didn’t custom order it. Buying a dealer order.
Lame.
It is what it is. I wouldn’t let this stop me from buying the truck if I’m good with everything also.
starrtech2000
Colorado
Yeah, I won't. It's just $500 that I'd rather put towards a bed liner or other accessory. I have a mobile charger I can use already.
rdr854
Northern Virginia
I found my mobile charger to be quite useful while I waited for my charge station pro to be installEd. Unfortunately, the installs was delayed because the original charger arrived damaged in shipping. Now, I keep it in my Frunk in case I am somewhere where I need a charge and there is not a nearby charge station.
So, the question is: Would I order the mobile charger if I was ordering a 23 or 24? Answer: Yes.
starrtech2000
Colorado
already have a home charger (ChargePoint) and I’ve literally never used my mobile charger in 2 years of EV ownership other than than to see if it worked once.
Danface
Dan
Central Mass
2023 Lightning XLT
That's what I did, figured I'd put the $500 towards the $900 Pro Charger I got on Craigslist
ScubaSteve_TheReal
Steve
Midwest USA
Derivatives
Mine was already on my 23 when I bought my lightning from dealer lot in January. Yes it was a $500 line item ad on sticker as shown. I do use it daily and it suits my needs just fine and is covered by my trucks warranty if ever needed.
cdherman
Kansas City
RAV4 Prime, 2016 Leaf
As others have noted, there are better options out there, for less money. The 30A charger needs at least a 40A circuit to run. So a 30A dryer outlet is technically not sufficient, and the stupid Ford mobile EVSE does not have the option to select a lower amperage. If you do need a portable EVSE there are lots of better choices.
I own a similar one to this one that I am linking to. Current amazon price is under $200
Vevor from Amazon
jthiesse13
Phoenix
2023 Lightning
I've got one brand new I'll sell you for half that
