Unlock additional horsepower on Standard battery through Forescan?
iam7foot1
JP
Lake Tahoe, CA
22 Mustang Mach E GT PE & 23 Lightning XLT SR
Retired Tech
I'm wondering if it's possible to unlock the additional extended battery horsepower on the standard range Lightning through FORScan since it's clearly just a software setting.
FORScan. Not like foreskin...
And no, you can't do that.
ZSC100
Zach
Tulsa, OK
Electrical Engineer
The less horsepower comes almost directly from the voltage decrease of the pack size difference of 100/131.
My impression is that the voltages are the same, but the smaller battery cannot supply as much current?
Pack structure design
Module composition
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Module composition
Yep as you can see in this video nominal voltage for the SR pack is
8modules*3.7V*5P11S + 1module*3.7V*5P8S = 355V
ER pack is:
11modules*3.7V*5P11S + 1module*3.7V*5P8S = 477V
Both are still 400V class EV batteries. Both still supply the same motor dives, the difference is more power (wattage/horesepower) can be extracted per the same conservative limitations on the ER battery. I'd venture to say the only difference in an ER and SR performance wise has all to do with the battery (BECM) You can't tell a SR BECM that it's an ER BECM via software, Literally 3 modules are missing :(
