Copied from the Mach-E forum:
SSM 52039 2021-2023 Mustang Mach-E, 2022-2023 F-150 Lightning/E-Transit - Unable To Achieve 100 Percent State Of Charge After HV Battery Module Replacement
Some 2021-2023 Mustang Mach-E, 2022-2023 F-150 Lightning/e-Transit vehicles may exhibit a concern where the vehicle is unable to achieve 100 percent state of charge immediately after high voltage (HV) battery module balancing and replacement. This may be due to the battery energy control module (BECM) adjusting the cell balance (conditioning) of the battery module and should be corrected within 22 days. If the vehicle otherwise functions as designed with no related diagnostic trouble codes (DTC) setting, this concern will be corrected automatically with no further actions required by the technician.
----End SSM----
When a cell module in the battery is replaced, it has to have a similar voltage to the rest of the pack so the cells can all work in unison. However, the voltage in the new module may be close but not exactly the same immediately after replacement, which could cause a reduced battery capacity indication. The cell balancing system will work over time to correct the voltage imbalance, which can take up to 22 days.
Effects on % display may also be seen if you suddenly change your usual charge level (e.g. always charged to 50%, but now charge to 90%) or if your vehicle is brand new and has not been fully charged previously. Continue to drive and charge the vehicle normally to the same % level for 2-3 weeks and the fluctuating % behavior should decrease. Temperature effects may also cause a 1% variation when driving starts, this is normal since battery capacity changes due to temperature (pack has changed temp since charging finished).
Good to know this, a few members returned their trucks with similar symptoms with buy-back and or lemon procedures, had they known this it might have worked out in the end.
Reactions: cal
cal
Cal
Battle Ground WA
2022 Lightning, Tesla Model S Plaid
Please report back on your experience. Would like to hear real owner stuff.
If you’re referring to me, I won’t experience this (at least not yet). 23B57 completed, no module replacement required.
22 days. Where the hell does that come from?
Mine is in today getting the update, we shall see.
sstevetx
Steve
This is good info to know. Luckily, I didn't have this issue after my battery module replacement.
Quantum
Banned
Banned
Banned
Washington State / Malibu
2026 SEV TB ER
Accredited Investor
Who was able to get a buy back or lemon procedure processed?
I don't recall specifically who, it's likely they are no longer following the forum to help jog my memory
Hoping @MickeyAO checks out this thread, he could give us a primer on cell balancing processes in a pack.
Quantum
Banned
Banned
Banned
2026 SEV TB ER
Accredited Investor
So you're claiming they got a buy back with the latest battery module CSP - or were they one of the 18 or so with faulty batteries early this year?
One that stands out had a faulty battery, brought in for repair process, it was completed, but afterward the truck failed to perform as should have, especially concerning was the charging rate was substantially slower afterward.
The dealer was not able to resolve the issues and the member gave up on the truck, he lost trust and faith and frustration with the delays while they dickered around with trying to get the truck working properly.
I've read several folks relay in various threads where they Ford Tech's have had to contact engineering to give them a revised code for the balancing tool to get the operation to working properly!!
I fear some techs gave up, not being persistent and gaining tech support from the factory to properly complete the balancing process, leaving this and other customers with super delayed or half-done repairs.
It seems, that this 3 week internal self balancing process might have helped in some cases or maybe not, mere speculation at this point.
Still curious to hear Micky's take on slapping together a incorrectly balanced (replacement) module into the mix of other existing modules within the pack and relying on internal processes to slowly bleed down the imbalances.
Bigbuckhunter71
Steve
South Jersey
2023 LIGHTNING Pro
My truck is in the service department for program 23B50 ,they said there are parts that need to be installed by the dealership.
They scheduled me 3 weeks ago cause they didn't have the parts.
I will give update when I get truck back tomorrow, let you know if they needed to install a new module.
My rear passenger seat belt latch took a crap and they are replacing that also.
Quantum
Banned
Banned
Banned
2026 SEV TB ER
Accredited Investor
Thank you - is this the CSP you refer to? I had a battery module replaced 10 days ago & have been unable to charge to 320 miles now in my ER even after a reset of driving history right before the Level 1 charge in my garage - that seems related to the postings here.
This TSB relates to not being able to charge to 100%. It has nothing to do with miles showing on the GOM (which is not worth looking at, IMO).
