2024 Lightning availability
Nomoregas
Nomoregas
Scott
Toronto
2022 Ford Lightning
hoping i can trade my 2022 in this year for a 24, little worried the dealers don't want them but maybe moving a new truck is enough incentive to take it in on trade.
Nomoregas
Nomoregas
Scott
Toronto
2022 Ford Lightning
ER trucks will only have one onboard charger [11 KW], this will lengthen the time to charge ER's
please explain this one onboard charger, I did not think we had onboard chargers mine is in the garage it is a chargepoint my truck is 2022 er
Oafy44
Georgia
23 ford lightning
Landscape contractor
Not 24’s since they aren’t even out yet but my dealer has 23 platinums for 12k off . you will take a bath on your trade in but maybe with $12k it’s worth it.
MickeyAO
Mickey
San Antonio Tx
You have an EVSE (Electric Vehicle Servicing Equipment) in the garage. It only provides AC power to the OBC (On Board Charger) located on the vehicle that converts the AC current to DC that the HVB uses.
The original ERs had 2 9.6 kW OBCs that could provide 80 A to the battery pack. A single 11 kW OBC can only deliver 45 A.
Doesn't matter to me, as my wife's EV6 and my ER share a single 9.6 kW EVSE.
Oafy44
Georgia
23 ford lightning
What happens if you have a 80 amp and buy a 24 or 25? Do we have to set our 80 amp to a lower setting or will our truck just charge at the highest speed it can?
The truck will handle it. The vehicle always determines the charge rate up the max communicated by the EVSE.
Nomoregas
Nomoregas
Scott
Toronto
2022 Ford Lightning
i did not realize the charger is in the truck I really thunked that box on the wall was the charger so thanks for that. It seems that one complaint is speed of charging the truck so that seems to be the reverse of progress with these trucks.
erproco
Colorado
2024 F150 Lightning Pro ER
oh really? so no more 80 amp home charging on any models?
80 Amp charging remains available for 24 Fleet ER only, Pro and Flash. Its a standalone option code 99M. I have one on order, and this restriction sealed the deal for my Trim decision.
LazyLightningATX
Doug
Austin
'23 Lariat ER
Wonder if they found out a lot of people weren't installing at full power (100 amp breaker is pretty large)...I could only spare a 60 amp breaker where I installed my charge station pro (my moms house). My house only has room for 30 amp, so I just kept my mobile charger from my Tesla and bought an adapter.
Zaptor
2022 Lightning Lariat ER ZAPTOR 2025 MME GT RALLY HABOOB Kubota L3560 Goats wut
.......... Trophy husband
Thanks for the update, I started using Autotrader.com to glean through dealer stock orders, so far I've captured the following, still looking for build week 1/15 which was selected on the 4th or 5th of January.
Ford F-150 Lightning 2024 Lightning availability 1704988336158
kknoedle
Karl
Ashburn, VA
I have tried through 4 different dealers in my area (Northern Virginia) to order a 24 Flash since 1 Jan, and all of them are saying that the Flash is already allocated out for the entire MY? All builds are already spoken for, and they are not even available yet on the Ford.com configuration tool?
