Ice, not ICE; not nice.
SmoothJ
New Jersey
2022 F150 Lightning
Charge door winter cover? You mean an old towel? I'll ship you one for half the price :D
https://accessories.ford.com/f-150-2023-charge-port-weather-kit-for-bev-lightning-only
If your truck will fit thru the garage door opening, and you disconnect the opener and open the door manually will the truck fit inside? Maybe you only need a new opener....
Sorry, I just couldn't resist...
Its not the opener, its the L shaped or even J shaped bracket that attaches the opener to the door. Closed is not a big deal, but when its open it will hit the roof of the truck.
Not my picture but close enough.
Ford F-150 Lightning Ice, not ICE; not nice. C8A33009-B460-4A65-B010-80846B9ADE43
mr.Magoo
2022 Lariat ER, AMB
Would it clear the opening?
Is so wouldn't a direct drive opener be an option ?
They attach to the bar/shaft and you can get rid of the whole overhead pull mechanism.
https://www.homedepot.com/p/Chamber...-Backup-and-Wi-Fi-Connection-RJO101/325675581
Lift master has the same? unit as well with their branding.
The Weatherman
Dean
South Central KY
They’re not cheap, but you might consider a side mounted opener that doesn’t use the rails or connector you are having issue with.
They mount at the top of door connected to the spring rod.
The Weatherman
Dean
South Central KY
What @mr.Magoo said. (I’ve got to learn how to type faster on this dang phone!)
SmoothJ
New Jersey
2022 F150 Lightning
I might look into that. According to the last home owner, I have "special" garage doors so I need to check compatibility and etc.
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
I believe those openers are called "jack shaft opener". They look to attach to our existing door shaft.
Bwanapete
Peter
Cazenovia, NY
2022 Lightning, 2023 Tesla MY, 1941 Lincoln V12
The J attachment piece might be able to be shortened. I had 10’ door and a 9’8” rv. I just sawed off part of the J so as to maintain 10’ under the J.
VTbuckeye
Vermont
Could you move the attachment closer to one side or the other? I moved my garage door opener and its attachment over so that instead of being in the center it is 1/3 of the way to one side (to accommodate the roof box in my Volvo). With the roof box the car clears the opening by about an inch (maybe less).
cdherman
Kansas City
RAV4 Prime, 2016 Leaf
I will say -- we are all early adopters and we will suffer the consequences on occasion. ICE vehicles, especially top dollar ones, have had 100 years or so to get every detail right. We are spoiled. All that waste heat from the ICE engine has been kind of taken for granted. Of course, it was truly wasted most of the time -- except in the winter etc......
Anyone who suggests Ford should have produced a perfect truck in the first iteration is asking for too much IMO. But there are reasons to be on the cutting edge -- cheaper operating costs if you don't sell the truck anytime soon (otherwise rapid depreciation will eat your rewards).
And.. I think the science behind global warming is real. We are going to have to address this. Even if we fall short of the goals that the crazies say we must achieve, just slowing down the RATE of change helps people, economies, and the environment adapt.....
End rant
USA EV
Yeah, with cabin preconditioning the ice melted off the windshield, but resolidified on the wiper armatures. Everything not touching the cabin never melts because there is no engine producing waste heat.
biers
Thomas
SW Washington
2022 Pro SR upgraded to ER
Battled the Portland area ice storm this week too. Two issues.
1. Tailgate lock froze.
2. Truck slid down the driveway. Very glad it wasn’t plugged in at the time.
Ford F-150 Lightning Ice, not ICE; not nice. IMG_2606
Bwanapete
Peter
Cazenovia, NY
Never had trouble opening the flap to fuel my former vehicles, mostly Fords. There really is no getting around the fact that the Lightning chargeport door is engineering malpractice. Before my Lightning I never needed a heat gun to fuel a car, and I have always lived around here and always kept my vehicles outside, for almost 6 decades.
roadhouse
F150 Lightning Lariat ER
The only issue I had the other morning was that the cowling below the windshield (where the wiper arms sit) formed a giant block of ice, locking the wipers from rotating. Leaving the defrost on max for 20 mins loosened it (just) enough that I was able to use a scraper to lever the ice out.
Ishkatan
Adam
Monrovia, Md
2023 F150 Lightning Lariat ER =RAe (Range Anxiety)
Old
I'm aware of what it is, just seems silly when the dog towel will do the same job.
Seems like they should simply include that as part of the vehicle. Charging $95 for a fix to a poor design insults the customer.
And do they have a fix for the tail gate freezing closed? Mine won't open despite hard tugging at the clamp holes but I get a tailgate ajar warning.
BTW, if you tug or push hard enough, the top of the tail gate flexes, so be careful.
