EA Plug & Charge disappeared in Fordpass [resolved]
DiveMan911
R.J.
Maui, HI
'06 Acura TL, '13 Ford Escape
Flight Nurse
Not sure when it happened…maybe with the Supercharger update or maybe when my dealer factory reset the truck…but EA is no longer listed in Plug & Charge. It was there previously and worked…but now only Tesla is there.
Ford F-150 Lightning EA Plug & Charge disappeared in Fordpass [resolved] IMG_4453
I’ve checked everything I can think of, but clearly I’m missing something.
Anyone else have this issue? Any other insight from you wizards out there?
I'm still seeing both, v-4.33.0
Ford F-150 Lightning EA Plug & Charge disappeared in Fordpass [resolved] 1709925705315
Factory reset the truck? That’s probably the trigger here, not the update. Assuming you reconnected to all the services, give it a day or two to resync with the mothership.
DiveMan911
DiveMan911
R.J.
Maui, HI
Flight Nurse
I’m on SW version 4.33.
I do agree the factory reset is the likely culprit, especially since no one else seems to be having this issue.
I have turned plug & charge off, and then back on…but I am going to leave it off for 24hrs today…give it a little extra time to reset itself.
I have reconnected all the services…and it’s been well over a week and still no dice.
Schroederhc1
Cordell
Wenatchee WA
2023 Lightning XLT ER, 1990 911 Targa
Self Employed
Delete the app and reinstall?
lightspeed
2023 Lightning Lariat ER
I noticed some quirkiness, but if EA is already selected it doesn't appear in the list. OR try deselecting Tesla and/or turning off plug-n-charge and they will both come back.
But really, if you have plug-n-charge selected, you don't need to select any specific network because it will automatically already be Tesla and EA only.
I'm curious to see how your charging experience with the P&C feature is affected, how long before you have an adapter?
DiveMan911
DiveMan911
R.J.
Maui, HI
Flight Nurse
I don't do a lot of DCFC, but we have a couple long distance trips planned this summer. So, I actually don't know yet how it is affected. I may end up going to an EA station in town just to see. Before it was removed from the app it worked well. On the Tesla side...I am on the schedule for a June arrival for the adapter.
Liked your suggestion. Tried it...no dice.
DiveMan911
DiveMan911
R.J.
Maui, HI
Flight Nurse
I did try deselecting Tesla in addition to turning off plug & charge. EA just never shows up anymore.
Puffoluffagus
Tyler
Georgia
23 Lariat ER
I don't have it on mine either.
I also don't have charge assist that is so frequently mentioned on this forum as well. So who knows. I don't d/c fast charge that often. The one time I tried plug and charge early on in my ownership, I couldn't get it to work and just went through the EA app instead.
Labs4Lightning
C
@DiveMan911
same here.
tried all: delete reinstall. Turn off & on. Turn off, wait a day, turn it back on.
guess I’ll just use ea app until it return.
DiveMan911
DiveMan911
R.J.
Maui, HI
Flight Nurse
@DiveMan911
same here.
hmmm...I may have to call the Ford Pass Customer service team on Monday. Wish me luck.
lightspeed
Just clear all the filters and accept it, and then go back in a select plug-n-charge. You should see Tesla and EA in the networks section. But you don't really need them unless you specifically want just one for some reason. I'm using iOS. It might act differently on android.
DiveMan911
DiveMan911
R.J.
Maui, HI
Flight Nurse
Found the fix. I had to unenroll/cancel the Blue Oval Charging Network subscription and reactivate it. That fixed it.
Thank you all!
