Is this crack around the charge port normal?
Maineiac12
Iowa
I just noticed this small crack in the seal around the charge port. Is this normal? Or do I need to call the dealer?
Ford F-150 Lightning Is this crack around the charge port normal? IMG_4032
Ford F-150 Lightning Is this crack around the charge port normal? IMG_4033
that 'piece' the nick is within just looks like a surrounding 'mounting part' that is where the charge port, itself, is mounted into... there's no 'electricity' associated with it. The charge port is really just a placeholder for the 'outlet' that you plug your J1772 or CCS plug into.
Looks damaged to me, I can check mine when I leave work but I'm inclined to agree that it is not normal. Did you recently take delivery?
Maineiac12
Iowa
No, but my charge port was recently replaced under warranty.
That's a cut IMO, not a crack. It doesn't belong.
That said, some black caulk and it's fine.
Whammy Bar
Fuck that. Let them replace it a second time with one without a crack.
jimfigler
Orchard park, NY
Yep it looks like a cut not a crack. Probably cut the other one out and went too far.
Definitely cut. If it were me, it would bother me and I'd want the dealership to fix it but I also wouldn't want to deal with the dealership more than I had too so I'd sit on it a few days to see if I forgot about it.
