Oil used in motor/axle/differential assembly
JHC283
Josh
2024 F150 Lightning Flash
Farmer
What type and viscosity of oil is used in the differential assembly on these trucks? I looked online and in the manual. I’ve seen some recommended service intervals (90,000) but no more information on it. Anyone know or can point me in the right direction? Thanks
The 2023 manual says 10 years/150K miles.
The fluid spec isn’t shown.
Shop / Service manual
Ford F-150 Lightning Oil used in motor/axle/differential assembly 1737433393380-u9
Ford F-150 Lightning Oil used in motor/axle/differential assembly 1737468768180-87
marc_hanna
Marc
Nova Scotia
'23 Lightning Lariat ER; '25 Tesla Model 3; '16 Porsche Macan S; '87 MB 560SL
Here's the spec sheet for the Mercon ULV:
Ford F-150 Lightning Oil used in motor/axle/differential assembly Screenshot 2025-01-21 at 9.24.18 AM
21st Century Truck
Martin
I recall (likely correctly but it's been a while) that Mercon was also the fluid used in my 2022 Ford Mustang Mach E, in its AWD motors.
From the owners manual, shop manual, or other? Just curious.
thanks!
Updated post four with that information and a snapshot of the volume needed for the front motor.
I <3 My Lightning
Note the pour point temp... I speculate this is why the motor temp gauge doesn't really deviate from middle as seen with the excellent work by TaxmanHog, who's purposely cold soaking his ride. As others have also noted at even much lower temps the same lack of motor temp gauge deviation.
