Battery Preconditioning.
Iroc34a
Iroc34a
Roc
23 Lightning Platinum
Mechanic for American Airlines. GSE (ground equipment) 38 years. Worked on everything from Lawn mowers to Boeing 747's.
Well, at work last night I plugged in the level 1 evse to a generator that happened to be in for a pm check. It was on charge for 6 hours. And going by just the gage, it didn't warm the battery at all. It was 1° last night. So. Maybe with a monitor it went up a couple degrees, but on the dash gage couldn't see any movement.
TMND
usa
Lightning
ag
L1 will only keep just above lower line in my experience.
jlferg0509
Dayton
2015 Chevrolet Malibu; 2023 Ford F-150 Lightning
I apologize if this has already been addressed in this thread, but my question is... If the only way we currently have to precondition the battery for charging is through navigating to a DCFC and I decide NOT to purchase a third rate product (the Ford navigation).
How will I precondition my battery in the future?
Possible answer: Ford, give us a way to manually precondition our battery for charging.
Ragman
From watching the different trucks on everything from L1 to FCSP this past month of arctic cold - the L1 does keep battery at low end of Blue on the 23s. If you have access to a 120 follow the always be charging mantra in winter.
I call out year as 24s have different battery logic then 23s. In Fordpass on the 23s once charged they show 0 charging rate and other then programmed departure times I never see unscheduled messaging for conditioning. However batteries are staying in blue as long as plugged so some heating is occuring.
On the 24s at full charge it continuously shows the <1kw so trucks are constantly pulling a small amount and regularly show unscheduled conditioning.
This is all at -35C /-20 F exterior temps. Either due to heat pumps operation or Ford has become more battery pack protective but the 24s definitely heat more and more often.
My 2022 does spontaneous battery conditioning at the command of the BMS, several times this week it's been around the 6 to 7 am time frame when it's coldest. When this happens Fordpass displays that the cabin & battery are being prepared.
Sunday afternoon charging session for 13 kWh, put a lot of heat in the pack, so there was no need to add more heat early or late Monday, the power output limiter was still at 100%
Then early Tuesday a little after 2 am it did a 2 kWh warming session, that afternoon another when I plugged in for the night, another 2 kWh.
Ford F-150 Lightning Battery Preconditioning. 1740147404558-sy
Ford F-150 Lightning Battery Preconditioning. 1740147430975-57
Wednesday morning 4 to 5 am another brief session pulling 1.9 kWh
Ford F-150 Lightning Battery Preconditioning. 1740147485788-gd
Thursday early morning it called for 2.1 kWh around 6:30 am timeframe
Ford F-150 Lightning Battery Preconditioning. 1740147133953-uq
Friday morning, around the 7 am time frame another 1.9 kWh
Ford F-150 Lightning Battery Preconditioning. 1740147150116-pt
RyZac
Owen
2023 ER Lariat w/Max Tow; 2021 LR Model Y w/ Boost
This!
Would love a button on charging screen that you push say 10-15 miles from a location your planning to DCFC.
The battery preconditions while using Google Maps on Android Auto according to Ford.
jlferg0509
Dayton
I'd like this too, if I were to get the Google maps update.
Not on a 2022. No preconditioning with Ford nav either. Can't speak to later years.
The Weatherman
Dean
South Central KY
Hey, but you can sing along with Karaoke while your waiting on your cold battery to charge.
