Brake Fluid Refill
grizwizwg
Walter
Arizona
2023 Ford Lightning Lariat ER, 2023 Mach-E Premium
I was refilling my coolant recently (details in another post) and noticed that my brake fluid appears to be low (reservoir right next to coolant). That is, I cannot see any up to the max line...not sure if the brake fluid has a color of any kind like the coolant does (bright yellow). If not, it might be harder to see.
My question is, can we just add more brake fluid like we do coolant, wiper fluid, etc.? I've never done that before, but if we can, this is the product I'm tracking:
https://www.amazon.com/Genuine-Ford...1841&sprefix=wss-m6c65-a2,aps,165&sr=8-1&th=1
Grumpy2
Central Oregon Coast
23 F150 Pro SR
Retired Hvy Construction
Brake fluid is clear. It is VERY hard to see. I would suggest not opening that reservoir. Dirt and moisture are important not enter the brake system.
Use a flashlight to shine through the reservoir and you'll be able to see the level.
It's probably fine. Brake fluid is only low if the brakes are very worn or there's a leak. Neither situation is very likely in a Lightning.
grizwizwg
Walter
Arizona
Thank you both for the info! I'll leave the cap on the reservoir and shine a flashlight on it to see where the level is at. Even if low, I'll leave it to the dealership :)
Why does the parking brake need to be off??
The electric servo's push the caliper piston from the inboard side, of both rear calipers, I don't think it'll change the volume in the reservoir by much, but it should go down slightly when the EPB is active.
Marcelo Zanetti
Marcelo
New York
Ford F150; Ford F-150 Lightning; Ford Explorer;
Both coolant and the brake hydraulic lines are "closed circuits", meaning if the level is bellow minimum (assuming that's marked on the reservoir), you might have a leak on the system.
The brake level goes down as the brake pads worn out and the calipers push out of their position, if you add brake fluid when that happens, most likely it will overflow the reservoir when you have to replace the pads and the calipers need to be pushed back.
Lytning
Georgia
Auto mechanics don't like it when owners add brake fluid for this reason.
I‘ve been doing brake jobs for 50 years. The easiest way to compress and retract the caliper piston is to open the bleeder valve. I’ve never had the reservoir overflow and, in fact, it’s normal to have to add a bit of fluid upon completion.
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
NW Ontario Ford Lightning
Robert
NW Ontario Canada
Contractor
Actually the best thing to do in our Salt-loving region is to apply never-seize to the bleeder threads when the truck is new-ish, and be sure the rubber covers are installed with a bit of grease. Then the bleeders don't 'rust-weld' into the cast iron.
Having lived in the rust belt I can tell you that many many cars have perfectly fine brakes years, even a decade or more, after the bleeder rusts up.
Heaven forbid that rubber cap falls off...
I assume the rubber cap was invented recently and put into service starting with 2022 Lightnings? I've never seen one prior to that.?
