2024 Platinum replaced 2023 Lariat 1st impression
flypony53
Rodney
Houston, TX
22 Ford F150 Lightning Platinum, 21 Tesla Model Y, 24 Tesla Model S
agree but at least with my 24 platinum - the sports mode is almost smoother (definitely quicker off the line ) and should be the normal mode and the sports mode should be the normal mode if that makes sense…..at least compared to my 23 lariat.
the 24 platinum steering is stiffer as well in normal mode then my 23 lariat. I know this has been documented but since the 24’s charge at a slower rate then the 23’s - is that a software issue that can be OTA or is a physical reasoning to it ?
it’s a shame my 23 lariat gained about 35 miles per hour when charging at my 80 amp vs my 24 that barely gets to 20 . I knew that going in but didn’t think it would be that bad or noticeable.
If they can speed up charging at a super charger not sure why they can’t go back to normal charge rates then my 23.
Ford changed the onboard charger for 2024 to 48A max for both Standard and Extended range. This shows up in the at home charging speeds. A shame really as you are trying to fill a battery that is almost 2x the size of the model Y at the same speed.
EDIT to add link: https://www.ford.com/support/how-to...ightning-charging-frequently-asked-questions/
3rdgenfan
Geoff
Delaware
Cybersecurity
If my truck had any sort of equity I'd make the jump to a '24 Plat, found an AntiMatter Blue down in Maryland but I just can't bring myself to basically restart the process all over again. The numbers after X-Plan incentives/pricing was tempting, though.
Unfortunately I'd have to sell the truck to Carvana and then go get the truck on my own since their trade in number was hilariously low.
flyct
flyct
Jerry
South Florida
Blissfully Retired
I had the same issue with the value of my 2023 Lariat. Mine was paid for so I didn't have issue of negative equity. The buy offer from Carvana, CarMax and dealer were low. The dealer finally came up to my number and called me 2 hours before the month end closed for the store.
I replace my vehicles quickly so normally leasing is not something I consider. With the lease incentives it made sense to me to lease. I was planning to lease and buy it our immediately. But with the 0% lease finance rate. I just put the money from my sale of my 2023 in the bank in a high yield savings account and kept the lease with zero down.
The incentives for buying it outright were $2000 less and still had 0% financing. I took the lease in case the value drops crazy low so I could walk away after 3 years, if I still had it.
3rdgenfan
Geoff
Delaware
Cybersecurity
The incentives for buying it outright were $2000 less and still had 9% financing. I took the lease in case the value drops crazy low so I could walk away after 3 years, if I still had it.
I was hoping to find a Lariat with the only two options being Max Tow + Pro Power OnBoard so it qualifies for the tax credit by ~$50...but no one has it around the 500 mile radius on Ford's website. Then when using the Lariats in stock I found it was cheaper to get a Platinum somehow due to the number of incentives thrown at them.
Their trade in was 27k and Carvana was $34k, told the sales guy and the GM and they just said too far apart. If they would have matched then I'd have gone down that day after pulling my audio stuff out.
  • I feel road abnormalities more in the Platinum. Feels like tires ride slightly stiffer.
  • Ride is much less "floaty". Truck feels more "Planted". I don't know if its the spring rates or calibration of the shocks.
Platinum has larger wheels and shorter sidewalls, which is obvious but it also has higher spring rates. I'd heard people complain about the floaty ride but never detected that in my Platinum. At some point I read what @SmoothJ posted - see below - and it made sense.
I rotate between Lariat and Platinum wheels and tires seasonally and detect only a small ride difference. I suspect the higher spring rates on the Platinum is mostly responsible for the difference in ride.
It was listed in the e-source book for the Lightning. Took me a bit to find it, but here it is.
I had the part numbers too and I copied the data from Oasis, but I don't have access anymore and I am not sure where I put it.
Massaging seats make in "Relaxed" mode sooths the back and my butt on rides.
Yep!☺
Throttle response is more ICE like.
This is fascinating. I can't imagine why this is different. Is this a Platinum thing? Is this a 2024 thing? To be determined...
The Platinum has a Gloss front "grill" which looks like it will scratch easily compared the Lariat when removing Florida Bugs
The gloss black looks great...for about a month, at which point you'll realize that the Florida bugs you are trying to remove are dings. Get it PPF ASAP if you want it to continue looking nice. I inquired about painting mine and my body shop guys talked me out of it because it will inevitably chip again.?
Upgraded Blue Cruise seems to only give me the addition of automatic lane change when signal light is activated on mapped roads. It does nothing new on unmapped roads
I find it centers on all roads better than BC1.0. Maybe your 2023 truck had a more advanced version than my 2022.
flyct
flyct
Jerry
South Florida
Blissfully Retired
I will inquire about PPF on the front ASAP The Lariat was easy to remove bugs without scratching.
I have used the Aero Cosmetics bug scrubber for over 10 years now without any scratched on any surface I've used it on.
https://www.amazon.com/dp/B00NFWUS8O
This is a picture of my F-350 after driving across south central Florida during Love Bug season
Ford F-150 Lightning 2024 Platinum replaced 2023 Lariat 1st impression 1741817086880-mb
flypony53
Rodney
Houston, TX
  • Massaging seats make in "Relaxed" mode sooths the back and my butt on rides.
Funny enough, this was one of the (many) reasons I did not go with the Silverado EV...My wife said it was a requirement moving forward.
flyct
flyct
Jerry
South Florida
Blissfully Retired
I understand,....... Happy Wife, Happy Life!!
It's not bugs you need to worry about, it's road debris. I posted the following after five months of ownership. Michigan winters are not the same as Florida anytime but I wish I'd known about the problem ahead of time.
My 2022 Platinum with fewer than 7,000 miles has a ridiculous number of paint chips on the gloss black grill and lower trim piece. The bumper and hood have just a couple paint chips combined. I get that paint chips happen but this is excessive and suggests the painted plastic isn't super durable. Hopefully the photos below illustrate what I'm talking about. Are others having a similar issue?
What's the best way to fix and/or mitigate future damage? Touch-up and PPF? Wrap? Something else?
The last image is an extrapolation of what the parts will look like after 70,000 miles.?
Rip
Rip
Southwest Harbor, ME
2024 Lightning Platinum
Quality Consultant
So, question for you Lariat owners. I traded my Tesla in on a Platinum. I love it, but I noticed a Lariat in a parking lot the other day that appeared to have charging ports on both sides. Mine only has a single port on the driver's side. Anyone know why there is that difference? Ports on both sides would be pretty good (although a single port in the front/center would be even better). Seems like it would be a lot more flexible at the charging stations.
3rdgenfan
Geoff
Delaware
Cybersecurity
It was just a fake port to match the driver's side, they got rid of that for 2024.
Oafy44
Georgia
23 ford lightning
Landscape contractor
Could be the fake door that came on 22/23’s but correct me if I’m wrong fleet can order them with dual chargers starting in 24? At least that is what the ford pro website option showed.
Dual chargers does not mean dual CCS1 ports
Scorpio3d
SS/IBA car wash owner
The 22s and 23’s have dual chargers which is how we are able to charge at 80 amp instead of 48 amp but yes, it is an option for fleet!
Dual charge ports would be nice, but probably overkill now that Tesla is putting out V4’s with longer cords most of the others have long cords to begin with!
flyct
flyct
Jerry
South Florida
Blissfully Retired
Dual chargers aren’t an overkill if someone only charges at home andhas very cheap time of use charging. They can charge fully in the limited cheap charging hours.
With my 48a output 11.5 kWh charger it can take me over 10 hours to replenishe after a 225 mile round trip. With dual chargers and a EVSE capable of delivering 80 amps or 19.2 kWh‘s it would take probably only 6 hours.
