astrand1
Alex
Studio truck driver
Thank you @Ajzride and @astrand1 for putting all of your time into this and posting your progress. I have a Comma ordered and am following closely so I can hopefully get it up and running without too much difficulty.
The credit goes to Ajzride. I’m very grateful for his help.
astrand1
Alex
Studio truck driver
Those are your lateral settings.
change tuning profile to low.
post pictures of the “toggles” page for long tuning.
Here is the toggles.
Ford F-150 Lightning Comma AI self driver assistant IMG_1035
Ford F-150 Lightning Comma AI self driver assistant IMG_1033
Ford F-150 Lightning Comma AI self driver assistant IMG_1034
Ajzride
Alan
Houston
Eng
you Are still using ford ACC. Toggle on “enable openpilot longitudinal control”
set your driving personality to “relaxed”
astrand1
Alex
Studio truck driver
Understood. So more questions. First off those setting changes are amazing. Now the truck brakes way more like I would. For the most part nice and smooth. I have 1pd on and it seems to operate just fine with it on. I will be on freeway shortly and see if that other change helps the horrible oscillation that was happening in the lane. Is there a setting for it look at the traffic lights? I am aware that it’s very experimental but I love being in the bleeding edge and trying new tech so I’m ok with that part. Also is this sending the data back to you or who ever? I have all the send data options on as I’d like to make sure if my driving can help out the developers that they can get it. Does it have the ability to see speed limit signs and adjust speed or is that a down the road item?
Ajzride
Alan
Houston
Eng
Experimental Mode = stop signs and red lights.
if you turn on experimental make sure you token on dynamic experimental control as well.
Speed Limit Control = speed limit signs, but the feature works a little weird because of comma safety rules. It will never gonfaster than the speed you set cruise at, although it will slow down and speed up based on signs up to the speed you set.
astrand1
Alex
Studio truck driver
Under speed limit control which one. There is car, map nav etc. ?
astrand1
Alex
Studio truck driver
So wonder what this means? When cruise is on but cancelled it says blended. When cruise is on it says acc. Does that mean the when on cruise it’s not using both camera and radar or is that something else?
Ford F-150 Lightning Comma AI self driver assistant IMG_1041
Ford F-150 Lightning Comma AI self driver assistant IMG_1040
Ajzride
Alan
Houston
Eng
DEC blends ACC and experimental mode. It has nothing to do with radar / vision.
DEC exists because experimental mode likes to drive 10mph under the speed limit.
astrand1
Alex
Studio truck driver
Thank you for all your info. I hope I’m not driving you crazy. Lol. Also I will note that the truck most times when I start it kinda freaks out. It throws all these errors and then after a few seconds then says lane keeping system on and all is well.
Ajzride
Alan
Houston
Eng
That's wha the extension harness is for. It's a hardware issue that can't be fixed in software.
I'm going to make a prototype this week of a USB Coupler with resistors that might be a simple solution rather than an extension harness. Will post some pictures as I go. If it works, we might could get a group buy on pcbway.com to have some made up.
astrand1
Alex
Studio truck driver
Wait are you talking about that short little jumper usb-c cable? If so that might be part of the problem. I don’t have that plugged in as the one long one that came with the kit was more than enough. I had no idea that was anything more than an extension.
Ajzride
Alan
Houston
Eng
B177y
Oly Pen, WA
2024 Pro ER Max Tow
