ctuan13
- First Name
- Chuck
- Jul 31, 2022
- Pittsburgh, PA
- 1979 Continental, 2022 F150 Lightning, 03 Marauder, 2024 F350
Well it's like the title says, my hood stopped closing on its own. (I can obviously still manually guide it down and push it closed) But here's the weirdest part, it will open just fine on its own, but refuses to close.
So I first tried a 12V reset(disconnecting and reconnecting the 12V battery), but that didn't solve the problem. So then I took my high level scanner and scanned it to see if there were any codes. Other than the hidden codes related to my TCU being disconnected and the errors thrown when the 12V battery was disconnected, there was only one, unknown code, but it stuck out like a sore thumb:
Under the BCM #1 (Body Control Module) there was code B1305:01 HOOD SWITCH.
I tried erasing the BCM codes, but this did nothing.
From my research this isn't related to the pressure switches along the tops of the fenders inside where the hood closes, this is related directly to the latch.
Unfortunately, or rather fortunately, I had to turn around on my cross-country road trip due to a leaking vent fan in my teardrop camper. I was able to score an appointment at my Ford dealer and I'm waiting to see what they say now.
I'd have gone and replaced the latch myself if I could, but I figured since I'll be back for at least a week, I'll just have them do it since it should be covered under warranty.
Have any of you ever experienced this failure mode? I'll be sure to keep you guys updated.
