HI Zeus
Craig
New Mexico / Hawaii
2023 Lightning XLT, 2013 Kia Optima Hybrid, 2003 F350, 1989-93 BMW Paris Dakars
SO retired!
In a previous post I reported that my new-to-me CPO Lightning had a LOT of road salt on the undercarriage. In the attached pictures you’ll see what I meant.
Having lived in AZ and NM my entire life my only experience with road salt has been working on and restoring cars that have the long term damage, I’d never encountered the demon personally. My previous experience did make be very aware that it should be eradicated ASAP though!
I crawled under the truck in my carport with a high pressure sprayer about 11:30AM and emerged about 6:30PM. YES, that was seven hours of cleaning the underside of the truck!!
My goal was to spray every possible area I could get to until the water running down from that spot was clear, not milky white. Honestly, I still didn’t achieve that goal 100%. (I will have round two in a few days.)
One of the first things I realized was that this was not primarily road salt. I believe the bulk of it was powdery dust from gravel roads. Some of it was actually little pieces of sharp gravel, like I have typically encountered on rural gas line roads or roads to oil fields etc. I knew this truck was from Michigan and commercially owned when I bought it from a Ford dealership over the internet/phone 700 miles away. I figured those two factors accounted for it $4000-$5000 reduction in price compared to comps. Since the truck had only been in service for a little over a year and had less than 20,000 miles, I felt the cost benefit ratio was acceptable, IF I remediated any salt exposure immediately.
A couple of takeaways:
1st
For anyone who might’ve had any concerns about spraying the undercarriage (ie batteries, inverters etc.) with high-pressure water, I believe I have proven this is NOT a concern. (Obviously I believed/hoped this would be the case, but am pretty confident that I now have the most experience with this activity, and can report zero incidents of electrocution, vehicle fires or equipment failure as a result.). ?
2nd
The design of these trucks can result in an incredible amount of road crap accumulation underneath. Anyone who has been under a 4x4 with substantial off-road miles on it will know that horizontal areas like the transfer case skid-plate/crossmembers catch and retain a LOT more crap than the rounded surfaces of transmissions, axles and differentials.
Well, the Lightning has many elements that create this same type of “lovely” table-top feature, primarily the battery pack, but also the inverters and motors.
I know my truck probably had WAY more accumulation of crap than most folks would have at this point, but I feel like it’s like the canary in the coal mine for this concern, especially if your lightning is gonna spend much time on anything other than nice clean black top.
My personal recommendation would be to ensure that your undercarriage is thoroughly cleaned at least once a year. I doubt there’s much of any way to get it done properly other than climbing under it with the high pressure washer like I did. I’m certain that the typical automatic car wash with the undercarriage sprayers would do very little.
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_7423
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_7420
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_7438
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_7425
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_7427
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_7428
Do be careful around case seals, wire terminations & pass throughs with high pressure.
PA Lightning
Tbone
PA
Lightning Pro
I read your other thread and noted that you said road salt was laying or piled up on the under carriage. I figured it was not road salt because road salt does not pile up like that.
Whoever previously owned that truck did a lot of driving on gravel roadways or in quarries. I would hit the rusted areas and frame with some fluid film
Good job on the cleaning
flyct
Jerry
South Florida
Blissfully Retired
@HI Zeus
Craig,
Good job cleaning off the stuff underneath.
Another area where lots of stuff accumulates is the area around the 12 volt battery. Pull the panel in the back wall of the front trunk to access that area. That panel slides up and then it can be removed on 2023 and earlier models.
HI Zeus
Craig
New Mexico / Hawaii
SO retired!
@HI Zeus
Craig,
I did the 12volt area yesterday as well. Here’s what it looked like under the front trunk area (I can’t embrace the “frunk” term) when I removed the liner today. And then after washing.
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_7459
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_7455
HI Zeus
Craig
New Mexico / Hawaii
SO retired!
I notice there is still a dusty "film" on the non-painted parts (mostly aluminum I guess). Any recommendations from you folks in the "rust belt" for neutralizing the salt that lingers? I've seen products advertised, but don't know which ones, if any, are worth the trouble.
I know from restoring BMW motorcycles that salt isn't exactly friendly to aluminum either.
flyct
Jerry
South Florida
Blissfully Retired
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
Good job with the, frunk(?) bay. Ur coolant overflow tank looks a little low.
75Highboy
Robert
2025 Ford Lightening,73 Bronco
My new truck I noticed the rear drive shaft for the rear wheels is rusted already. Ford did not paint that area. I too have restored old ford trucks and very aware of keeping the undercarriage clean.
I was planning on getting under and painting those parts so they don’t continue to rust. Little disappointed in ford not painting those parts.
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process IMG_0924
21st Century Truck
Martin
I bought six cans of Amsoil Heavy Duty Metal Protector spray along with the cheapo Home Depot "pistol grip" spray faciliator attachment for spray cans and spritzed four of those Amsoil cans into the underside crevices last Fall to protect against future underbody corrosion. Eye protection and an airway mask are advisable for this task.
Four of those Amsoil HD MP cans were enough. Took a good 1.5+ hours of careful work under the truck... 70% or so of the effort went into the underside's front end and rear end.
Underside looks decent now after our harsher-than-usual Winter here in the midAtlantic. There is of course dirt but not much corrosion.
Lytning
Georgia
@Ford Motor Company
The corrosion can't be good for the shaft seal.
Ford F-150 Lightning Road Salt, and other undercarriage cleaning process Shaft Corrosion
SSNutz
Troy
SE Wisconsin
2024 Flash
Sr Process Innovation Specialist
Living in SE WI I have my truck undercoated with fuild film film in fall every year. Stuff is sticky which collects dust and really that helps with winter road salt. Perhaps that is what the previous owner did, if so that is a good sign.
astrand1
Alex
Studio truck driver
@HI Zeus
Craig,
I just took out the frunk pan. It’s pretty easy to take it out. A few bolts and one connector and put it comes. That whole area gets really dirty. I plan to do it once a year and power wash it.
Vypurr
24' Flash
This is key! Do your fluid film in late summer/early fall so that it can accumulate lots of dust and debris ahead of the winter. That sounds weird, but it forms a nice protective "crust" before the salt comes!
HI Zeus
Craig
New Mexico / Hawaii
SO retired!
Good job with the, frunk(?) bay. Ur coolant overflow tank looks a little low,
@Ford Motor Company
Grrrr, not happy about THAT observation! I doubt paint will help that either.
I appreciate others sharing their experience with these rusted areas. I figured this truck was probably ahead of others due to its exposure etc., but clearly these parts will look like this sooner of later regardless of where you're driving.
I do think painting them can't hurt (not positive it will help, but its a cheap way to attempt to possibly remediate premature problems).
I was contemplating hitting the rusted stuff with a sandblaster at low pressure and non-aggressive media, since my experience with painting over existing rust is not encouraging, regardless of the product. I figure all of the fine dust that had accumulated over the past year and that I sprayed out has already gotten in to any possible areas of concern... (hopefully Ford properly designed against that, and there are none).
