alconcolaroja09
Is it that it is not as robust or is there as safety issue as well?Good advice. Reliability with the Ford Mobile EVSE has been reported by many as not robust.
Not robust. There have been no reports of safety issues to my knowledge.Is it that it is not as robust or is there as safety issue as well?
MidAtlantic best me to it but to concure, I have not seen any safety issues either.Is it that it is not as robust or is there as safety issue as well?
Generally the Ford mobile "charger" not as reliable as other EVSEs. Plus the plug to outlet can be an issue with overheating and melting the outlet, as with every mobile charger. When I refer to a "Charger" it really is an EVSE. Electric Vehicle Service Equipment. The actual charger is in the vehicle.Is it that it is not as robust or is there as safety issue as well?
I just had a 50 amp RV hookup installed at my house. I plugged in my Ford charging cable and it reached a maximum of 6.6 kw/hour. Is that the fastest one can charge with the standard Ford charging cable? Thanks.
I upgraded the wiring for 80 amp, and it charges at 19.2 kWh per hour. I own the Lariat ER.I just had a 50 amp RV hookup installed at my house. I plugged in my Ford charging cable and it reached a maximum of 6.6 kw/hour. Is that the fastest one can charge with the standard Ford charging cable? Thanks.
No.So If i change my breaker to a 60 amp (currently a 30amp) will that increase my charging ability with the supplied ford charger?
So If i change my breaker to a 60 amp (currently a 30amp) will that increase my charging ability with the supplied ford charger? would that be safe? its a 23 XLT
If i wired with 4 AWG Copper then I would buy and install one of the highly rated reliable Hard Wired 60 amp EVSEs. The I would keep the mobile charger in the Fronk to use when traveling. THHAT IS WHAT I DID.Yep the wiring is 4 gauge. not a problem there. When I initially installed I was thinking of a 60 amp breaker but downgraded to 30 after. I may just go back and install a 60. Thanks
The Ford Mobile Power Cord says (on the back of mine anyway - see image) 32A max, so at 240V that's 7.6kW assuming no losses.I just had a 50 amp RV hookup installed at my house. I plugged in my Ford charging cable and it reached a maximum of 6.6 kw/hour. Is that the fastest one can charge with the standard Ford charging cable? Thanks.
I expect Webasto downrated the chargers internally but didn't change the labels. Mine looks exactly the same on the back.The Ford Mobile Power Cord says (on the back of mine anyway - see image) 32A max, so at 240V that's 7.6kW assuming no losses.
But perhaps they operate at 30A as some contend, then 7.2kW max with some losses at 240V.
So your output seems lower than would be expected IF you have a 240V circuit.
But is you outlet voltage 240V?
If it is say 220V, then that's why you get 6.6kW: 220V x 30A = 6,600kW
Regardless...the FMPCs have a spotted record based on posts about failures after relying on one exclusively for charging for some period of time (months).
On a 50A 240V outlet you could charge at 40A (80% rule and NEC code for plug-in EVSEs).
So find a better EVSE suitable for daily use that can charge at 40A. Or higher if hardwired on an appropriately wired and protected (breaker) circuit.
If you have an SR battery, the limit is 48A (also for some 2024 and later trucks with larger batteries).
@chlYes, thanks, I guess that explains it.
I put mine away in the Frunk ice bucket under the cover, but I thought about checking it too.
I used it when I first got the truck - had a 30A J1772 set up on a 40A breaker for my 2012 Nissan Leaf through a 6-50R for the 6-50P that my GE WattStation came with and got an adapter to use the FMPC temporarily. I took down the GE EVSE but then I read about all the issues with the FMPC so I put the GE back up for the Leaf and put the FMPC away in case of an emergency, like a stranded EV on the road.
I'm an EE so I know how to check the current, if I could find my ammeter, lol, but I'll take everybody else's word for it that it is 30A. It makes sense if the idea was to use it with the 30A 240V bed outlet.
Nice of you to help someone out on the road, we EV drivers have to stick together for sure! Those compliance EVs don't have a lot of kWh's in their batteries, a friend of my wife's has a Mini Cooper EV with pitiful range - about the same as my 2012 Nissan Leaf - well not much room for battery on a Mini Cooper.
@chl
Chris,
Mach-E and Lightning Mobile EVSEs are the same except for the pigtail.
If the pigtail for your mobile Ford OEM EVSE has a piece of yellow tape on it, then it is limited to amps. If no tape then it is the 32 amp version.
The Lightning's ProPower 240vac output can handle 30 amps continuous , unlike a typical home dryer outlet which is code limited to 80% of circuit rating for continuous use.
Tesla has multiple cords that will change the output of their mobile connectors. I have a 14-30P plug version for my Tesla Mobile Connector that plugs into my 4-wire 30 amp dryer outlet and limits the Tesla Mobile ESVE output to 24 amps.
Here is a picture of a 30 amp Lightning pigtail.
