cowboys1870
Alex
Oklahoma
‘22 Lightning SR XLT
I added two 120V neutral switching transfer switches (I don’t have the bed 240V). I paid $300 to have the pair installed, and $700 EVSE install.
One powers my NG furnace, and the second does the master bedroom + living room TV + fridge via extension cord
https://ezgeneratorswitch.com/
Ford F-150 Lightning Real-World Home Power Backup Options Using F-150 Lightning IMG_0150
Traconesu
Patrick
Quad cities, Illinois
Ford lightning platinum
Hi there - first time posting, big-time F-150 Lightning fan!
Here today as I've spent hours reading as many forum posts and electrician articles about possibilities to use the F-150 as a backup generator. However, many of these posts get in-depth on the "why" a particular solution won't work (particularly around F-150 outlets being netural-bonded / GFCI), but not necessarily exact specifics on how to make it work.
Personally, I'm trying to find the most cost-effective option that allows me to use a standard generator inlet (ideally without the added cost/complexity of a transfer switch), so I'm torn between options C and D below (assuming E isn't really an option).
This is what I've found in order of cost - with a few questions:
  • A) Sunrun-Installed Home Integration System + Ford Charge Station Pro ($9,400)
    • Pro: Theoretically the "correct" solution offering the most power out of the truck and as easy as calling Sunrun
    • Con: Most expensive, large equipment, only EVs with a combo charging port can use the CSP (e.g. no plug-in hybrids with a basic J1772 - at least I couldn't find an adapter), Sunrun may not be the easiest to work with
      • Question: Anyone know of a J1772 to J1772 CCS1 adapter?
  • B) Non-Sunrun Installed HIS + Ford CSP (Estimating $5k to $9k range)
    • Pro: Theoretically adds some cost savings / customer service improvement using your own electrician
    • Con: Might have issues if electrician isn't familiar with this kind of equipment
    • Detail: $3,895 minimum for the equipment (assuming the CSP came with your truck), so as long as your electrician quotes less than $5,505 you should be saving some $$$
  • C) Neutral-Switching Transfer Switch + Generator Inlet + 240v Bed Outlet + Cord (Estimating $3k-$5k including EVSE install)
    • Pro: Substantially cheaper than HIS. Flexible backup option as you can just use a regular portable generator and makes your house "generator ready". Forces you to identify and limit backup power to the "critical" circuits in your house, but you don't have to deal with load management as much later (some may see this as a con)
    • Con: Requires a very specific type of transfer switch that is "Neutral Switching". To the best of my knowledge, I can only find 2 options readily available (Reliance used to have one, but recently discontinued it at least as of Dec 2022)
      • Generac 9854 (50A)- $620 - I know the truck outlet is 30A, but I like this option to maximize options, e.g. portable generator
      • Generac 6852 (30A) - $380
      • Question: Can anyone share a link to any other readily-available 50A or 30A "Neutral-Switching Transfer Switches"?
    • Detail: As part of this, I actually had the Clipper Creek HCS-80 HVSE installed ($1,066 on Amazon + $1.6k installation for me including local permit) since I didn't want the J1772 Combo plug and big Ford branding.
  • D) Basic Generator Inlet + Interlocked Breaker + Cord + Generator (Estimating $3-$4k including a $1k generator and EVSE install)
    • Pro: Eliminate the neutral-bonded / GFCI discussion and just buy a compatible portable gas generator
    • Con: You have to worry about storing, fueling and maintaining a portable gas generator + noise when it's running
  • E) Basic Generator Inlet + Interlocked Breaker + Cord (Estimating $2-$3k if it can be done including EVSE install)
    • ***There is a good chance this is NOT possible due to the neutral-bonded / GFCI aspect of the truck outlets***
    • Pro: Theoretically least expensive/complex option. Allows full flexibility in your main panel of what to turn on if using backup power.
    • Con: Doesn't appear this can be done and meet NEC code requirements (e.g. without messing with disconnecting grounds, etc.)
    • Question: Does anyone know a code-compliant way to do this?
  • F) Extension Cords + 120v outlets (Under $200)
    • Pro: Just plug in and go!
    • Con: May have power loss on very long extension cords. Not very aesthetically pleasing. Not sure if this is NEC acceptable.
    • Detail: This literally means plugging a regular extension cord into the 120v outlets and running into the house through doorways/windows etc in an emergency situation.
Phew - that was a lot. If I missed any options, let me know and I'm happy to update this post!
I run my home from solar. The grid is how I charge my solar batteries if my solar batteries get low because of cloudy days and in that instance If the grid is down I use a 60 amp manual reliance transfer switch that let's my truck charge my solar batteries. Since my solar battery charger sees my truck as a main bonded neutral there's no need connect the trucks ground wire to the transfer switch. Only the two hot legs are transfered and the neutrals are always connected. Therefore no ground fault on my truck. And the solar battery charger thinks it's connected to the grid. I've got a good ground from the main service panel to my solar battery charger. My main panel is bonded, my truck is bonded and no ground fault.
Lightning Rod
North Coast
2023 Ford Lightning Lariat ER
CNC PROGRAMMER/MACHINIST
I just installed the Micro-Air Flex SoftStart unit onto my AC compressor and it works like a charm! It took about 30 minutes, and 25 minutes was finding a place to put the unit and securing it.
Thanks. $400 well spent. :clap:
Oh, I forgot to mention...
During the after-installation backup test, the Lightning ran the whole house AND the AC, flawlessly! I turned the AC on several times during a 15 minute test while plugged into the Lightning. It ran both refrigerators, I had many lights on, 2 TVs, router and everything that usually runs on a typical day at my home, and had zero issues. I can't wait for another power outage! :) 🌩🌩🌩
I have a 5 ton unit with a LRA of 185A. It has now dropped to 30A and I can run it with my PointGuard system as part of the whole home backup.
Congrats. Love the MicroAir, but my 5 ton unit is just not efficient enough. It's 10 years old, 17 SEER American Standard. It pulls too much for the truck. I can run everything else in the house though. Clothes dryer, Oven, Pool Pump, Central Heat. But no AC.
Ford F-150 Lightning Real-World Home Power Backup Options Using F-150 Lightning IMG_8786
Lightning Rod
North Coast
That's most unfortunate. Did you use their latest product; EasyStart FLEX? That unit is supposed to handle up to 6 ton AC units. My AC unit is old also... 19 years old! It's only a 3 ton, but that EasyStart FLEX should be all that you need, according to them. :unsure:
That is good to know. I may reach out to them. I knew they had a new single product to support all size units. I have the older style that is sized to the AC tonnage you have. I didn’t know the new units were also more efficient at startup. I’d love to be a guinea pig for them or see if they’d give me some credit toward a trade. I’d love to know I could run this AC from the truck. I don’t need to run it all at once. I can trade off for a few hours back and forth if needed with other appliances. I can go days without needing an over or a clothes dryer.
Lightning Rod
North Coast
Yes. Their EasyStart FLEX should do it. Just from reading about 50 or so testimonials before I bought it, almost all of the user's comments are the same... it dramatically reduces startup inrush amperage draw enough that they can use midsized and even smaller generators. I'm willing to bet that it would work for your AC unit and the Lightning.
Traconesu
Patrick
I used my own option and power my solar inverter with my lightning which charges my solar batteries while powering my home.
timtread
Tim
2024 F150 Lightning
Hey folks!! It took me a while to get my home power situation figured out, but yesterday, I was able to use Option E - hooking the Pro Power Onboard to a generator inlet. I thought it might be useful to share that experience, so here goes!
We are having solar installed, so it was a good time to address using the Lightning. I had already decided against SunRun because I already have an EV charger (non-Ford) and I already had 14 solar panels.
What we added is another dozen or so panels, but this time with a Tesla Gateway and two PowerWall batteries. All of that was in the range of double what SunRun would've cost, but i would only have gotten the Ford integration. Anyway, decided to go with a more typical solar system and use the Lightning as a backup to the backup.
So, what we had done was very, very simple. A generator inlet leads to a breaker in the main panel. That breaker has an interlock so that the main must be shut off to use the generator inlet. Bought a 25-ft generator cord, which goes from the Lightning to the inlet.
Immediately got the ground fault when all this was hooked up. But, in other threads on this forum, it was suggested to remove the ground pin. My electrician thought about that for a few minutes and decided it was safe and reasonable. That made everything work!
I was able to watch the Pro Power screen and see the wattage draw in realtime as we switched things on in the main panel.
Frankly, I do not know if it is code compliant, but, my electrician felt it was perfectly safe. He even pointed out that the Tesla Gateway works the same way, in that it has no earth ground and relies upon the main panel to provide a ground. He reasoned that the Lightning is acting as the Tesla Gateway when I use it.
Do note, this is not an automated solution. I will have to flip breakers to use the truck and I may have to turn off the Tesla Gateway. We are awaiting the inspector before I can really jump in and play with it.
My electrician said the same thing. we had a 4 hour power outage last night and my Option E set up with a 30 amp breaker ran my house until the power was back online.
phildickerson
Phil
Raleigh, NC
2023 F-150 Lightning
Great! It's funny....ever since I got that stuff installed and tested, I have not had any occasion to use it! Our Tesla walls have saved the day for our brief outages. Longest outage in the past four years has been two hours. Dang Duke Power decided to make my backup less useful. (-;
ClevelandBeemer
Chose option E and had it installed today. Works like a dream!
Ford F-150 Lightning Real-World Home Power Backup Options Using F-150 Lightning 4e91a9d2-fa71-4dcd-98aa-83c2b0d1f10d_cdv_photo_001
Ford F-150 Lightning Real-World Home Power Backup Options Using F-150 Lightning IMG_5716
Ford F-150 Lightning Real-World Home Power Backup Options Using F-150 Lightning IMG_5717
Ford F-150 Lightning Real-World Home Power Backup Options Using F-150 Lightning d3177a64-10c5-4820-8936-e1e02befbbfd_cdv_photo_001
Ford F-150 Lightning Real-World Home Power Backup Options Using F-150 Lightning IMG_5713
NW Ontario Ford Lightning
Robert
NW Ontario Canada
2024 F-150 Lightning XLT
Contractor
I did similar as well,
since I had the solar and battery system first, it was easy to use an EG4 Chargeverter and set it up to suit the Lightning output to DC charge the house battery - and no G-N issues, since the truck only powers the chargeverter and doesn't connect to the AC side of the home electrical.
My typical daily loads are only 37kWh - so the truck can supply that over 24 hr period with 120v easily, and my solar battery is 131 kWh so no need for the truck to carry any big loads, no issues with in-rush from motors, and no risk from someone switching on the electric dryer that would trip the truck pro-power. Having the truck as back-up to the solar-house battery system adds days of run time.
The "cost" is DC Lightning:AC Chargverter: back to 48V DC house battery losses, but hey, as others pointed out it is not needed too often.
The 2024 allows the propower to run while the truck is off, not sure if all the earlier lightnings do this?
The side benefit this time of year is charging the Lightning from solar.
Traconesu
Patrick
I'd love to see an update for my 2022 that would allowed to use my pro power without starting my truck & disabling the 30 minute shutdown.
ClevelandBeemer
How does one disable the 30-minute shutdown?
