The Weatherman
Dean
South Central KY
This has to be the best mod you can do on the Lightning! Thanks to Thanks to @Drayday55 for printing it for me his version which is perfect. Also the under seat air vent extension and Frunk button cover. The air extensions worked well for my
One note on the install, when taking of the center trim piece the video shows to pull towards but there is a plastic pin in a hole that needs to be lifted up but the center screen is blocking it from coming out of the hole it is in. You have to pry the hole down and the pin up to get it out, I also put a L- wrench in the hole once I had the pin out of one side to keep it from popping back in while prying the other side out. If you just pull I'm sure that pin will break, although not a big deal as it's probably not needed.
Thanks for the detailed information regarding the ā€˜center’ trim, but I’m still a little unclear on where that is located. Would it be possible for you to shoot a pic from the outside of the console and point out about where it is located?
Many thanks.
CRAIGC540
Craig
Moreno valley
Technician
Many thanks.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 1000008091
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder 1000008096
cwstnsko
Mesa, AZ
2023 F150 Lightning Lariat ER
They'll "move" / shift into park anyway, just put yours into gear and open the door and you'll see. It doesn't physically move, but the gear will shift and the LEDs with it.
It seems to depend which version of the shifter you get. I got the $30 one from the original e-bay listing and the knob definietly physically rotates if you open the door or shut off the truck with it still in D or R
mr.Magoo
2022 Lariat ER, AMB
Yes, but the point was more that all rotary shifters will/should shift to park when you open the door / shut the truck off even 9f it doesn't physically rotate.
Drayday55
Andre
San Diego
22 Lariat Lightning
Contractor
We have a mavrick work truck and I noticed the newer shifters only the light goes to park when you open the door while in gear. The older shift mechanism is more complex and has a servo that rotates the shifter back to park. Also when the mavrick is off you can spin the shifter all you want in either direction. You cannot with the older shifters with the servo built in.
Mike G
N. AL, USA
This just makes more sense in my opinion. The dial itself has no physical orientation, so why involve other mechanical systems just to make it move?
I dont like the dial shifters, but reducing complexity is the name of the game here so some motorized dial just seems like its trading one failure for another
Exactly! Why bother putting a stepper motor actuator in when you can simulate the movements using the LEDS and circuitry. Just unnecessary complexity. The knob doesn't need to physically move at all from D to Park. Just cycle the LEDs.
Same as Mach-E. What is surprising is that shifter throws errors in the Lightning.
Mike G
N. AL, USA
This is for the 15.5 inch screen R/R of the GSM. I realize that there are steps in here that people are skipping as not really necessary when swapping out the GSM...I'm posting this only as a reference to be referred to in general.
Mike G
N. AL, USA
Are there any versions of the GSM that don't result in DTCs being thrown? I mean there are a lot of variations of these shifters around...Escape, Bronco Sport, Maverick, MME....some have the stepper motors in them some don't.
Update/Edit.....I ended up going with a Bronco Sport GSM from a '21/'22 model, and it is the motorized version that actually turns the knob to Park when you open the driver's door (if you were in Drive at the time). And it works perfectly and doesn't throw any codes at all.
sstevetx
Steve
No DTCs with mine.
  • Shifter Model: LX6P-7P155-LE
  • Designed for: 2021 Ford Bronco Sport
  • Motorized: Yes, you can see the rubber ring/grip rotate to park when in drive and you open the door
  • DTCs: None found using CarScanner Pro (Android) with an OBDLink MX+ or in FDRS
Mike G
N. AL, USA
No DTCs with mine.
I'll go with that one then. Thanks!
The Weatherman
Dean
South Central KY
Anyone using the 21-24 Escape seeing DTC?
sstevetx
Steve
Here's my original post with pictures as well as the ebay listing. With your FDRS knowledge you probably already know this, but a PMI doesn't work in FDRS on the GSM. I had a 2-day license earlier this year and figured I would try. I tried answering both yes and no about having the original module, but both failed complaining about the part number.
jeff_h
WV
2023 F-150 Lightning XLT ER
Paint-Drying Observer
I used a rotary shifter from a 2021 Escape Hybrid, made a post here around the beginning of page 25 -- was getting errors every day with the old shifter and while I don't have a scanner to check for DTCs, the warning light went away and hasn't returned in the 2k miles since.
digitaldad
ABQ
'23 Lariat ER MaxTow
No DTCs with mine.
I bought that one too, same one as OP's original eBay post.
Regarding questions about DTCs...
I only had DTCs twice.
1. After removal of OEM shifter assembly and turning on truck (with nothing connected to the shifter harness).
2. After connecting and removing the new rotary shifter a couple of times (before putting into the 3d printed cubby), I didn't seat the harness connector in fully (and started truck).
Other than these times, haven't seen one for the shifter, since.
P.S. I thought the rotary ring didn't move when being in Drive and it auto-placing itself into Park...but it sure as heck does (motorized turning - as sstevetx states).
