priceb
Price
Western North Carolina
2023 F150 Lightning XLT SR
College Instructor
So I finally crossed the FDRS hurdle. Thanks to @rugedraw for his guidance and all of the posts and information on this and the F150GEN14 forums. Truly if Ford would work out their issues this would be straight forward.
I'm fairly savvy with a PC and followed all of the directions from others. Nothin I could do would get me logged into FDRS though (license was bought and added). They have a new banner since June 15 that there are some problems with cached credentials, but I followed all of that advice. After a PW reset and several other hints from other pages, an hour later I called support.
Support had me go to the SW page and download and reinstall FDRS - right over the top of the old install. Didn't uninstall anything first. Then before launching he had me reboot. Login worked the first time after that. Only mildly irritating.
To say the least 13 modules updated in about an hour. As noted in post #1572 I can't get the ACM and RFA to go away. All other modules updated. I didn't have any GWM or modules that require a USB, so they were all pretty straight forward. For general knowledge - the 13 modules were PCM, ABS, SOBDMC, BECM, DCDC, GFM2, SOBDM, SOBDMB, ACM, TRM, RFA, DSM, HVAC. Last week the dealer had updated the IPMA, PSCM and FHCM for the CSP for front parking sensors.
I could see the dealer sessions from last week. The IPMA and PSCM took an hour and a half and the Front Hatch module took about 15 minutes total with some other stuff.
For the dealer sessions, I expanded all the lines related to a module update and then "printed" it to a PDF. Did the same for the sessions I have done. Mainly wanted a record of elapsed times for each module update.
You can also do a Battery Health report (and kinda save using screenshots) that will tell you the health of each cell in each module. This is the test our dealer did when we had bad modules.
Did you ever get the BCM updated for WAL?
Scorpio3d
SS/IBA car wash owner
Welcome to the @TaxmanHog “Tweaker“ club-???
Really good call on the battery health. I forgot that was in there. I'll have to hook up again tomorrow. I'll have to do a little googling to recall where that is buried. I was a bit cautious in what I did other than the SW updates.
I did get the BCM back on May 1 in the BCM-24.5.1 release. The details were something about Frunk closing securely when the truck was locked. That got me the WAL.
It may be called BECM test, I can't remember. You should not have to hook up your power supply. It was a pretty quick test if I remember. You should also be able to see the tests Utter did back when your truck was with them for module. Both the before and after. They will be in your Vehicle History as another line item for the dealer visit IIRC.
You do not need to hook up to the truck to review history.
FDRS captures everything. Its hard to hide being a tech. Last week looks like they got brave and did the updates with no power supply - or it still drained hard. IPMA was started with 67% SOC and the IPMA was started with just 19%. It took about 14 minutes.
Ford F-150 Lightning Lightning Software Updates using FDRS 1750388979408-2
OK - guessing that all the little details in the hands of the novice (me) is dangerous. I'm wondering if they had to replace my Front Hatch module. They tried twice to update the SW and it failed. Code E100. They tried PMI on the module 3 times answering NO each time to was the original module installed and it failed with E100. Then an hour and a half passes and one more PMI is successful. They didn't add the parts to my work order.
Ford F-150 Lightning Lightning Software Updates using FDRS 1750389583173-jc
Is there a way with FDRS to push the trucks config/as built to the Ford servers? I made updates last weekend that still aren't reflected in the As Built. None of the change I made were in modules that I updated yesterday, but at the start of each FDRS session it pulls data about the truck from the cloud. I guess I'm surprised some of it didn't get overwritten.
If I understand correctly - you made config changes last week in some module(s) using FORScan. Yesterday, you updated the firmware of entirely different modules using FDRS.
If so, it sounds like FDRS only updates the cloud As-Built for modules that were updated. Which I would expect.
In my mind there are two pieces of "data" for each module. The first is the firmware itself. These have version numbers that get updated when you do an FDRS update. You can see these version numbers if you click on each module in FDRS and look at it's data. I believe these are actually firmware files that are loaded into the module and there can be more than one. The most common one seems to be F188.
The second piece is configuration data - what we can see in FORScan in the AsBuilt tabs. And you can also see on the Motorcraft As-Built Site. I'm not surprised that FDRS doesn't look at the config data or update it for modules you aren't touching. We have heard of instances though where an OTA or FDRS update wipes out a FORScan configuration edit/mod on that module. I believe this is because some updates not only update firmware files but also do a configuration step.
Hope this makes sense (and is right) ;) .
Did you not have an APIM update? Or are you already on Sync 25094?
Thanks - it does help. When I start the FDRS session it reads some config from Ford. I assumed this likely to be the As Built. I figured if it read it, then it might possibly update or overwrite what the truck had or some process might actually send the truck config back to Ford. I guess perhaps it only does that for modules you update.
The good news is that my Forscan updates persist on the truck and will eventually make their way back up to Ford in the next few weeks.
I am still on 24127. No APIM has popped up. I'm headed out to reconnect in just a few to run the BECM battery test. Other than the network test/scan is there something I'm missing to make it run a module check?
