UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
I'm not sure if you looked at the github threaad recently, but there is someone on there petitioning very hard to collect the bounty simply because he suggested adding resistors, even though he didn't invest anything in the prototypes. I basically told him have fun collecting from Comma, we would take up a gofundme to reward UncleTony.
Man, If I knew all I had to do was make suggestions to fix the issue...
Idk, I don't get that train of thought. I don't even claim credit for the final product, my goal was to understand the issue and turn the resolution into something the average person can do. It would have taken me much longer to do this without input from people that know more than me on all the subjects leading to a proper resolution.
This is supposed to be an open source project, not a money grab.
UncleTony
Tony
Yeah props for even taking this project on. It's only the Lightning that has the issue correct? That shrinks the pool of potential buyers even more with the comma being such a niche product already.
Yeah, something in the lightning modules causes a stub with the comma connected.
You can see it when you compare an ICE F-150 to the lightning.
My truck:
Ford F-150 Lightning Comma AI self driver assistant 1752693806325-lv
Alans ICE F-150:
Ford F-150 Lightning Comma AI self driver assistant 1752693853465-8k
The pins don't match their designations since Alan got a reversed set. But you can see one of the 128 readings is sitting at 85 on the lightning which is causing reflections for whatever is on that Bus. The PSCM disconnects with reflections, which is why we get a Christmas tree on startup.
UncleTony
Tony
The 120 drops us into over-termination territory and the 360 puts us at 55 ohms and 69 respectively. Still slightly out of spec, but within margins. I don't expect 69 ohms to matter much since that is coming from the comma power. The 55 ohms is what we care about.
B177y
Olympic Peninsula, WA
Hardly a money grab. More of just a "Thank you for your time and effort".
UncleTony
Tony
Not intentionally replying to any funding. Was referring to the github user complaining that he's not getting a payout for theorizing the problem.
oafydude28
Robert
2025 lightning flash, 2023 MachE GT
Alright – a couple of updates before I forget:
  1. I'm cutting off orders for breakout boards starting today. PCBWay has sent me photos confirming the production boards were produced correctly, which means they'll ship in the next couple of days. I’d rather ya'll get the proper design instead of the breakout board workaround. And with USPS shipping times, it's just not worth it anymore. If anything goes wrong for any reason, I’ll reopen orders.
  2. Alan (@Ajzride) and I revisited the USB-C cable discussion offline, and we’ve agreed that going forward, USB-C 3.2 Gen 2x2 and USB4 are the only cables we will recommend. These are the only ones that include the necessary internal connections by specification. (We are working on finding specific cables on amazon that are known to work to recommend).
More updates are hopefully coming soon—we’ve been working on a lot behind the scenes.
It looks like this cable from Amazon doesn’t work. Still getting errors on startup. I tried it again with the short jump only and there was no errors on startup. Should I try a USB 4?
I put on about 1,000 miles in the last few days and the was 2 instances were no errors appeared for a section of the drive. If I clear the codes after startup they do not come back for that drive.
Ford F-150 Lightning Comma AI self driver assistant IMG_0553
Ford F-150 Lightning Comma AI self driver assistant IMG_0554
Ford F-150 Lightning Comma AI self driver assistant IMG_0555
Ford F-150 Lightning Comma AI self driver assistant IMG_0556
Ford F-150 Lightning Comma AI self driver assistant IMG_0557
UncleTony
Tony
Do the errors only exist at startup or are they sticking around once the comma is up?
oafydude28
Robert
The stick around
I have the Comma powered by the OBD port so it stays powered up. The codes stick around and do not clear.
UncleTony
Tony
The stick around
So an important thing to keep in mind is that it doesn't matter if the hardware is powered on. It matters if sunny pilot is up and controlling the signals and hardware.
From what I am gathering, you are having errors stick around after sunny pilot boots (When the camera opens and shows the overlays), and the "one pedal fault" and "service vehicle now" are the only errors that stick around. Is this correct?
If so, you are able to clear those errors with something along the lines of forscan and they don't return until you turn the truck off?
oafydude28
Robert
From what I am gathering is that you are having errors stick around after sunny pilot boots (When the camera opens and shows the overlays), and the "one pedal fault" and "service vehicle now" are the only errors that stick around. Is this correct?
Thank you for clarifying. You are correct the only errors that stick around are the service vehicle now and one pedal fault.
I clear the codes through car scanner app and a Bluetooth connection that I use for ABRP. The code do not return until the truck is turned off.
UncleTony
Tony
I'm between two possible theories here,
1. You have a bad harness or box.
2. The CAN reflections are manifesting slightly different in your truck than what we normally see and are causing the one pedal to fault.
Option one doesn't make sense to me since the short cable resolves all of it for you. The fact that you can clear them with a scanner and they don't return also would point to it being caused by an error that doesn't clear once the reflections are resolved.
DM me your shipping info and I will send you a breakout so we can at least eliminate the reflections if nothing else. I will have to order a set, so it will take a bit to get to you.
PJnc284
Garner, NC
I can send him the one I'm using and just remake mine since I have a spare board and a bazillion resistors
