PJnc284
Garner, NC
2:30 pm for us weird people on the east coast wondering why it's not working yet :cwl:
UncleTony
Tony
2023 Lightning Lariat
Cybersecurity Engineer
Once you order, I will get them assembled and request payment from the app you chose in the order forum. Total price will be $55 which includes shipping. Total lead time is going to be a week maximum before they are shipped. Should be more like 3 days, just don't want to oversell it.
UncleTony
Tony
pfft. reading an entire line is overrated. Ordered one just because. May just let it sit and look pretty on my desk. :crazy:
I'm glad I put the extra time into the case design then :)
In all seriousness, thank you for the order.
El Duderino
2025 Flash Job 1
I put it in an order. Thanks for all your hard work on this and resolving this issue.
UncleTony
Tony
I don't recall posting the final iteration of the casing on here. I believe the forum was down at the time. If you can read "Lightning" from left to right, you have the right orientation. If you have it turned over, the lightning goes towards the truck and the comma goes to the comma.
Ford F-150 Lightning Comma AI self driver assistant 1753832314566-zd
Ford F-150 Lightning Comma AI self driver assistant 1753832288742-9l
3rdgenfan
Geoff
Delaware
Cybersecurity
Would you say it'd be beneficial to grab one of these to replace one of the older breakout board style setups?
UncleTony
Tony
Yes, The breakout boards were a great low-cost way to prototype and validate the concept, and they’ve helped a lot of people get up and running. That said, they were never really intended for long-term use — they’re more suited for controlled bench testing, and they can be prone to issues in harsher environments like a vehicle interior.
The finished PCB was designed specifically for this application: it’s more robust, compact, and reliable, and it solves a number of small but important weaknesses in the breakout-based setup. While the breakouts cost around $1.25 each (before tax/shipping from China), that doesn't even cover the component cost of the production design. So for anyone who wants a more durable, plug-and-play solution, the finished version offers much better long-term peace of mind.
3rdgenfan
Geoff
Delaware
Cybersecurity
Yes, these are specifically designed for our use. The breakout boards are only designed for controlled testing, not long term or harsh environments
Heading out of town this weekend for vacation but will put a request through shortly.
Alan sent me a harness with a breakout board he assembled, so figured I'd ask!
UncleTony
Tony
Ah, you replied before I did the smart answer. But yeah, it is worth it for added piece of mind.
UncleTony
Tony
Just to clarify — if you’re currently using a harness mod (like a harness extension or added resistors wired directly into the harness), you’ll need to revert to the original OEM harness before installing this adapter. If you’re using the breakout board setup (the small USB-C box), this PCB is a direct replacement.
The reason is that combining this with a harness mod would introduce more resistors than intended and potentially create electrical issues. The new adapter already includes the proper termination and routing internally, so stacking additional mods can disrupt the intended behavior.
3rdgenfan
Geoff
Delaware
Cybersecurity
ServiceNOW is slow today, so I've been hitting refresh.
He sent me one of the newer OE harnesses that comma sends out after the harness extension I had done initially was giving some wild errors.
