spacepirate
Ken
Middle-of, CT, USA
2024 F150 Lightning Flash
Nice!, FYI - I recommend stowing the original shifter (if able to) as a last step before disconnecting the harness to go to rotary...helps save some space if putting in a box/storage.
I wish I had thought of this too but I have a box that should be sufficient to protect it.
One of the four 10mm bolts that you need to remove to get the shifter out is actually under the stowed position of the shifter so you should get that bolt out BEFORE you put the shifter down.
digitaldad
ABQ
'23 Lariat ER MaxTow
That is indeed, good guidance! I will edit that post.
I had swapped in/out both stock and new rotary shifter twice before I made the final upgrade and only took the original bolts out once.
Vancouver, Canada
2023 F150 Lightning Lariat ER
I bought an inexpensive rotary shifter from AliExpress using part LX6P-7P155-EH paying about $54 USD all in. I pulled the driver side trim and attached it temporarily for testing (easy) and everything works without any DTC's and lights up correctly. It automatically shifts into park when the driver door is opened. I might change it over if the conversion mount becomes easily available or mass produced. Right now it will stay in my truck so I can still drive it if I ever have a problem (no tools required). The cheap ones on ebay are knockoffs from China. You might be able to save yourself some money by ordering it directly. I have no affiliation with the website or vendors. I just wanted to pass along another inexpensive option that's been tested.
Search for LX6P-7P155-EH
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder Screenshot 2025-07-21 at 14-51-59 Gear Shift Module LX6P-7P155-EH For Ford Escape Bronco Spor
OtterJohn
Philomath, OR
Got my shifter in the mail today, tub won't be here until late August (per the Etsy order status page).
That said...what size/type screws did everyone use to mount the shifter to the tub? I'm sure I have something in my spares box, but don't want to strip the tub's mounting points when it arrives. Forewarned and all that...
The Weatherman
Dean
South Central KY
If you ordered your tub from ManionMakes, the screws will come with it.
Walle1jm
2022 Ford F-150 Lightning SR XLT 312A
I just ordered mine from the same Etsy seller along with the rotary shifter from eBay. I don’t necessarily have a need to have the work surface down while in gear but just freeing up the clutter and having more space is my main motivation for doing it.
As others have mentioned, pretty crazy the existing shifter is so click and clunky for it being a shift by wire system. Although it does make sense to keep this part for the Lightning based on the annual scale of the F-150. I wouldn’t be surprised if they go to the rotary dial in the future like in the Expedition.
Mike G
N. AL, USA
Personally, I don't see a reason to ever remove the center stack on a 15.5" version of the Sync screen.
Those tabs up under the front were pretty easy to lift up to get them out of the holes and slide the trim panel back. As long as you're standing outside the truck and leaning in to do the work. You can't do it while sitting in the driver's seat.
AirVeg
Travis
23 F150 Lightning XLT SR
I went the front mount route. Bought all the stuff to sand, fill, and paint. But when I put it in for a trial run I said, well dang… that doesn’t look half bad. So for now no intention in painting but I’ll hang onto the supplies in case I change my mind. No ragrets here.
Also I farmed it out to 3 different dealers while shopping for a trade up to a Flash and not a single dealer mentioned it during the appraisal. So that was interesting.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder IMG_6110
CRAIGC540
Craig
Moreno valley
Technician
Nice. Yeah I never planned on painting mine Since so little of it shows on the top after the trim piece covers it. How do you find reaching for the shifter? I kinda wanted that version but thought reaching for it would be to different because I used to rest my hand on the original shifter, I can still do that with the rotary shifter.
AirVeg
Travis
I used to rest my hand their also but I got used to it very quick… you just readjust. It’s also in the exact same place as my wife’s new Explorer so the muscle memory between the 2 is helpful.
CRAIGC540
Craig
Moreno valley
Technician
I have this phone holder and it blocks some buttons with the phone in place, not a big deal but your version would help that. But then the phone would block the rotary.
Ford F-150 Lightning Stick to Rotary Shift Knob Conversion w/ 3D Printed Rotary Shifter Holder rotary
jredondox
Jorge
San Diego, CA
2021 F150
It was a little darker outside today when I left to do some shopping and I happened to notice that there is a blue ring around the edge of this Bronco Sport rotary knob afterall. I just didn’t notice it before.
Mike,
what’s the part number?
