Storm Breaker
Norm
F-150 Lightning Lariat
truck driver
this is bananas...im almost a year behind in updates. just got this one last night. FU Ford. :facepalm:
Seeing the excitement in the BC-1.4 thread I go out to the Garage and push the Start button to tell the Mother Ship we're ready for deployment!
Start, check software update screen, recap of prior update, stop, open/close door
Start, check software update screen new update is pending.
Ford F-150 Lightning Priority Update: FHCM-24.AC.AD - Enhanced Frunk Functionality 1755261220833-3f
pjell
Same here, and I wasn't previously so far behind. But it's been crickets for 4 or 5 months.
All my updates have come in clusters. 4-5 over a couple weeks, then nothing for months.
No Oil HaHa
Josh
2022 Ford F150 Lightning Lariat ER
You’re who I pay attention to as far as updates. My truck seems to be within a few days of getting the update after yours. This update installs tonight on mine. :)
Sgt. Carter
2022 Lariat ER - Star White
This morning I talked with my service advisor (whose very into EV’s) and she said the FHCM-24.AC.AD (frunk operation) OTA download took care of the CSP 24P24.
queuewho
Western PA
22 F150 Lightning Lariat SR
I had 3 CSPs in my app and they are all gone this morning after the frunk update. No idea if the update fixed them or if they expired.
The one in there was definitely the front sensor issue. I thought that was not fixable by OTA?
Anyhow, frunk opens a bit quicker now, so that's great.
ryun
Earth
Just got this update yesterday. Didn't have the CSP this addresses. 🤷
ashadkc9
Kansas City
Updates are not always sequential. That Frunk update was from last year, but I had still gotten all other updates including BC1.4 and the new APIM update a week or so ago. There is no rhyme or reason. I would LOVE the 500amp charging update, but I haven't seen that one in a while.
If you are getting updates, you will eventually get them all. This may not be the ultimate source, but it had previously served me well as a checklist to see what I had and had not gotten. It might be missing some of the newest ones... https://github.com/elmedico27/fordpowerup
Robocop
2022 Platinum; 1962 Lincoln Continental
I found a reason today to look forward to the frunk update - a new glitch I've never experienced before. I keep my truck in a garage. I regularly trickle charge the LVB. And until this past week, I've been disconnecting the wires, closing the frunk each day, and reopening it the next.
I thought, "Why the heck am I doing this?! I'll just leave the frunk open all the days I don't drive the truck." So, I've started the truck plugged in or not, locked, and unlocked the doors over several days with the frunk up the whole time. I even got the karaoke update while the truck was parked in the garage, just as I pulled into the garage and shut off the engine some days ago; it was still downloading.
Today, I removed all the wires and tried to close the frunk. Won't work via FordPass with the truck off or on or via the frunk button on the truck dash to the left of the steering wheel with the truck turned on (I didn't try the button on the frunk hood). After gently manually pushing the hood shut and letting the frunk lock itself, things were back to normal.
I think I was able to open and close the frunk via FordPass quite a few times after getting the karaoke update, so I suspect something else is responsible for my "frunk won't close" glitch.
Hi Jim,
A little off topic here but can I ask why you use a trickle charger? does your truck sit for long periods of time between drives?
Sgt. Carter
Hi Jim,
I use a trickle charger on my truck cuz it sits for a week or more at a time at our cabin. I use a 5 amp Battery Tender model and connect it via a quick plug I put in the frunk that’s connected to the 12 volt battery terminals.
I <3 My Lightning
This rolled in today (probably was meant for update Thursday, but the truck has been parked since then)
'23 xlt er 312A
Jim Lewis
San Antonio, TX
Yes, my truck may sit for days before I drive it again (I just had an inguinal hernia repair operation and am not supposed to drive for 5 to 7 days, for example). I started trickle charging because of the updates that required >80% SOC to run. Then, according to ChatGPT, keeping the LVB as close to 100% SOC is best for 12V lifespan. I also charge via my FCSP at 24 amps rather than 80, as I read on the forum that the LVB can be charged while the truck is charging, and slow charging the HVB will provide the most opportunity to charge up the LVB a bit (don't know whether this is apocryphal or not).
