Ford EVSE finally installed
Highpi
Ken
Sacramento, Ca.
2025 Lightning Lariat, Iconic Silver
I had the Ford Connected 48 amp charge station installed yesterday. Works as it should and, to no surprise, much faster than the included mobile cord.
I did use public charging twice while waiting for the install, mainly just to get the process down. One time at Electrify America and one time at a Tesla station. The rest was done at home with the mobile cord.
The electrician found some room in the main 100 amp panel, luckily, because he said there wasn’t enough power in the sub panel to make it work.
Ford F-150 Lightning Ford EVSE finally installed 1755814934432-ti
K6CCC
Glendora, Calif.
RLXXI, you have the Ford Charge Station Pro (will work up to 80 amps - not that your 2025 Lightning will use that much), whereas Highpi has the 48 amp Ford Connected Charger.
Highpi
Ken
Sacramento, Ca.
You have the 80 amp version versus the 48 amp. It seems hit and miss on what you get from Ford.
For my needs, the 48 is plenty. I’m retired and the truck spends a lot of time parked, so I’ll just top it off to 80% every week or so.
K6CCC
Glendora, Calif.
I don't have details, but a bunch of people are reporting that they are getting the smaller charger, that also does not support vehicle to house system.
Highpi
Ken
Sacramento, Ca.
Well, I spoke too soon. It charges just fine, but the charge station app doesn't want to connect to the Ford pass app, for some reason. I just get the spinning vortex of death and the charge station gets stuck in some type of pairing loop.
When Lightning sales grossly underperformed Ford’s forecast, they were stuck with a bunch of FCSPs. Apparently they have given enough away with the Ford Power Promise that they are switching over the less expensive FCCS.
flyct
Jerry
South Florida
Blissfully Retired
And most recently as this week, Ford is now shipping a 3rd version, 48 AMP Emporia, when truck buyers use the Free charger coupon.
flyct
Jerry
South Florida
Blissfully Retired
flyct
Jerry
South Florida
Blissfully Retired
My compass is broken, how will I be able to tell where the north side of my house is? You got something against green mister? ROFL
I have the same Vinyl siding on my cabin and The north side looks EXACTLY the same. You picture reminded me that I need to treat mine. :)
First, try powering it off for a few minutes then back on.
Not sure about your station but you had to set up the other ones with another app first to the WiFi and then to fordpass.
Signal strength is incredibly important here.
pirate4x4lance
Lance
2025 Lightning
This is what I just received a couple of days ago.
Rayden
'23 Lightning Lariat ER
I seem to be following right behind you, Highpi. Only had my truck for about 3 weeks now and have only been using the small plug in charger so far, with a couple of top offs at a charge station near my work. I haven't gotten moving yet on getting an installation done b/c I'm not sure what size line I should be getting, nor what charger to get. I'm not planning on using the truck to power my house, so I don't think that the FCSP is necessarily the best option.
Highpi
Ken
Sacramento, Ca.
I was thinking the same thing, but when I found out they were throwing it in, including labor, I figured why not.
If you haven't already, check out State of Charge on youtube. He has a "best of" for 2024 charge stations vid.
As for size, I think the newer trucks are limited to 48 amps. Someone please correct me if I am wrong.
I'm sure others will be along shortly to help out, as well.
