Not a 12V battery issue.
TwentyTwentyThree
2023 ER
I was just greeted with every possible light in the dash. Guessing it’s time for a new 12v - can someone point me to what battery to buy at a local advance auto or Napa?
I do not have forscan or anything similar - is the 12v plug and play?
Thank you
Edit: not a 12v battery issue. I pulled the battery and tested it - it’s fully charged. Taking the truck in for service and will update this thread.
rockfish
Rock
Shoreacres Texas
23 Lariat, Star white. ER Max tow.
aircraft mx.
I just had the LVB replaced in my 23 er as well. I took the truck to a dealership for its 10000 mile checkup and a LVB message i had on the phone. Also the truck wasn't taking OTA updates and completing them, They did the battery test and replaced free of charge. only down side was the dealership had the truck for 5 days.........
p/n for the battery they put in my truck is.
BAGM*H3
TwentyTwentyThree
2023 ER
I was able to get the truck started. My local dealer parts department is a rock star and was able to order a new battery to be delivered today. Picking it up soon. I’d drop it off for service but I need something to drive. Will eat this cost of the 12v.
Several threads, one pinned in the maintenance section.
TwentyTwentyThree
2023 ER
Was hoping to swap it in the parking lot. I have a 10mm, maybe service can let me borrow an 8mm.
Thank you
You need to charge the 12v fully, then reset the BMS (instructions easily found online).
TwentyTwentyThree
2023 ER
CCA doesn’t really correlate to longevity. Especially when there is never any cranking load.
It gets cold here
Link to instructions?
Turn the truck on to accessory.
Flash the headlights 5 times.
Then press the brake pedal 3 times.
The battery icon will flash 3 times.
TwentyTwentyThree
2023 ER
Quick update. While picking up the battery, I popped in at service. Service adviser pulled up a ton of codes - he said there is nothing that shows that my low voltage battery is low, however BCM was showing camera and some other errors. Recommended bringing it in, so I booked an appointment. This morning, I pulled the negative terminal for 30 seconds, all codes disappeared and the truck started. I have since driven 80 miles.
Thoughts?
ElectrifyingMe25
Trav
F150 Lightning, XLT, 2023
Thank you
AutoZone is a good place to buy a reasonably priced replacement 12V accessory battery. See my attached pictures. You can buy from their local store for $244.00. There is a $22.00 credit for the core.
Ford F-150 Lightning Not a 12V battery issue. Screenshot_20250923_175343_DuckDuckGo
Ford F-150 Lightning Not a 12V battery issue. Screenshot_20250923_175358_DuckDuckGo
TwentyTwentyThree
2023 ER
It is not my battery. There’s some other issue. I tested my battery - it is fully charged. See picture above.
I stopped by service, and service advisor was able to pull the codes via FordPass. He recommended I take the truck in for service. I scheduled an appointment, will report back in the thread. I haven’t turned in my truck but I already miss it.
FloridaMan655321
Banned
Banned
Banned
1973 F100, 2024 Flash
Thoughts?
This is why I have a quarterly calendar reminder to pull the negative wire from the battery for 20-30 minutes (I usually do it on the weekend while doing other things).
Seems it sometimes needs a good ole cold boot, just like old school computers back in the day.
Question, do you have your truck connected to your home wifi to do updates with? That is something I do to help with it grabbing updates fast and hopefully not utilize as much of the 12v battery when updating. Just something to think about.
TwentyTwentyThree
2023 ER
I pull the negative terminal when I rotate tires.
I charge the truck on level 2 every night.
The truck is connected to wifi every night.
It’s under warranty - I’ll take it in. I miss it already and I still have it
