FordPass PPO menu this is new right?
ClevelandBeemer
I wouldnt call them controls…..
Fair enough. My theory still stands. I think this functionality is only going to Lariat and Platinum owners.
Maineiac12
Iowa
I would be pretty pissed if they gatekeep this functionality behind trim level when Pro, XLT, Flash owners paid extra for 9.6 kw pro power when they bought the truck and we already had that app feature previously.
I wouldnt call them controls, when I turned the truck on, you can only monitor the usage.
I'm on Android so maybe it's phone OS dependent?
Funny thing when I started the truck, then looked at the PPOB app, it showed the system in an OFF status, which surprised me, for years this has always defaulted to ON with the cabin outlets being available. Funny that many members over the years have indicated they would like it to remain default OFF until a need arises, maybe a recent OTA brought us this easter egg?
Ford F-150 Lightning FordPass PPO menu  this is new right? 1759847818646-z6
I manually turned the system on, to show only cabin outlets available.
Ford F-150 Lightning FordPass PPO menu  this is new right? 1759847921631-lu
Then I turned on the Frunk & Bed outlets, showing status' as expected.
Ford F-150 Lightning FordPass PPO menu  this is new right? 1759847958070-qa
My 5.28.0 version 9/8 installed 9/18, does not present a view of Productivity Functions on the Vehicle tab.
Ford F-150 Lightning FordPass PPO menu  this is new right? 1759848036319-09
Rtashiro
Ryan
Winnipeg, MB, Canada
I have a ‘23 lariat and I do not have this in the app. But would sure like to have it. I just had a power outage yesterday and would have liked to monitor when running the house from the generator interlock.
SFsparkie
2023 F150 Lightning Lariat ER 01/23
Same. 23 Lariat, ios26.1, Ford Pass 5.28, PAAK, and NO productivity function. No opportunity to update iOS or Ford Pass
flyin525
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
SFsparkie
I don’t have beta 2. It does not appear as available on my phone yet
flyin525
flyin525
Richard
Youngsville, NC
You must be on the public beta then. I have the developer Beta, which means I’m just a couple days ahead of you.
SFsparkie
Thanks for explaining the Betas. I will try the updated charging with Forscan
SFsparkie
For your 23. What Forscan changes did you use successfully. Is it 6 or E or just two up on 7DO-10-04 xxx* xxxx xx--
flyin525
flyin525
Richard
Youngsville, NC
I just went 2 up from what was there. I dont recall what it was - I did it a month or so ago.
ClevelandBeemer
I hope that I’m wrong….
I would not blindly add 2.
For 7DO-10-04 xxx* xxxx xx-- See this post and enable AECVP keeping your other options the same.
For example if 0,4,8,C then add 2
If 2,6,A,E then it is already enabled and don't add 2. If you do you then you'd end up disabling it and toggling RF.
ClevelandBeemer
I wouldnt call them controls, when I turned the truck on, you can only monitor the usage. If you had FP 4.xx, it’s similar to that.
I just updated to iOS 26.1 Bata 2 as well as made sure my FordPass is V18.28.0. If the new info is because of iOS then a Lariat or Platinum with PAAK is needed have the new info display.
Needless to say this is very disappointing….
Ford F-150 Lightning FordPass PPO menu  this is new right? IMG_7552
