Pre-Purchase Guidance and Thinking Points
flyct
Jerry
South Florida
Blissfully Retired
I’m curious, can you run your entire house, HVAC off the Lightning? I understand it will consume power faster, I was just wondering if you have and how long the truck maintained it?
You have to manage power for sure as with any small portable generator. The Lightning will run a good 2-3 days managing power.
At our cabin I can run most everything except I have to only use one of the 240v appliances at a time. The AC, the Hot Water Heater, the well pump etc. So for example, When I need to heat the water in the hot water tank I turn off the AC and the well pump breakers. Once the water is hot I turn off the HW breaker and turn on the well pump to take a shower.
The Central AC was initially an issue since the compressor start up amps exceeded the Lightning capacity and caused the Lightning to trip its breaker. I initially put a window AC in the Master BR and didn't use te Central AC. . Later I installed a MicroAir Easy Start https://www.microair.net/products/easystart-flex-home-ac-soft-starter on the Central AC condenser that reduced the start up amps and allowed the Central AC to run on the Lightning.
There is one other hiccup using the Lightning with a Interlock bypass kit. While a portable generator will function plugged into the generator inlet the Lightning will sense a ground fault and trip it's breaker. If the ground is not connected from the Lightning to the Gen inlet it will not trip. Installing a transfer switch with Neutrals switched eliminates this issue. A Licensed electrician can advise.
Here is the Micro Air installed on my AC
Ford F-150 Lightning Pre-Purchase Guidance and Thinking Points 1760365417213-gn
flyct
Jerry
South Florida
Blissfully Retired
Thanks much. Good points all around. My house is currently ready for a power generator to be plugged into the panel where I can control the powered areas. I just need my electrician to confirm the truck can use the input.
I will send you a DM.
RLXXI
3rd rock
Automotive Technician
I run my entire home including central hvac the way I have mine connected thru a solar inverter.
There is a dedicated connection inside the inverter for a generator, it'll auto switch a regular gen to provide power based on how you decide, in my case it's simply to add to an already present battery array in my garage. I have it set to allow energy from the truck into the home based on battery voltage, can also set it for battery SOC, when it falls to a certain level of my choosing, it tells the generator to wake up and get busy, in my case it starts allowing current flow from the truck to help recharge those batteries that are also getting recharged from the PV array in the back yard.
I could opt for it to just use only the generator/truck as the main power source, (if I had no battery array).
Things I've found that help longevity of charge is the replacement of the regular water heater and clothes dryer with the newest heat pump technology. We avoid using the oven and cook top, both electric as they suck the power up real quick. We have a gas grille for cooking if needed during a power outage.
RipInPepz
Erik
Ohio
2025 Flash Antimatter Blue - 131kWh ER, 9.6kW PPOB
My opinion is that you might be able to make it to your vacation homes without stopping. If you drive 55-60 while towing, you should be able to get 1.5 or 1.6 mi/kwh, which equates to 196-222 miles on a full charge. If you have a level 2 charger at both homes, you'll be golden. Worst case scenario is you have to stop and charge for 5-10 minutes. Get the NACS to CCS1 adapter so you can use the Tesla Superchargers.
On to the battery, obviously you'll want the extended range, but make sure you get the 131kwh battery. Most 2025 flash trims are 123 kwh, I got lucky and have the 131kwh because it was a January 2025 build date, and they were still putting the 131kwh in the flash like they did for 2024. So if i were you, I'd look for a Lariat ER, or try to find a Flash with the 131kwh battery. It will be on the window sticker and advertise 320 mile range instead of 300 miles.
WXman
Central Kentucky
2025 F-150 Lightning Flash
Meteorology/Transportation
While I think having the *option* to power my house with my truck is great, and I did purchase the appropriate NEMA 15' cord to run from my truck to my fuse panel transfer switch inlet on the outside of the house, I'm not sure how often I'll actually use the truck. I may just continue to use my portable generator anyhow.
Reason being is that if I use my truck to power my house for 2 or 3 days until my truck is dead, then how do I make it out of my rural location to town? At some point my truck is dead AND my house is dead.
If I just use my portable generator, I can always make it to town to purchase more gasoline if needed.
97WhiteCobra
George
North Carolina
65 Mustang GT, 2010 F-150
thanks much, let me know if you need my email.
thanks and what a cool set up. I have a gas water heater, stove/oven, and heat pump. So I have that going for me. No solar yet though. You have definitely given me food for thought.
97WhiteCobra
George
North Carolina
Good point.
RLXXI
3rd rock
The only gas I have at my house I had to have installed by the local utility to run our back up generator, until getting the Lightning it was our only source of power when the grid skips town. I'm on my 2nd whole home gen since 2013 and I'd like it to last longer than the 1st one at 6 grand a pop, it's connected to an ATS and picks up until the grid returns, I use the truck/solar in the capacity of keeping run time low. NG ain't cheap by any stretch of imagination.
When I hear the big one kick on auto, it only runs until I plug in the truck. Depending on the situation with the grid determines how l go from there.
MidAtlanticLightningClub
F-150 Lightning Lariat ER
Some great discussion here.
To add my two cents
Go to www abetterroutplanner.com and get familiar with it, or get the app. From that plan your trips and see how the charging lays out.
The default efficiency configuration in ABRP is pretty good for the regular truck (SR or ER) but you will want to adjust your baseline consumption for towing. There is a towing efficiency thread here that can help estimate when you pull your boat.
I just did two road trips in the Mach E (MD to SC and AR) and one in the Lightning (MD to western NC) in the last 5 weeks. ABRP did a great job of planning and highway routing. However, remember to switch to some other navigation for close in. I had it miss my navigation to my destination twice.
ABRP is still inadequate for pulling a trailer behind my Lightning though. Ditto for Apple Maps. Ford Connected Navigation is best for that. Now if they would only add Tesla chargers to Ford Connected Navigation. Any progress on that one Brian / @Ford Motor Company ? I'm not paying for Ford Connected Navigation again until it includes Tesla chargers.
97WhiteCobra
George
North Carolina
Thanks again to all that have provided a wonderful amount of data and support. I have another question, I tried searching the forum, I’m sure it’s there, but has anyone had to do any warrenty repairs, what is the battery warranty? I googled it, but was given several data points.
WXman
Central Kentucky
The main high voltage battery pack on the truck? It's warranted for 8 years OR 100,000 miles, whichever comes first, beginning from the original in-service date of the truck. I believe there are one or two other items included in that warranty associated with the drive system of the truck, but you'd have to pull up the warranty guide, which you can download from Ford's website.
1) It is likelymto last many more days. My usage by day, starting Sunday - 12kWh, 16.7kW, 24.7kWh... Oh wait, 24.7 includes 12.7 of charging. So, in 3 days I used 40.7. 40.7 / 3 = 13.6. Round up to 14. 131/14 = 9.3 days.
2) ProPower has a setting at which it stops providing power. Need 20% to reach a charger? Set it for 25% to be safe. Manual explains this.
97WhiteCobra
George
North Carolina
Thanks so much that makes sense. One other quick question hopefully, i’ll be right back. I’m gonna look for your safety thing too. I need that.
Thanks makes sense the truck has a shut off, I appreciate you confirming. One other question, do I need formal wall charger or can I just buy a Tesla portable charger like my friend had when he visited and plug it into my 14-50 NEMA 240v 50A outlet to charge the truck? I’m not sure they are built for long term use.
Ford F-150 Lightning Pre-Purchase Guidance and Thinking Points 1760710237822-dd
SOME are made for continuous heavy use, others are not. Make sure you have the right one.
A hard wired charger is better if you can. You may even be able to use that exact wiring (ensuring current is set correctly).
