shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
Vancouver, Canada
2023 F150 Lightning Lariat ER
@PJnc284 @shoopg @21st Century Truck and others - are you seeing this behavior with the PPO reserve sliders not working now? I verified via DM that @lightning-spark has updated modules and he sees the "Keep On When Vehicle is Off" toggle. But apparently the reserve sliders no longer work for him.
PPO reserve slider is working! Disconnecting the 12 volt battery for 10 minutes did the trick. Some other very strange behaviour before I did that. I love the truck and it's a feature that I really wanted. Thanks everyone! :clap:
Now that it has been verified to work, I've added to post 1. Thanks to Jesse and all the folks who tested it.
Enable Pro Power Onboard with truck off (2022-2023 only. Standard on 2024+).
Creates a Sync toggle in the Pro Power settings screen. See this post.
7D0-10-03 xxxx xx2x xx--
7D0-10-04 xxx* xxxx xx--
If 0, change to 8. If 4, change to C. If 6, change to E
If you enabled the Advanced Charging Screen, you likely have a 6.
Requires truck to have 2025 PCM update and likely Sync version 25094.
Scorpio3d
SS/IBA car wash owner
Enable ProPower Onboard with truck off (2022-2023 only. Standard on 2024+).
Creates a Sync toggle in the ProPower settings screen. See this post.
Time to fire up the laptop it has been a while!
Thank you Bruce for all you do to keep track of all this stuff and everyone that has been a guinea pig!
It's working! Disconnecting the 12 volt battery for 10 minutes did the trick. I love the truck and it's a feature that I really wanted. Thanks everyone!
Did you try a Sync reset first? That usually clears up glitches on the center screen. If you aren't familiar, holding down volume down and next track on the steering wheel for about 10 seconds forces a Sync reset.
flyin525
Richard
Youngsville, NC
2022 Ford Lightning Lariat ER
I'm not sure I've ever rec'd a PCM update OTA. But yeah, if Ford decides to give 22-23 owners this functionality as promised and it requires a PCM as I believe, then a PCM OTA will need to happen.
That's a lot of ifs.
Personally I think they need to address the power off after 6 minutes issue before rolling it out.
As luck would have it, looks like a set of PCM updates hit FDRS this morning so here’s hoping they become an OTA
  • Wow
Hopefully. But the ones released in March never did :(. May have to break down and pay for a 2 day license at some point.
Vancouver, Canada
Yes I tried the sync reset a few times before I disconnected the 12 volt battery.
astrand1
Alex
Studio truck driver
Also can confirm this is working. I finally got around to doing this yesterday and works like a charm.
Pswag115
Peter
Atlanta, ga
'21 Mach E, 22 Lightning Lariat ER
I finally tried this yesterday.
Glare Free Working
Pro Power while off Got the toggle but it switches to off 5 seconds or so after I toggle it on
Silent Mode Working
Remove Message R Cam Working
Trailer Side view Unsure as Im having Towing Issues
50/50 Working
Disable Seat Belt Warning Working
Disable Power Down Working
The problem I discovered today is when I hooked up my trailer instead of trailer selection poping up it is a towing settings screen with 3 selections.
Trailer Light Check
Trailer Sway Control
Trailer Maint Reminders
And it says no active trailer at the top. Two diff trailers that worked 2 days ago.
Range GOM also does not switch to towing mode.
When i got to the towing app on screen it displays identically to above.
Thought I would check the Hive mind before I restore to as built. (total pita as I have to use a desktop, my laptop is a work one and wont install Forscan.)
I supect my PCIM is not up to current version, I do have BC 1.4.
'22 Lariat ER
Thanks for any help
PJnc284
Garner, NC
Noticed something rather amusing today after updating to add the enhanced charging screen back. If you have the charging screen up when you turn the truck off and then turn it back on, you can see the old charging screen for a while before it switches.
No idea on the trailer wonkiness but sounds like you're missing some software dependency for the PPO while off.
You are in the same boat as me. It will toggle on but switch back off after a few seconds. There was a PCM and BECM update that came out in March this year that I believe we need. When I compare my truck to ones where it works, PCM/BECM sticks out. The PCM controls the PPOB inverter modules.
BC is unrelated to the PCM, I also have all the BC and WAL updates.
Unfortunately the PCM has not been offered OTA. Requires a dealer visit or DIY with FDRS.
BhamDCam
Birmingham
2023 F-150 Lightning Pro ER
Hey y'all, I'm looking for some help too. I recently retrofitted my cameras with turn lamps and puddle lamps. I made the forscan changes here (see post #2) and the turn lamps and four-zone lighting are working great. However, my puddle lamps aren't working. You can find more info about this in my post on that same thread (post #3). Any ideas what the issue may be?
- Since neither of the puddle lamps are working I doubt it is a wiring issue, unless I got the pins wrong for both of them?
- I doubt the puddle lamps themselves are bad since what are the odds both would be malfuctioning "out of the box"?
- So I think I might have a Forscan issue. When making the forscan changes I followed the #2 post on the thread I linked above exactly.
Any ideas?
Any help would be appreciated!
Bringing this back to the top. I tried a different sent of puddle lamps so I don't think the original lamps I used were bad. Further, on both sides when puddle lamps should be on (tried testing using the 4 zone lighting) both showed they got about 2v DC instead of 12v DC. Any idea what might be causing this?
Again, any help would be appreciated!
Two thoughts: 1) Did you also enable Lincoln Folding mirrors with Forscan? If so, then a known issue is that puddle lamps don't work with that feature on Fords. 2) Contact @21st Century Truck - I know he upgraded the mirrors on his XLT and has done a lot of extra wiring to enable features.
