Heated Steering Wheel Retrofit PU-22G06
Brons2
Mij
Cybersecurity
This must mean that the retrofit is possible for other models :wink:
mattskr
Matt
Austin, Texas
23 Platinum Iconic Silver
shoopg
Garrison
Utah, United States
www.lightningretrofit.com
'22 F150 Lightning Pro | '21 Polestar 2 | '18 Charger Scat Pack | '98 Ford F250
Cloud Engineer
@watts/up For those that have fitted to a Pro or XLT do you have the heated steering wheel option in Fordpass upon remote start?
That's what those of us with the dealer retrofit are missing.
This is what my post was about. I've retrofitted the HSW in my Pro myself, full OEM but DIY. I do not have the option in FordPass, but my wheel does automatically come on with remote start when its cold out.
Yes, I did this in 2022 lol.
mattskr
Matt
Austin, Texas
Ah that's the other difference, not only do I not have the option in Fordpass but my steering wheel remains cold as hell with a remote start too. I've made some changes in Forscan that should have fixed it but has not.
watts/up
23 Pro SR
Sorry to add confusion. I was simply providing the link showing how it's done for @Brons2. I have not added HSW to my truck but plan to do so in the future. Following this thread as well...
mattskr
Matt
Austin, Texas
Main reason would be the interrogator running. Once the as build is pulled up to fords server you probably will see it. Until then you wont. THis is the same thing for when I help people add BlueCruise. THe truck has Blue Cruise but shows pending activation or coming soon until the as build correctly reflects on fords server. Then it triggers Ford pass to show it.
There is a limit though. I added zone lighting and had all the appropriate as build changed and it was pulled up on FOrds end. Still wouldnt show in FOrd Pass.
Since your truck should though I bet it will once the as build is aligned on fords end.
The only time interrogator is run is before and OTA and then in FDRS after the OTA there is a second bite at the apple for the Interrogator.
So if you send me your vin Ill take a look at your as build
@Jesse-Infotainment @rugedraw I've made the changes in Forscan to enable remote start heated steering wheel. My As Built was updated 5 days ago and I can confirm all my changes went up to the mothership. Fordpass however, still doesn't show the option for the Heated Steering Wheel.
Do you guys have a suggestion on what the next step would be? The only thing I can think of is completely resetting the truck to add it to Fordpass again but reluctant to do that if it won't make a difference.
Mine doesn't either. I didn't even know it was supposed to be there, tbh. I would assume that have to be scripted into the app itself, but not sure.
I'm also still at a loss. FYI, I just checked on my FordPass and I got this when I did a Remote Start:
Ford F-150 Lightning Heated Steering Wheel Retrofit PU-22G06 1740883089381-k
Clicking that Climate Settings box allowed me to turn off the heated seats and steering wheel and turn on cooled seats. I'm guessing you have all those icons except the steering wheel, right?
Ford F-150 Lightning Heated Steering Wheel Retrofit PU-22G06 1740883148449-j8
Ford F-150 Lightning Heated Steering Wheel Retrofit PU-22G06 1740883164391-a6
kstype
Kurt
Pennsylvania
Principle Systems Engineer
That is correct, I see all but the wheel.
salengueros
salen
San Francisco
Honda
I lost the heated steering wheel and got the $50 credit, but haven’t heard anything about retrofitting. Dealer didn’t have any clear info either, just said it might never happen.
abel408
Schenectady, NY
2023 F-150 Lightning Pro
Hey there! I have a '23 pro and I have upgraded to a leather heated steering wheel, but haven't installed the SCCM required to bring heat to it yet. All you needed to do was purchase and install the SCCM and use forscan to enable it? Any other things I would need to do or purchase? Reading the f150gen14 forums, a lot of members say they had to make or buy a harness. Was that not needed for you pro?
Thanks!
shoopg
Garrison
Utah, United States
Cloud Engineer
Thanks!
Yeah you’ll need to run a power and ground to the SCCM. I did it the official way of pinning out the connector on the BCM and running the wire from the BCM to the SCCM and then grounding it on the ground point behind the headlight controls in the dash. But I think really any power and ground will work as long as it can supply enough current. It’s a constant 12v supplied to the SCCM. You should be able to pretty much follow the guide exactly on f150gen14.
rio
CT
2016 Chevy Volt, 2023 F150 Lightning Pro
I want to do this too. Would you be able to point me to the crimp connector needed for the BCM? Does this pin simply supply constant 12V, or is there any programmed function to it? I don't recall the FORScan programming for HSW involving any changes to the BCM.
