Mike G
Mike G
N. AL, USA
Mike G
Mike G
N. AL, USA
Could this be the fabled APIM update that ads the NACS superchargers to the nav interface?
I thought I had that already....the ones in Conyers, GA show up on my map when I'm passing through there. That's where I charge on the way to Augusta.
Mike G
Mike G
N. AL, USA
Getting a bit further into it...
Ford F-150 Lightning Lightning Software Updates using FDRS APIM_OTA_Pending_31_Jan_26
Time to take it for a short drive or let it sit running where you have good AT&T coverage. Probably easier than getting out the FDRS setup.
Mike G
Mike G
N. AL, USA
Time to take it for a short drive or let it sit running where you have good ATT coverage. Probably easier than getting out the FDRS setup.
It's in the carport on an extended climate run right now...my update schedule is daily at 0900 so we'll see if it does the magic then.
This is not an inhibit OTA so ignores any schedule. Just occurs when the truck is on and it’s able to download.
I got it on a 10 minute drive to lunch yesterday. If you have it on now, it may have already installed.
majorgearhead
Summerville, SC
2023 Ford Lightning Lariat ER
Computer Systems Engineer
I just checked PTS for my 23. No bueno. Back to waiting for Ford to integrate NACS superchargers into the factory nav. With the latest Google Maps breaking its integration with the IPS and preconditioning there is really no current solution for routing with preconditioning when using Tesla Superchargers.
Also I have had no OTA’s since last March. I have done all module updates myself with FDRS since then. I think the only thing I lack at this point is NACS routing option in native nav.
Ford F-150 Lightning Lightning Software Updates using FDRS IMG_0002
mr.Magoo
2022 Lariat ER, AMB
Mine is set for 5AM, took the truck out for a drive and got back home about 2hrs later.
At 9.45am I got an email from "fightclub" asking how Iiked the update, and I'm like, huh ?
I go back out to the truck and then it pops up that I reciecved an update.
The car did act super weird as I pulled into the garage (I stopped briefly in the drive way with it in park) all sorts of warnings about park sensors and stuff (car is clean) so I don't know if it decided to apply the update right then and there. (bunch of DTCs on the park sensors and ABS module in FDRS when checking later, everything cleared OK)
Interesting thing is that PTS showed nothing, still on the old revision for now and no OTAs completed / pending.
Hooked up FDRS and the APIM update was there so I ran that now, took like 5min,
no longer in FDRS but PTS says it still has an update (might need some time to synchronize I suppose).
Mike G
Mike G
N. AL, USA
Checked for updates this morning and the APIM in the available software list has disappeared. So obviously the OTA took care of that....my new Sync revision is:
Ford F-150 Lightning Lightning Software Updates using FDRS Lightning_Sync_25221
Nice to see SW they created back on August 9 can finally get rolled out 5+ months later. I started my truck in the garage last night, the SW showed downloading after 20 minutes, hoping it finished install. I'll know more in a couple of hours when I get out.
21st Century Truck
Martin
I now wonder and hope about the updated Sync version for us with the 12-inch screens.
Kansan
Wayne
2024 Flash
Civil Engineer
.....did a selftest and everything was still reporting green.....and had another go...same thing. Rinse and repeat. Still the same.
So I've got the ACM update that never goes away along with an OBCC update that won't proceed because there's a communications error of some sort.....
My ACM Update disappeared yesterday when I had Mobile Service perform the 25C69 Recall on the Integrated Park Module; it included SOBDMC, PCM, and ABS (maybe a couple more, I lost my screen capture). He also took care of the 26C10 Trailer Module update; same update is/was available on both my Lightning and my '23 5.0. I don't know if he just went ahead and cleared the ACM because it had an Outstanding Field Service Action. He said he had to enter a PIN to make those disappear from the list. Oddly, the paperwork shows he address 25C69 and 24U14 but makes no mention of 26C10.
Ford F-150 Lightning Lightning Software Updates using FDRS 1773951691496-re
I guess I'll find out Monday. Mobile Service is coming back out to address 26C10 on my 23 5.0. It does not show 24U14 ACM Update like my Lightning did.
Mike G
Mike G
N. AL, USA
He had to enter a pin....? I wonder what that was about? I still have that ACM update in my list. I just ignore it now. But on the other hand my truck does not have an outstanding recall for the ACM module anyway (24U14). Just a ACM module in my list of available software that won't go away.
astrand1
Alex
Studio truck driver
What do you mean “ext. climate run” what’s the purpose of that? Do you mean you’re just leaving the truck on hoping that an update might happen?
Mike G
Mike G
N. AL, USA
Yeah that was the idea. But I had to actually go out there and tell it to "Update Now" to get things started. I thought it might connect to the mothership while it was in climate mode...but I guess not.
