flux capacitor
For the group of Lightning owners that rarely take long trips or pull trailers long distance and only use their Lightning for local and short trips where a round trip can be achieved on one charge having a EREV has it's own set of problems of most of the time not being used enough to keep it in optimum condition. It might just be wasted and not needed most of the time. Anything that does not get used very often eventually stops working. It also is like carrying dead weight constantly for no reason at all. If the generator is always running then you are like hauling a portable generator in the back of your truck for no benefit at all when the battery is doing all the work. I think as a hybrid it is a better design than Fords current hybrid, but not as a replacement for the Lightning BEV. Mazda is reworking their Wankel engine to be more efficient and meet all the emission standards. They are also hinting about a Mini Wankel. That may be just the thing for a generator. I think using something that resembles one of those ER rescue table transports for people that collapses as it is put in the ambulance but with a portable generator with a mini Wankel that you could slide into the bed of your truck for when need it would be far better. It is no different than the having to buy the whole house back up system as an accessory. When you do not need it for the Lightning you can use it for other things. Also a generator like that is easily replaced when dead than having expensive replacement for something integrally part of the vehicle.
