My Last update 8/2025 Convenient Frunk - Has Ford stopped sending out updates?
derm
Lance
Chesapeake VA
2023F-150 Lighting Lariat. 2003 Ultra Classic
2023 Lariat : No updates since August 2025 and concerned Ford is dropping support on the Lighting.
Is anyone receiving updates, Love the truck, but bad enough we will all lose our shirts in the future or be able to find parts.
sfringer
Scott
NC
Yes, many of us with '23s have received PT-25.8.5 in the last few weeks. I received it on 6 February.
mrau
23 Lariat⚡ER
Yes, but not a lot.
Three updates since August 2025 for my '23 model.
09/10/2025: Convenient Frunk Closing. BCM-24.5.1
09/17/2025: Blue Cruise Toggles and Walk-Away Lock. APIM Sync 25.2.1.6.5
02/07/2026: Charge Port Functionality & Cold Weather Performance. PT-25.8.5
derm
derm
Lance
Chesapeake VA
no blue cruise. guess I got the charge port coming
davehu
hot springs, AR
Ford F-150 Lightning My Last update 8/2025 Convenient Frunk - Has Ford stopped sending out updates? Screenshot 2026-02-23 172826
You can always try the 12V disconnect. Has worked for a few folks.
Ford F-150 Lightning My Last update 8/2025 Convenient Frunk - Has Ford stopped sending out updates? 10mm wrench
Jfennell55
Jason
2024 Ford Lighting
Mechanic
I have a 2024 flash no updates since November of 25.
Marcelo Zanetti
Marcelo
New York
Ford F150; Ford F-150 Lightning; Ford Explorer;
I have a 22 Lariat extended range and my last update was in September/25.
Could you please describe the 12V disconnect procedure?
Much appreciated, Thank you, :)
Unlikely to help, it didn't help me a few years ago anyways. Ford will send it to you when it wants to and not a day before. No clue how or why they determine when, not sure Ford knows either to be honest. My dealer updated a single module for me after I'd gone almost a full year, started getting updates about 3 weeks later. Coincidence? Maybe....I've given up trying to figure it out.
Yes, but not a lot.
Like the Ready Kilowatt avatar.
My first band after High School was called "Ready Kilowatt and the Voltaires"...we never had a paying gig, but we played a McGovern rally at the Shriver's in 1972.
https://www.nytimes.com/1972/08/30/archives/mcgovern-s-supporters-rally-at-kennedy-estate.html
Use a 10mm wrench to loosen the negative battery terminal (pic below). Then remove it for about 20 minutes. Then reconnect it. This will reboot all modules. A few folks have noted that they began receiving OTA's again but clearly no guarantee.
FYI, the info above about charging the battery is if you get an update and it fails. Won't help you get the update sent to you in the first place.
Ford F-150 Lightning My Last update 8/2025 Convenient Frunk - Has Ford stopped sending out updates? 1771979798006-uc
Marcelo Zanetti
Marcelo
New York
Thanks for the reply. 🙏
RocketGhost
Spencer
Memphis TN
2022 Lariat ER
This is my understanding too, if low 12v is the problem you'll have some sort of failure notification. If there's no sign your truck is even trying to receive an update then it's not a 12v problem.
