Identify ProPower, APIM says 2.4 kw, but 240V available.
16 amp is common on the euro style plugs. And two plugs could then pull 7000+ watts.
I wonder why the SYNC interface only shows the limited 10 amp rating?
Ford F-150 Lightning Identify ProPower, APIM says 2.4 kw, but 240V available. 1778775744778-a3
hb.sagen
hb.sagen
Henning
Norway
F150 Lightning 2023 Lariat
PreservedSwine
Fort Myers
2023 Lightning
There are many assumptions being made, based on what seems pretty reasonable information.
That being said, there are many assumptions being made here...
here's mine, with front 120v inverter...
Ford F-150 Lightning Identify ProPower, APIM says 2.4 kw, but 240V available. June 23 EXPOSED removed frunk
I think what you see mounted on it's side, in front, is the CONVERTER, when charging... as it gets hot taking 240v power and Converting to DC for the battery pack...hence the cooling lines...
ZSC100
Zach
Tulsa, OK
Electrical Engineer
Hey, so I'm going to look at configs soon. OP, can you 100% confirm the AC power is 50hz? Or did you already confirm this? You can check this with a cheap multimeter (some have this function)
hb.sagen
hb.sagen
Henning
Norway
I’ll check tomorrow :)
hb.sagen
hb.sagen
Henning
Norway
The frequency jumps all over the place. I tried adding a load while measuring, but to no avail.
How do I measure it reliably?
Oscilloscope
ZSC100
Zach
Tulsa, OK
Electrical Engineer
That's odd, what kind of meter and what kind of load? Try and inductive load like a motor.
hb.sagen
hb.sagen
Henning
Norway
ZSC100
Zach
Tulsa, OK
Electrical Engineer
That's wild, only thing I can think is the inverter's AC is too noisy, but even cheap VMMs should have filtering to fix that to measurement. Have you tried your meters on grid power and verified it works.
hb.sagen
hb.sagen
Henning
Norway
Yes, the wall is solid 50.00 Hz
