Bad front passenger side shock absorber?
DerMot
Derek
Ontario, Canada
2023 Mustang Mach e Premium, 2024 F-150 Lightning Platinum
IT Leader
Thoughts? This was just around the neighbourhood -- I'll try to get a better bumpy/higher speed shot tomorrow. Left side (was raining) is not squeaking and dampens the spring better....but it's doing the work of both sides technically. My dealer said "you need a tire balance and alignment" your suspension is working perfectly.
Bad side (right)
Good side (left) - was now raining hard
21st Century Truck
Martin
Bad side (right)
What is Your truck's mileage (kilometrage)?
My shocks, all four of them, were completely shot at just over 60 thousand miles. One was visibly bleeding oil... when I took them off, I could completely compress each of all four shocks against the concrete floor with one hand.
Ford is known to cheap out on OEM shocks, for their sedans as well as trucks.
I strongly suggest Eibach shocks for the Lightning as replacements if Your shocks are blown, or if Your truck is nearing 60,000 miles or its eq. in kilometers. If You have the $$$, then I suggest Eibach shocks anyway as they give a far, far better ride with the OEM springs (my case).
DerMot
DerMot
Derek
Ontario, Canada
IT Leader
just under 20,000 km -- I'm guessing the others are getting there too...the dealer feels it's totally fine. I didn't think I'd have to mount a GoPro and light to prove it out...
21st Century Truck
Martin
20,000 km = about 14,000 miles or so. In that case, it might come down to $$$ and changing them out for Eibach Lightning shocks anyway. Good Luck on Your decision!
Brad
Lincoln phev ‘21 & Platinum Lightning ‘23
not anymore
Was that the same stretch of road in both videos?
Joe.....Montana
Joe
Montana
2023 Lightning
It is posts like this that keep me coming back every day....some next level vehicle ownership and insights on here....
DerMot
DerMot
Derek
Ontario, Canada
IT Leader
Bad side (right)
Setup photo (no Siri) :)
Ford F-150 Lightning Bad front passenger side shock absorber? Screenshot 2026-06-18 at 20.30.37
thanks - can you give me more details? At the top?
I've never looked at mine, even after over 100k km's but if the top mount is loose it could cause a little vibration. The shock could be defective but that's the easiest thing I can think of.
mattbrac3
Matthew
Ramona, CA
25’ Lightning Lariat in Antimatter Blue Metallic
Local Pig
Based on the noise, specifically, I had a similar noise in a previous vehicle, and it ended up being some rocks in the bushings. I believe it was in the front bumper that was causing a squeaky noise, but yeah, like others said, the shock replacement is a huge deal. Mine already leaking oil, and they only had 10,000 miles on them.
DerMot
DerMot
Derek
Ontario, Canada
IT Leader
What exactly is the issue.
Without knowing that each side drove over the exact same pavement (EXACT same, not same stretch of road) i would say that nothing here looks to be a problem.
If its making noise then it could be any of a dozen other issues.
lots of shaking in the cab, especially on the passenger side, the seat, door and anything left on that side vibrates and chatters away. My Dad got sick from it on a road trip recently.... just way too much shaking. I don't really notice the same on the driver side, but I hear things and see things moving around a lot.
Are the top of the shocks normally rusty like this photo? This truck has only been on the road since November 2025 --
Ford F-150 Lightning Bad front passenger side shock absorber? Screenshot 2026-06-20 at 18.30.40
DerMot
DerMot
Derek
Ontario, Canada
IT Leader
thanks for the ideas, I don't see anything leaking ... I gotta check the back as well, I keep thinking it's the front, but maybe the back is causing the chattering and shaking.
