astrand1
Alex
Studio truck driver
Hi F-150 Lightning owners,
You have been asking for this one for a long time, and I know it has been a point of frustration to have the entire truck powered on just to use the outlets. For those that don’t have this switch yet, I am really happy to share that we are officially enabling the Pro Power Onboard with Vehicle Off toggle in your SYNC system.
This is rolling out specifically for 2022 and 2023 model year owners.
Earlier this year we pushed out Powertrain updates 25.13.12 (2022) and 25.8.5 (2023). A lot of you eagle-eyed forum members noticed that one. That update was the final prerequisite laying the groundwork for this feature. If your truck has already received that Powertrain update, we will be pushing the new toggle directly to your SYNC system via a silent update. You can visit this page to check your recent software update history.
Here is what you need to know about the rollout process.
When does it start? Deployments begin June 25th
Will I receive a notification? No. This is a completely silent update. There will not be any in-vehicle notifications, release notes, or vehicle downtime. It happens entirely in the background.
How do I know if I have it? Once the silent update completes, it can take one or two power cycles of your truck (turning it on and off) before the toggle actually appears in your SYNC menu. Keep an eye out for it after the 22nd.
How do I use the feature? To enable, navigate to the Pro Power Onboard screen. Turn on the respective outlets you wish to use. Toggle Keep On When Vehicle is Off. Turn off the vehicle.
I know we took a while to get here. Thanks for keeping the feedback loud and clear so I could keep taking it to the software team. Let me know how it works for you once it shows up.
Brian (not AI) from Ford
CC: Borrowing the image from @bmwhitetx to show the toggle
Now if only we could get a map update for the Tesla chargers in the factory nav. 🙏
Ted23Lightning
Ted
23 F-150 Lightning Lariat ER, 2014 Honda VFR 750 Interceptor
Mobile ADAS Technician
Send me a message and let me see if I can help with this.
Thank u Brian for keeping us updated on updates/ rollouts. Thank u Ford for coming out with more & new updates for our trucks 🙏
Rayden
'23 Lightning Lariat ER
Also note that it appears to actually be a lower limit than 100 watts. Because of an odd situation, I am almost always leaving PPO turned on with about a 50 watt load (measured). PPO stays on just fine. And as Heliion pointed out, it is rather energy inefficient leaving it on. Hopefully the reason for leaving it on will go away in a few days.
Well, ok. Now I'm curious... :inspect:
Buf_T
michigan
2023 Lariat Lightning
r
Thanks for getting this pushed thru. NOT being able to do this was a pain when I did my 5,000 cross country trip, camping in the truck bed tent. Often in RV sites in campgrounds grabbing an overnight charge, I would have to start the truck to use the bed power at night. Usually flashing my headlights at neighboring tents in the campground. Keep the updates coming.
Dimitri
DImitri
2022 Ford F150 Lightning Lariat
Thank you!
MaintGrl
Marsha
El Sobrante, Ca
Still pretty much useless then, unfortunately.
Most use cases are intermittent loads or low power. Fridges, power tools, small appliances, A/C, heating w/thermostat, charging your devices - all intermittent or low power. I wish the engineers would consider the real world when designing features.
Ya, . . . 100watts🤷‍♀️
Pacific.NW
Christian
Vancouver, Canada
2022 Lightning Lariat ER
Hmmmm… learning about this update now, but I was camping recently and pressed the power button for the outlets in the bed while the truck was off, and nothing happened… but then I pressed the unlock button from my fob and pressed the power button again and presto! Power! Pretty sure I didn’t already have this update. 🤔
Is it true that if the truck is running, the 100W minimum is not in play?
Evans
Evans
F150 '23 Lightning Lariat
My engineering brain says there must be a technical reason for a min power draw and timer. Currently camping on Vancouver island and the BougeRV fridge does not draw enough to keep the outlets on while the truck, 23 lariat, is off. Still the best truck for my use case ever made.
djryan13
DJ
Ford Lightning, Tesla MS
Yes, this is how I camp.. I have a small hot water heater running off my 240v bed plug which I obviously only use intermittently over a weekend period. Leave truck on with AC off and it’s been fine. If you mess with the truck at all, it turns off so you have to turn truck back on. Stupid thing.
ryry
Ryan
Nashville
Lightning Lariat ER
Anybody else on EAP without these Powertrain updates?
