hughestr
All,
I have a 2022 lightning XLT with about 83K miles on it presently. A month ago, I had the SOBDM replaced under warranty because the truck stopped being able to AC charge at home (and work). After that repair I haven't had any additional problems AC charging. Last week on an 8-hour trip to FL I noticed that during level 3 DC charging after a few minutes of charging at 160+kw the charge rate would suddenly drop down to 75kw then after a minute or so tick back up to over 100kw. It would then go back and forth between 75kw and 100+kw for the remainder of the session until I stopped charging. After the session it took quite a bit of trying to get the charge port to let go of the cable...at times I didn't think I was going to get the charging cable out of the charge port. This happened almost every stop with many different charging networks (Ionna, EVgo, EA, and even Tesla). I have attached a photo of the charging curve from one of the stops.
I took the truck back to my local dealer for service on Wednesday and as of today they still haven't diagnosed the problem. Do you guys have any thoughts on what the issue could be?
Thanks in advance!
Thanks in advance!
